pjashura
Posted: Thu Jul 07, 2016 4:45 pm Post subject: Yak-18T Part |
Guys,
I need the pop off valve piston (with the rubber end) for my Yak-18T. It is a slightly smaller diameter than the one for the '52. Any help would be greatly appreciated!
PJ Ashura
_________________ PJ Ashura |
Posted: Thu Jul 07, 2016 6:44 pm Post subject: Yak-18T Part |
I'm not sure this may be the answer because I personally do not know what the 18T pop off valve piston looks like. But it may be the same as the one in the CJ6. Maybe Doug Sapp can post a photo of the pop off valve piston and you can compare it to what yours looks like?
Dennis
To: yak-list(at)matronics.com
Sent: Thursday, July 7, 2016 8:43 PM
Subject: Yak-18T Part
--> Yak-List message posted by: Patrick Ashura <pjsales(at)me.com (pjsales(at)me.com)>
Guys,
PJ Ashurk-List" target="_blank">http://www.matronics.com/Navigator?Yak-Listhttp://forums.mat - NEW MATRONICS LIST WIKI -
_ http://wiki.matro -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
tigeryak18t
Joined: 26 Sep 2009 Posts: 233 Location: PARIS FRANCE
Posted: Thu Jul 07, 2016 10:02 pm Post subject: Yak-18T Part |
You may find it with Dennis or Jill.
Didier Blouzard
+33 6 5184 4802
| Quote: | Le 8 juil. 2016 à 02:43, Patrick Ashura <pjsales(at)me.com> a écrit :
Guys,
PJ Ashura
_________________ Didier Tiger YAK18T
Member of Commemorative Air Force
French Wing |
tigeryak18t
Posted: Thu Jul 07, 2016 10:03 pm Post subject: Yak-18T Part |
I think it may be the same as the 52
Didier Blouzard+33 6 5184 4802
Le 8 juil. 2016 à 04:41, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> a écrit :
| Quote: | I'm not sure this may be the answer because I personally do not know what the 18T pop off valve piston looks like. But it may be the same as the one in the CJ6. Maybe Doug Sapp can post a photo of the pop off valve piston and you can compare it to what yours looks like?
Dennis
From: Patrick Ashura <pjsales(at)me.com (pjsales(at)me.com)>
Guys,
French Wing |
Posted: Fri Jul 08, 2016 2:45 am Post subject: Yak-18T Part |
That's what I was thinking too. But Patrick did say it was a slightly smaller diameter.
Patrick, if you are reading this, maybe you could use your vernier caliper and measure the diameter and height of the piston and post a photo to the list. Possibly someone on the list will be able to answer your question.
Dennis
From: Didier BLOUZARD <didier.blouzard(at)gmail.com>
Sent: Friday, July 8, 2016 2:03 AM
Subject: Re: Yak-18T Part
I think it may be the same as the 52Didier Blouzard+33 6 5184 4802
GeorgeCoy
Posted: Fri Jul 08, 2016 3:25 am Post subject: Yak-18T Part |
It is not the same as the yak 52. We sent him two of the Yak 52 units and they were a larger diameter and he needed.
George coy
On Jul 8, 2016, at 2:03 AM, Didier BLOUZARD <didier.blouzard(at)gmail.com (didier.blouzard(at)gmail.com)> wrote:
| Quote: | I think it may be the same as the 52
Dennis
Guys,
tigeryak18t
Posted: Fri Jul 08, 2016 3:58 am Post subject: Yak-18T Part |
ok sorry about thatthanks Georges that is a god point to know
Didier
2016-07-08 13:24 GMT+02:00 George Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)>:
| Quote: | It is not the same as the yak 52. We sent him two of the Yak 52 units and they were a larger diameter and he needed.
George coy
Didier Blouzard[url=tel:%2B33%206%205184%204802]+33 6 5184 4802[/url]
DennisÂ
Subject: Yak-List: Yak-18T Part
Guys,
____________________________
Didier BLOUZARD
Directeur Général DATEXIS Portable : +33 6 51 84 48 02
Email: didier.blouzard(at)gmail.com (didier.blouzard(at)anolistech.fr)
French Wing |
Posted: Fri Jul 08, 2016 4:02 am Post subject: Yak-18T Part |
He may then have to swap the entire pop off valve cross assembly and attaching check valves for the one used on the CJ because those parts are readily available.
