wright.dennis(at)icloud.c Guest
Posted: Tue Jul 05, 2016 7:39 pm Post subject: Dead battery |
| Quote: | Trying to figure out if I have an issue with my electrical system in my sonex or just bad luck. Have had multiple battery failures. Here's the situation. Battery is an odyssey pc625. , 12 volt. Engine is an Aerovee 2180. First flight was in December 2015. Battery at that time was about 2.5 years old. During the time before first flight had to charge batter several times due to minimal use. After about 5 hrs of flying started experiencing a dead battery. Would charge, fly, and next day battery would be dead again. Figured it was due to age and fact that battery had sat uncharged for prolonged periods. Replaced battery. After about 15 hrs flying time (about 3 months) on new battery, went dead. Tried to charge but would not hold a charge. Had battery tested and showed that it had a bad cell. Replaced battery. After about 25 hrs (about 3 months), another dead battery and will not hold a charge Each time everything is working perfect one day and dead the next. Not blo!
wing any fuses, no smoking wires, system voltage is showing 13.5 volts when I'm flying. Have not checked to see if there is a load on the battery when the battery solenoid is open but do not have anything connected on the battery side of the solenoid so unless the solenoid is bad, shouldn't have any load when off. Would appreciate any thoughts on what the problem might be or where to start to figure it out.
ceengland7(at)gmail.com Guest
Posted: Tue Jul 05, 2016 7:54 pm Post subject: Dead battery |
On 7/5/2016 10:37 PM, Dennis Wright wrote:
> Trying to figure out if I have an issue with my electrical system in my sonex or just bad luck. Have had multiple battery failures. Here's the situation. Battery is an odyssey pc625. , 12 volt. Engine is an Aerovee 2180. First flight was in December 2015. Battery at that time was about 2.5 years old. During the time before first flight had to charge batter several times due to minimal use. After about 5 hrs of flying started experiencing a dead battery. Would charge, fly, and next day battery would be dead again. Figured it was due to age and fact that battery had sat uncharged for prolonged periods. Replaced battery. After about 15 hrs flying time (about 3 months) on new battery, went dead. Tried to charge but would not hold a charge. Had battery tested and showed that it had a bad cell. Replaced battery. After about 25 hrs (about 3 months), another dead battery and will not hold a charge Each time everything is working perfect one day and dead the next. Not b!
lo!
> From: Dennis Wright
13.5v won't charge the battery.
peter(at)sportingaero.com Guest
Posted: Tue Jul 05, 2016 9:56 pm Post subject: Dead battery |
Agree, charging voltage should be more like 14.2 to 14.5 v, especially for an Odessey type battery. On 6 Jul 2016 05:07, "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote: | Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
| Quote: | --> AeroElectric-List message posted by: Dennis Wright <wright.dennis(at)icloud.com (wright.dennis(at)icloud.com)>
| Quote: | Trying to figure out if I have an issue with my electrical system in my sonex or just bad luck. Have had multiple battery failures. Here's the situation. Battery is an odyssey pc625. , 12 volt.  Engine is an Aerovee 2180. First flight was in December 2015. Battery at that time was about 2.5 years old. During the time before first flight had to charge batter several times due to minimal use. After about 5 hrs of flying started experiencing a dead battery. Would charge, fly, and next day battery would be dead again. Figured it was due to age and fact that battery had sat uncharged for prolonged periods. Replaced battery. After about 15 hrs flying time (about 3 months) on new battery, went dead. Tried to charge but would not hold a charge. Had battery tested and showed that it had a bad cell.  Replaced battery. After about 25 hrs (about 3 months), another dead battery and will not hold a charge  Each time everything is working perfect one day and dead the next. Not !
| b!
| Quote: | Â lo!
| Quote: | wing any fuses, no smoking wires, system voltage is showing 13.5 volts when I'm flying. Have not checked to see if there is a load on the battery when the battery solenoid is open but do not have anything connected on the battery side of the solenoid so unless the solenoid is bad, shouldn't have any load when off. Would appreciate any thoughts on what the problem might be or where to start to figure it out.
