nickc(at)mtaonline.net Guest
Posted: Mon Jun 06, 2016 11:37 am Post subject: Best way to block end of boom tube? |
Kolbers,
I was intending to block the end of my boom tube with screening, to keep all my fellow summer aviators to from getting suck inside and snacking on me. Sounds like I should reconsider my material choose. What have you used Rick?
Nick Cassara
Palmer, AK
N607AK
victorbravo(at)sbcglobal. Guest
Posted: Mon Jun 06, 2016 11:55 am Post subject: Best way to block end of boom tube? |
For testing, perhaps use a 5 inch diameter foam disposable plate, taped into position with masking tape, and holes poked in the foam for the cables. Then if it works and makes a useful difference you can come up with a more permanent or more attractive solution.
They do make plastic insert plugs for all sizes of "mailing tubes" I think???
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net      - winning proposals for non-profit and for-profit entities
On Mon, 6/6/16, Nick Cassara <nickc(at)mtaonline.net> wrote:
Subject: Best way to block end of boom tube?
Date: Monday, June 6, 2016, 12:36 PM
Kolbers,
Nick Cassara
Palmer, AK
N607AK
Forum -
   - MATRONICS WEB FORUMS -
MATRONICS LIST WIKI -
List Contribution Web Site -
       -Matt
Dralle, List Admin.
neilsenrm(at)gmail.com Guest
Posted: Mon Jun 06, 2016 12:40 pm Post subject: Best way to block end of boom tube? |
Don't use that insulating foam in a can I think it is called "great stuff". It latches on to the control cables in the fuselage tube so hard that you have to almost break the cables to get them to move again. Ask me how I know this...
Rick Neilsen
Redrive VW Powered MKIIIC
On Mon, Jun 6, 2016 at 3:36 PM, Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:
| Quote: | --> Kolb-List message posted by: Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)>
Kolbers,
Nick Cassara
Palmer, AK
N607AK
undoctor(at)rcn.com Guest
Posted: Mon Jun 06, 2016 2:56 pm Post subject: Best way to block end of boom tube? |
I saved the foam from a cushion of a sofa I discarded. Cut a piece a little larger than the diameter of the boom tube, cut slices for the cables and pushed it in the cockpit end. Kept the wind out of my FireFly, stayed in place and didn't interfere with the cables.
Sent from my Verizon Wireless 4G LTE smartphone
Kolbers,
Nick Cassara
Palmer, AK
N607AK
Forum -
-Matt
Dralle, List Admin.
_-============================================================
_-= - The Kolb-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Kolb-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
WhiskeyVictor36(at)aol.co Guest
Posted: Wed Jun 08, 2016 6:21 pm Post subject: Best way to block end of boom tube? |
Lube the cables well in the area of intended foam. Get a buddy to sit in the cockpit and operate the cables until the foam hardens.
Bill Varnes
In a message dated 6/6/2016 4:40:50 P.M. Eastern Daylight Time, neilsenrm(at)gmail.com writes:
| Quote: | Don't use that insulating foam in a can I think it is called "great stuff". It latches on to the control cables in the fuselage tube so hard that you have to almost break the cables to get them to move again. Ask me how I know this...