Dennis
Sent: Friday, July 8, 2016 7:24 AM
George coy
heaysr(at)telus.net Guest
Posted: Fri Jul 08, 2016 5:27 am Post subject: Yak-18T Part |
The Yak55 piston for the pop off valve is slightly smaller that for the Yak 52 as supplied by Jill at M14P. I mounted the piston on a wooden dowel and put the dowel in an electric drill as spun the piston walls against emery paper to turn the piston down to size. It works just fine. It's been 8 years now.
Royden Heays
Posted: Fri Jul 08, 2016 6:51 am Post subject: Yak-18T Part |
Now that was a brilliant idea Royden! I mean that sincerely.
//A. Dennis Savarese //
//334-546-8182 (mobile)//
//www.yak-52.com //
//Skype - Yakguy1//
Royden Heays
dougsappllc(at)gmail.com Guest
Posted: Fri Jul 08, 2016 8:09 am Post subject: Yak-18T Part |
The valve plunger inside the CJ pop off valve measures 0.4900 tall (12.45mm) and 0.4680 (11.89mm) dia.
I show 54 in stock, order p/n H2-5502-10 (at)$20.00 each
Best from here,
Doug
On Fri, Jul 8, 2016 at 7:50 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>
//[url=tel:334-546-8182]334-546-8182[/url] (mobile)//
//www.yak-52.com //
//Skype - Yakguy1//
[quote] --> Yak-List message posted by: Heaysr <heaysr(at)telus.net (heaysr(at)telus.net)>
Royden Heays
pjashura
Posted: Fri Jul 08, 2016 11:13 am Post subject: Yak-18T Part |
Great Idea! I may be doing that this weekend.
PJ
[quote] On Jul 8, 2016, at 9:50 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
//www.yak-52.com //
//Skype - Yakguy1//
> Royden Heays
Viperdoc
Posted: Fri Jul 08, 2016 3:36 pm Post subject: Yak-18T Part |
George a Coy is an additional source.
Doc
| Quote: | On Jul 8, 2016, at 1:02 AM, Didier BLOUZARD <didier.blouzard(at)gmail.com> wrote:
Didier Blouzard
+33 6 5184 4802
> Guys,
> PJ Ashura
> Sent from my iPad
_________________ Viperdoc |
Dawg
Posted: Fri Jul 08, 2016 4:09 pm Post subject: Yak-18T Part |
Finally some happy people and news!!
PJ
> //www.yak-52.com //
> //Skype - Yakguy1//
>> Royden Heays
_________________ Dawg |
pjashura
Posted: Sun Jul 10, 2016 6:06 pm Post subject: Yak-18T Part |
Thank you Doug for those measurements. They appear to be what I have from George. This 18T is slightly smaller and I am honing it down now to make it fit. I'll let you all know.
PJ
On Jul 8, 2016, at 10:08 AM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
[quote]The valve plunger inside the CJ pop off valve measures 0.4900 tall (12.45mm) and 0.4680 (11.89mm) dia.
Best from here,
Doug
//www.yak-52.com //
//Skype - Yakguy1//
Royden Heays
pjashura
Posted: Mon Jul 11, 2016 7:28 pm Post subject: Yak-18T Part |
Royden,
Thanks so much for your info on sanding the '52 pop off piston to fit the 18T. Works perfectly!
PJ Ashura
Best from here,
Doug
//www.yak-52.com //
//Skype - Yakguy1//
Royden Heays
Posted: Mon Jul 11, 2016 8:14 pm Post subject: Yak-18T Part |
Hi PJ,
Glad to be able to return some help to the Yak community who have helped me so much over the years.
Royden
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Patrick Ashura
Sent: Monday, July 11, 2016 8:27 PM
Royden,
PJ Ashura
Best from here,
Doug
On Fri, Jul 8, 2016 at 7:50 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:[quote]
//www.yak-52.com //
//Skype - Yakguy1//
On 7/8/2016 9:26 AM, Heaysr wrote:[quote]
Royden Heays