Posted: Wed Jul 06, 2016 7:16 am Post subject: Dead battery |
And I can confirm, that if your system charging voltage is 13.5, you will kill your battery in amazing short order.
You have to get it up to 14.5 or so. In the mean time, charge it on a proper charger (for AGM Batts) between flights.
Bill "killer of at least 3" Watson
On 7/6/2016 1:53 AM, Peter Pengilly wrote:
www.avast.com
alec(at)alecmyers.com Guest
Posted: Wed Jul 06, 2016 8:50 am Post subject: Dead battery |
Just to add one more datapoint, I'd been running on a charging voltage of 13.2 to 13.4 for three years+ on a Comcorde sealed gel battery - and while it has been sluggish starts for the past three Canadian winters I don't see any evidence that it's damaged, certainly not dead.
On Jul 6, 2016, at 11:15, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
www.avast.com
JohnInReno
Posted: Wed Jul 06, 2016 9:45 am Post subject: Dead battery |
I have a similar problem with an RV4 that I purchased.
Dead battery.
Discovered field wire broken - repaired.
Field wire is jumpered directly to the alternator output. No fuse, cb, or switch.
The alternator appears to be internally regulated.
I am seeing no more than 13.5 volts.
With no load at all on the field wire, is that what is keeping the voltage down?
john
On 7/6/2016 8:15 AM, Bill Watson wrote:
| Quote: | And I can confirm, that if your system charging voltage is 13.5, you will kill your battery in amazing short order.
www.avast.com
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
Posted: Wed Jul 06, 2016 10:29 am Post subject: Dead battery |
On 7/6/2016 1:44 PM, John Morgensen wrote:
Dead battery.
or switch.
voltage down?
Well, charging at 13.5 will kill an Odyssey AGM battery.
I have a regulator and alternator - my regulator is adjustable and
needed to be set to 14.5 to get a normal charge on my Odysseys.
In general, 13.5 is fine for lead acid batteries.
I'm doing this from memory and experience but the place to look is the
spec sheets.
Joined: 28 Mar 2008 Posts: 1954 Location: Riley TWP Michigan
Posted: Wed Jul 06, 2016 1:12 pm Post subject: Re: Dead battery |
JohnInReno,
A bad connection could be causing low voltage. Check both ends of the wire from the alternator "B" terminal. Pull hard on the terminals to make sure they are solid with no corrosion. Also check the engine ground wire. The engine mount should NOT be part of the ground circuit.
_________________ Joe Gores |
Posted: Wed Jul 06, 2016 3:58 pm Post subject: Dead battery |
I have a regulator and alternator - my regulator is adjustable and needed to be set to 14.5 to get a normal charge on my Odysseys.
In general, 13.5 is fine for lead acid batteries. |
It has never been fine for any version of a lead-acid
battery. In fact, low voltage warning systems are
generally calibrated to come on at or below 13.5
volts.
Batteries take on energy at 13.8 and above . . . 14.2
plus/minus 0.2 volts has been the lead-acid legacy
setpoint for 70 years or more. B&C sets their regulators
for 14.5 to 14.6 out the door.
An alternator producing 13.5 will not charge a battery,
but it will keep the battery from becoming discharged . . .
assuming it was charged before flight.
If the aircraft is stored with a charger/maintainer
then the engine gets started by a 100% battery. If the
alternator set-point is only 13.5, then the battery
doesn't get replenished . . . until it gets connected
to the charger while parked. Under THIS scenario, the
battery is happy as a clam and will last a really long
time.
Assuming the battery is never supported externally
for energy replenishment the 13.5v bus won't
top off a battery that has just started the engine.
At the same time, the 13.5v bus runs all the electro-
whizzies just fine.
Starting a well tuned engine only takes 3-5% of
a battery's stored energy. So a topped off battery
can be expected to take you flying for 5-10 times
before you notice that it's getting 'weak'. Whacking
it down over a long period of time without replenishment
eventually produces the "dead battery" syndrome . . .
storing a battery in a low state of charge is hard
on its chemistry . . . no matter what kind of lead
acid battery it is.
