ChangDriver
Posted: Tue Aug 02, 2016 6:20 am Post subject: Snot Valve Not Snotting... |
After the last time I flew, I opened the snot valve and instead of the gunk blowing out it dribbled out. Plane makes pressure and everything else is operating normally. What do I need to clean/fix?
Craig
wlannon(at)shaw.ca Guest
Posted: Tue Aug 02, 2016 6:48 am Post subject: Snot Valve Not Snotting... |
Compressor. Start with the output check valve.
rocknpilot(at)hotmail.com Guest
Posted: Tue Aug 02, 2016 7:32 am Post subject: Snot Valve Not Snotting... |
| Quote: | From someone who's been down this road so many times they named the street after me...you said the system seems to be operating normally other than the snot valve? So if your gauges are registering air pressure regeneration, the compressor is doing its job. The snot valve can be finicky in that it can easily develop reasons to incompletely close - either from basic wear & tear to needle valve obstructions to just accidentally being left partially open. If this were the case, there could still be enough closure to build pressure but just enough seepage to continuously clear the valve. Whatever the case, ripping the system apart is a pain. The 3' tall line workers with the 11" fingers that built these planes musta smirked every day when pondering we Westerners trying to dig into the many dark nooks & crannies with our sausage digits. I would highly suggest you start with the simplest options in your trial / elimination process before cutting too much safety wire. Always happy to pass on what I've learned here, but far from the level of the masters like Dennis, Jill and Doug.
[quote] On Aug 2, 2016, at 9:52 AM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Ot valve
Posted: Tue Aug 02, 2016 8:30 am Post subject: Snot Valve Not Snotting... |
Remove the snot bottle from the firewall; remove the valve assembly from the bottle and flush it out through all 3 openings with solvent or avgas. When it runs out clean, air dry it out, then reinstall and test the system.
Dennis
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Sent: Tuesday, August 2, 2016 11:30 AM
Subject: Re: Snot Valve Not Snotting...
--> Yak-List message posted by: Rico Jaeger <rocknpilot(at)hotmail.com (rocknpilot(at)hotmail.com)>
| Quote: | From someone who's been down this road so many times they named the street after me...you said the system seems to be operating normally other than the snot valve? So if your gauges are registering air pressure regeneration, the compressor is doing its job. The snot valve can be finicky in that it can easily develop reasons to incompletely close - either from basic wear & tear to needle valve obstructions to just accidentally being left partially open. If this were the case, there could still be enough closure to build pressure but just enough seepage to continuously clear the valve. Whatever the case, ripping the system apart is a pain. The 3' tall line workers with the 11" fingers that built these planes musta smirked every day when pondering we Westerners trying to dig into the many dark nooks & crannies with our sausage digits. I would highly suggest you start with the simplest options in your trial / elimination process before cutting too much safety wire. Always happy!
[quote] On Aug 2, 2016, at 9:52 AM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
Ot valve
ChangDriver
Posted: Wed Sep 07, 2016 6:07 am Post subject: Re: Snot Valve Not Snotting... |
I wound up cleaning and rebuilding the check valve on the compressor and cleaning the snot bottle/valve. The check valve was fine, not sticking and operating fine. However, after removing the bottle and soaking it in gas there was an incredible amount of sludge that came out of it. Once the gas ran clean thru the bottle and out the valve I put it back on and it works perfectly. Something that I should consider doing every other annual or some number of operating hours.
Hope this helps others on the list.
Craig
javiercarrascob
Posted: Wed Sep 07, 2016 6:27 am Post subject: Snot Valve Not Snotting... |
Thanks Craig,
I'd been grounded all this summer due to that issue
Javier
To: yak-list(at)matronics.com
Sent: Wednesday, September 7, 2016 10:07 AM
--> Yak-List message posted by: "ChangDriver" <capav8r(at)gmail.com (capav8r(at)gmail.com)>
Craig
http://forums.matronics.com/viewtopic.php?p=460327#460327
| Quote: | <a href="http://www.matronics.com/Navigator?Yak-List" target="_blabsp; -Matt Dralle, List Admin.<br======
Posted: Wed Sep 07, 2016 8:13 am Post subject: Snot Valve Not Snotting... |
Many people ignore the ant bottle when their airplane has a problem building air pressure. Good idea to flush it out every couple of years.
Dennis
| Quote: | On Sep 7, 2016, at 10:07 AM, ChangDriver <capav8r(at)gmail.com> wrote:
Craig
hkgibby(at)yahoo.com Guest
Posted: Wed Sep 07, 2016 8:44 am Post subject: Snot Valve Not Snotting... |
Highly recommend replacing both deposit filters with swagelok SS valve. It replaces the corrosion prone lower section. Less than $75 each and easy to do. Wish I had known about it 9 years ago cause it can mitigate one of the entry points of corrosion in the pneumatic system. Should be an article about the mod in next Red Alert mag.
I have a PP presentation on the mod I can email to you if you like. Contact me at hkgibby(at)yahoo.com if interested.
Hank
| Quote: | On Sep 7, 2016, at 12:13 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
> Craig
Posted: Wed Sep 07, 2016 12:16 pm Post subject: Snot Valve Not Snotting... |
Apple I-phone auto-corrected "snot" bottle to "ant" bottle. Sorry everyone.
Dennis
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Sent: Wednesday, September 7, 2016 12:13 PM
Subject: Re: Re: Snot Valve Not Snotting...
--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
| Quote: | On Sep 7, 2016, at 10:07 AM, ChangDriver <capav8r(at)gmail.com (capav8r(at)gmail.com)> wrote:
Craig
<br; <a href="http://www.matronics.com/Navigator?Yak-List" target="_blank"= --> <a href="http://www.matronics.com/contribution" target=====
wdjester(at)cox.net Guest
Posted: Wed Sep 07, 2016 12:23 pm Post subject: Snot Valve Not Snotting... |
I was looking in my manual for the ANT bottle. I thought I had missed something.
On Sep 7, 2016, at 3:15 PM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
| Quote: | Apple I-phone auto-corrected "snot" bottle to "ant" bottle. Sorry everyone.
Dennis
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
Dennis
Craig
[/url]
[url=http://www.matronics.com/contribution]
hess737(at)aol.com Guest
Posted: Wed Sep 07, 2016 12:40 pm Post subject: Snot Valve Not Snotting... |
Yeah, it was bugging me too!
Richard HessC 404-964-4885
On Sep 7, 2016, at 4:22 PM, Dave Jester <wdjester(at)cox.net (wdjester(at)cox.net)> wrote:
| Quote: | I was looking in my manual for the ANT bottle. I thought I had missed something.
Dennis
Subject: Re: Yak-List: Re: Snot Valve Not Snotting...
Dennis
Craig
[/url]
Gazoo
Posted: Fri Jan 20, 2017 5:08 pm Post subject: Re: Snot Valve Not Snotting... |
Thanks for posting Craig. I had the same problem. Annual is next week so snot valve cleaning it is.
_________________ Stefan Corriveau
stefancorriveau@hotmail.com |
