Hypothetical Battery Contactor Failure
PostPosted: Wed Jun 29, 2016 6:14 am    Post subject: Hypothetical Battery Contactor Failure Reply with quote
While flying, suppose that there is failure in the battery contactor coil circuit and that the alternator continues to function. Will the pilot notice any symptoms prior to engine shutdown? If so, what are they? Thanks.
Joe Gores
skywagon
PostPosted: Wed Jun 29, 2016 8:56 am    Post subject: Hypothetical Battery Contactor Failure Reply with quote
Hmmm. . . . Interesting scenario. . . .
First thought is. . . if one is good at watching steam gauge detail, the
amp/current meter should drop 1-2 amps because the support charge going to
the battery is cut off. Maybe some audio noise may increase in headsets,
etc., since the battery, acting as a huge filter capacitor, is not able to
do its secondary job being cut off via the open contactor. . . .
Dave
racerjerry
PostPosted: Thu Jun 30, 2016 3:42 am    Post subject: Re: Hypothetical Battery Contactor Failure Reply with quote
On a simple aircraft such as my Cessna 172K, the voltage regulator "S" terminal is supplied with power through the battery contactor. If no power is present at the voltage regulator, the alternator field SHOULD not be energized rendering the alternator inoperative. The first noticeable indication after battery voltage bleeds down is that my VHF radio display (KX-155) goes blank.
In order to alert me to take necessary steps to conserve battery power after an alternator failure, I installed a "13V Idiot Light" from Perihelion Design, which I highly recommend. Only $50 and legally installed without paperwork using Velcro and powered through cigar lighter. In addition, I added a Westach 6-16 VDC voltmeter to give me a REAL indication instead of the near worthless ammeter.
Jerry King
PostPosted: Thu Jun 30, 2016 5:13 am    Post subject: Re: Hypothetical Battery Contactor Failure Reply with quote
Once an engine is running above idle, the battery no longer supplies electrical power to the aircraft. The alternator does. Many alternators will continue to operate if the battery is then disconnected. The electrical current needed to power the alternator field comes from the alternator output, whether the battery is connected or not. There may be some alternators that will not continue to run without a battery connected. Even for alternators that do continue to operate without a battery, the alternator could stop working if a very large electrical load is turned on which causes the system voltage to momentarily drop.
Joe Gores
ceengland7(at)gmail.com
PostPosted: Thu Jun 30, 2016 5:26 pm    Post subject: Hypothetical Battery Contactor Failure Reply with quote
On 6/30/2016 4:20 PM, user9253 wrote:
Thanks for the knowledgeable answer. Once your new test bench is up and running, it would be interesting to verify or disprove this statement quoted from the Rotax 912 Installation Manual,
> Never sever connection between terminal C and B of regulator (e.g. by removal of a fuse) while the engine is running. Overvoltage and regulator damage can occur.
I find that statement hard to believe. When voltage is removed from Rotax regulator terminal C, its DC output should shut off, not increase. Of course the AC voltage would increase due to lack of load, but not anymore than if all electrical loads were shut off.
Joe Gores
I don't know squat about Rotax stuff or their manual, but...
If it's a PM style alternator, and the regulator is a shunt style
regulator, and breaking that C-B connection removes the shunt load, then
I can see how the regulator might be damaged. If the regulator
sensing/control semiconductors are still connected to the alternator
output but the shunt *isn't*, then the alternator could well be able to
create a high enough voltage to exceed the max voltage ratings of the
devices.
Having the shunt *in* the circuit would ensure that the voltage never
got that high.
PostPosted: Thu Jun 30, 2016 7:36 pm    Post subject: Re: Hypothetical Battery Contactor Failure Reply with quote
The Rotax (Ducati) rectifier/regulator is a switching-power-supply type of regulator that turns on for part of the dynamo AC cycle. There is no shunt.
Joe Gores
PostPosted: Fri Jul 01, 2016 5:08 am    Post subject: Hypothetical Battery Contactor Failure Reply with quote
No argument on those points, but if the contents of the document are artifacts from 'the bad old days'.....