We were presented with a 13.5v bus on a 182 a few
days ago on a Canadian ship that was suffering the
effects off high resistance joints and a poorly
adjusted regulator. His "dead battery" symptoms
were predictable . . . AGM . . . Flooded . . .
it doesn't matter.
The charging system needs attention to get the
bus up . . . 14.5v is a good target.
At 12:44 PM 7/6/2016, you wrote:
| Quote: | Dead battery.
The alternator appears to be internally regulated. |
then that is not a 'field' wire . . . it's
a control line that the automotive ECM talks
to for turning the alternator off and on.
| Quote: | I am seeing no more than 13.5 volts.
With no load at all on the field wire, is that what is keeping the voltage down? |
If repairing the CONTROL line did not correct
the problem, then the alternator is broke.
JohnInReno
Posted: Wed Jul 06, 2016 5:22 pm Post subject: Dead battery |
Sorry if I high-jacked the thread. My problem is a lycoming O-320 and it bothers me that there is no fuse, cb, or switch on the control wire going to the alternator.
john
Bob . . . |
RV4 - for sale |
Posted: Wed Jul 06, 2016 5:39 pm Post subject: Dead battery |
At 08:19 PM 7/6/2016, you wrote:
| Quote: | | Sorry if I high-jacked the thread. My problem is a lycoming O-320 and it bothers me that there is no fuse, cb, or switch on the control wire going to the alternator. |
This is an OBAM aircraft? Do you have an
alternator on/off switch . . . either as
a separate device -or- split rocker - etc?
It is functionally sufficient to simply
wire the control lead of an internally
regulated alternator direcdtly to the b-lead
or other always-hot source . . . this simply
causes the alternator to come on line as soon
as the engine starts.
At the same time, you have no control over
the alternator . . . if you turn the battery
switch off, the alternator continues to provide
output. If you experience an ov condition, there's
no provisions for bringing the runaway alternator
to heel.
Posted: Thu Jul 07, 2016 4:24 am Post subject: Re: Dead battery |
Just to emphasize what Bob said, connecting the alternator control wire directly to the "B" terminal is not recommended. The master switch no longer has control over the electrical system. It is not a master switch in this case, but is a battery switch. Shutting off the master switch in flight only disconnects the battery, but does not shut off the electrical system. Everything will keep working. If the electrical system needs to be shut off in an emergency like smoke in the cockpit or a fuel leak or high voltage, the only way to accomplish that is to shut off the engine also. The master switch needs to be placarded, "Inoperative in flight". The solution is to run the alternator control wire to a panel mounted fused switch. Doing that will not only eliminate the above problems, but also allow the voltage regulator to monitor actual system voltage instead of alternator output voltage. They could be different if there is resistance in the alternator wiring. That resistance could result in lower system voltage even though the alternator is putting out 14+ volts.
Posted: Thu Jul 07, 2016 5:11 am Post subject: Dead battery |
On Thu, Jul 7, 2016 at 7:24 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Just to emphasize what Bob said, connecting the alternator control wire directly to the "B" terminal is not recommended. The master switch no longer has control over the electrical system. It is not a master switch in this case, but is a battery switch. Shutting off the master switch in flight only disconnects the battery, but does not shut off the electrical system. Everything will keep working. If the electrical system needs to be shut off in an emergency like smoke in the cockpit or a fuel leak or high voltage, the only way to accomplish that is to shut off the engine also. The master switch needs to be placarded, "Inoperative in flight". The solution is to run the alternator control wire to a panel mounted fused switch. Doing that will not only eliminate the above problems, but also allow the voltage regulator to monitor actual system voltage instead of alternator output voltage. They could be different if there is resistance in the alternator wiring. That resi!
