mike(at)vision499.com Guest
Posted: Sun Jun 26, 2016 11:06 am Post subject: Nosewheel bearing pre-load |
Hi All,
I have the steerable nosewheel with the bearing pre-load adjusted with
bellville washers. I did not receive any of theses washers with my kit
and on approaching Matco they informed me that they did not supply the
washers and would not recommend this method of pre-load adjustment. The
axle is 3/4 inch and you can see the installation on Bob Reed's site in
the manual section.
Any recommendations on where I go from here?
aeromomentum(at)yahoo.com Guest
Posted: Sun Jun 26, 2016 11:53 am Post subject: Nosewheel bearing pre-load |
McMaster.ComSome Ace hardware stores have them.
From: mike(at)vision499.com <mike(at)vision499.com>;
To: <kis-list(at)matronics.com>;
Subject: Nosewheel bearing pre-load
Sent: Sun, Jun 26, 2016 7:05:11 PM
bakerocb
Posted: Sun Jun 26, 2016 1:26 pm Post subject: Nosewheel bearing pre-load |
6/26/2016
Hello Mike, You wrote:
1) "..... approaching Matco they informed me that they did not supply the
washers and would not recommend this method of pre-load adjustment."
So what did they recommend?
2) "Any recommendations on where I go from here?"
a) Why not go with flat nylon washers instead of the Belleville washers for
your bearing preload?
b) You may be able to obtain washers of the exact dimensions needed from on
line sources such as
http://www.mcmaster.com/#nylon-flat-washers/=130xnsi
or from a good hardware store.
c) If none of those sources work for you it is possible to buy nylon sheet
in various thicknesses:
http://www.mcmaster.com/#standard-nylon-sheets/=130xra3
and with clever use of hole saws and a drill press create just about any
washer ID and OD that
you need.
Please let me know if you have any questions.
OC
PS: This product may be of interest:
http://antisplataero.com/products/nose-wheel-bearing-mod
Sent: Sunday, June 26, 2016 3:05 PM
To: kis-list(at)matronics.com
Hi All,
the manual section.
Posted: Sun Jun 26, 2016 9:02 pm Post subject: Nosewheel bearing pre-load |
Hello OC,
This is the reply that I received from Matco, thanks for you help.
I am not aware of Bellville springs for the axle ever being part of
MATCO
mfg wheels. It was likely something that the HIS folks used. The idea
is
to have preload on the bearings which is reqyired. I'm not sure how
well
that will work.
We have an axle, used on VANS aircraft, that provides the preload and
the
column support of the fork separately. It is shown at:
http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html
http://www.matcomfg.com/WHLAXLE24NoseForkAxleInstallation-idv-3663-23.html
http://www.matcomfg.com/SPACERAXLE24KIT-idv-3681-44.html
This is for a 1.25 inch wheel but it gives you the idea.
On 2016-06-26 23:26, Owen Baker wrote:
6/26/2016
the
washers for your bearing preload?
from on line sources such as
sheet in various thicknesses:
any washer ID and OD that
you need.
OC
Hi All,
the manual section.
jerzy_krasinski(at)sbcglo Guest
Posted: Mon Jun 27, 2016 6:47 am Post subject: Nosewheel bearing pre-load |
Mike,
Also be careful with the direction of bolt/axle for the the wheel..
It can go from the left to right or it can go the other way..
Depending on direction of the bolt it can tighten or loose the bearings in case of jam in one or both of the bearings.
If it tightens it will immobilize the wheel and break back the front gear leg.
Impossible? It happened to my while taxing.. Resulted in broken front gear leg and broken propeller.
If it happened while landing or on take off it would be far worse.
Jerzy
On Monday, June 27, 2016 12:05 AM, "mike(at)vision499.com" <mike(at)vision499.com> wrote:
--> KIS-List message posted by: mike(at)vision499.com (mike(at)vision499.com)
Hello OC,
MATCO
is
well
that will work.
the
| Quote: | --> KIS-List message posted by: "Owen Baker " <bakerocb(at)cox.net (bakerocb(at)cox.net)>
6/26/2016
1) ".... approaching Matco they informed me that they did not supply
the
you need.
OC
From: mike(at)vision499.com (mike(at)vision499.com)
Hi All,
the manual section.
Thmatronics.com/Navigator?KIS-List" target="_blank">http://www.matronics.co= - MATRONICS WEB FORUMS========================http://www.ma======================