On Thu, Jun 30, 2016 at 9:11 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
If it's a PM style alternator, and the regulator is a shunt style regulator, and breaking that C-B connection removes the shunt load, then I can see how the regulator might be damaged. If the regulator sensing/control semiconductors are still connected to the alternator output but the shunt *isn't*, then the alternator could well be able to create a high enough voltage to exceed the max voltage ratings of the devices.
  Nobody has built a shunt style regulator in
  a very long time. A few small systems on motor
  bikes and snowmobiles popularized the simple
  design but the B&C regulators have never been
  shunt . . . the alleged schematic of the Ducatti
  R/R is also a series regulator.
  They are manufactured as a spares item but better
  regulators are so easy to design, there's no reason
  to stay with shunt style.
Having the shunt *in* the circuit would ensure that the voltage never got that high.
  but it WOULD drive internal energy dissipation
  to the max and, give the demonstrably poor
  thermal management of many designs, could
  toast the device.  But I'm pretty sure
  nobody builds/offers that control philosophy to
  on the product we're using.
yellowduckduo(at)gmail.co
PostPosted: Fri Jul 01, 2016 8:44 am    Post subject: Hypothetical Battery Contactor Failure Reply with quote
I refrained from commenting on interpretation but I was also stunned to
see Bob (my guru of "get the numbers so we can understand it") use the
word "immeasurably" Wink
just poking fun...
Ken
On 01/07/2016 11:48 AM, erich weaver wrote:
[quote="nuckolls.bob(at)aeroelect"]At 08:13 AM 6/30/2016, you wrote:
> In the mean time, as long
> as you don't hit the alternator with a really BIG load
> (which few system are capable of doing anyhow), the
> modern alternator runs self-excited and benefits immeasurably
> from battery presence with respect to noise.
Just to clarify, did you really mean "benefits immeasurably"? I think maybe the opposite.
Immeasurable: Too large, extensive or extreme to measure.
regards,
Erich
http://forums.matronics.com/viewtopic.php?p=457589#457589
raymondj(at)frontiernet.n
PostPosted: Sun Jul 03, 2016 3:26 pm    Post subject: Hypothetical Battery Contactor Failure Reply with quote
Don't tuck that piece of knowledge away just yet. I believe you usage
was correct.
The following is from my correspondence with my sister. Her
qualifications include a B.A. in English, an M.A. in Library Science and
a career as a technical writer, copy writer, college instructor teaching
creative writing.
First off, "immeasurably" is the adverbial form of the adjective
"immeasurable," so the difference is how they are used in relation to
the other parts of the sentence rather than in their fundamental meanings.
Cutting to the chase, we begin with the OED definition of "immeasurable"
(adjective) which is given as "Not measurable; that cannot be measured;
immense."
This takes us to the definition of "immeasurably" (adverb) which is
given as "To an immeasurable extent or degree; beyond measure;
immensely, vastly."
The essence of the terms in question is to describe things that can't be
measured. This includes things which are too small to be measured as
well as too large to be measured. The terms are also used to describe
things which are too large to be measured.
From a usage stand point I again refer to my sister's correspondence.
.. the phrase "benefits immeasurably" (which indeed uses the correct
form, an adverb modifying the verb 'benefits')...
Bottom line the words "benefits immeasurably" convey the idea correctly
and are used properly from a sentence construction stand point.
Hope this information is useful.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 07/02/2016 08:31 AM, Robert L. Nuckolls, III wrote:
At 10:48 AM 7/1/2016, you wrote:
> <erich.weaver(at)aecom.com>
> maybe the opposite.
I've been thinking that word described an unquantifiable
entity; impossible to express in terms of quantity for any reason.
In fact, I've learned that it refers not to generally unknowable
numbers but only to nebulously large numbers.
I can go to bed tonight knowing something I did not
know this morning . . . it's a good day. Thanks for
the heads-up!