Joe Gores
I think we need to be careful about which kind of alternator we're talking about. IIRC, the post was about an internally regulated ("one wire") alternator. Some older versions require the 'I' terminal to see system voltage for the alternator to start. Some of *that* subgroup will continue operation only with voltage on the 'I' terminal; some will not.Â
But all of the internally regulated alts I've seen need some form of external overvoltage protection (typically a series contactor in the B lead circuit) which implies the ability to control the alt's ability to feed the system. If the contactor control is 'downstream' of the master switch, you get the one-operation shutdown of the system
If the engine is electrically dependent, which is becoming more and more common, even with traditional a/c engines (automotive style ignition & injection), then something more complicated is needed, to be sure the engine electron source can be controlled independently from the airframe.Â
JohnInReno
Posted: Thu Jul 07, 2016 5:38 am Post subject: Dead battery |
Thanks Bob and Joe.
I will dive into the alternator wiring on this plane. I see a "page per
system" in the future.
john
On 7/7/2016 5:24 AM, user9253 wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=457845#457845
RV4 - for sale |
rnjcurtis(at)charter.net Guest
Posted: Thu Jul 07, 2016 7:49 am Post subject: Dead battery |
          I seem to recall a couple of years ago, Bob N. was working on a system
          to safely shut down an internally regulated alternator, and a simple series
          contactor was not the answer.Â
          IIRC he never came up with a good recommendation for a circuit and
          procedure to do this. Am I correct or did I miss the final answer???
          Roger
Posted: Thu Jul 07, 2016 9:22 am Post subject: Dead battery |
At 10:48 AM 7/7/2016, you wrote:
Yes, that idea was predicated on a bit of kerfuffle
over some Van's alternators that eppeared to have
gone belly up after having been switched on/off
using the Figure Z-24 ov manager.
To the best of my knowledge there was no failure
analysis conducted on the damaged units. The
general consensus amongst the best-guessers
was that the alternators were switched under
load . . . perhaps at rpms more than idle and
the subsequent load-dump (automotive parlance
load-dump) zapped the alternators.
Nobody knew the pedigree of Van's offerings.
Further, my visit to MPCA overhaul operations
in San Diego/Tijuana demonstrated that a
righteous/capable overhauler produces parts
immune to such events (see chapter on alternators
in the 'Connection).
The more sophisticated controller was not
pursued as probably unnecessary. Even if
the alternator is not so capably remanufactured,
turning it on/off under load and running faster
than idle is simply not necessary. Hence, Z-24
has not be replaced or updated.
JohnInReno
Posted: Thu Jul 07, 2016 10:24 am Post subject: Dead battery |
A quick test reveals that you are absolutely right. The master switch is
"Inoperative in flight" as long as the engine is running.
I am considering running the control wire through a panel mounted
pullable breaker as a temporary solution.
Joe Gores
RV4 - for sale |
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Thu Jul 07, 2016 11:44 am Post subject: Dead battery |
Roger
So you saying that the Plane-power alternators (as fitted to many RVs) need external over voltage protection
http://www.plane-power.com/pdf/internally%20regulated%20experimental%20alternator%20information.pdf
----x--O--x----
On 7 Jul 2016, at 04:48 pm, Roger <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
Roger
=================================== st">http://www.matronics.com/Navigator?AeroElectric-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
Posted: Thu Jul 07, 2016 11:53 am Post subject: Dead battery |
John,
Which alternator style are you using? If it's internally regulated, let
us know what happens after you install the switch in the 'I' lead. Some
alternators won't start without 12V on the 'I' lead, but will continue
to operate after breaking the 'I' lead connection. Regardless, you still
need positive control over the alternator if it has a regulator 'failed
hot' overvoltage type of failure, and opening the 'I' lead is unlikely
to offer positive protection. (Shorted components in the internal
regulator can keep the alternator 'hot' no matter what you do to control
terminals.)
On 7/7/2016 1:21 PM, John Morgensen wrote:
<john(at)morgensen.com>
is "Inoperative in flight" as long as the engine is running.
> resistance in the alternator wiring. That re!
si!
> Joe Gores
