Transponder and ADS Antenna Mounting Location Questions For
billhuntersemail(at)gmail
PostPosted: Sun May 22, 2016 8:57 pm    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
Joe,
This is really valuable information.  Sounds like you know your stuff so if I could kindly pick a bit more of your brain
I am running the SV-XPNDR-260 and it is supposed to be the higher-powered transponder that dynon offers I'm running the dynon ADDB receiver for traffic.
The ideal location for convenience of installation would be to install the monopole antenna directly underneath the Canard.  If I installed it like I am thinking then the monopole antenna would be sticking down from the Cunard and since the Canard is mounted up high in the nose cone of the airplane the antenna would not be sticking out below the bottom of the airplane assuming there's no carbon graphite in that section of the airplane and assuming there's no paint that has some kind of chromate based material then my question is would the antenna be able to still receive the ground-based signals?
To add to my confusion I will also be running a Garmin gtn - 650 and it is supposed to be able to receive ADS-B signals. . Should I purchase an additional monopole antenna for that unit as well or should I just run with the dynon unit?
Subject is way out of my league so any help from you or some of the other sharp guys on this forum would be greatly helpful!
THANKS AGAIN FOR YOUR HELP!!!
Bill Hunter
On May 22, 2016 6:30 PM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Assuming that you are installing the SV-XPNDR-261, why not use the existing transponder antenna?  Since the original transponder worked OK with that egg shaped ground plane, that reinforces my post that shape and size makes a theoretical difference, but is not critical in real life.
  The SV-ADSB-470 antenna is receive only.  It will not affect the operation of ADAHRS or Magnetometer.  Keep the ADSB-470 antenna away from other transmitting antennas, especially the transponder antenna.
  The SV-ADSB-470 receives 978 only, not 1090.  If you are out of range of an ADS-B ground station (maybe in a traffic pattern), you will not see traffic transmitting ADS-B out on 1090, i.e., other SkyView transponders.  Dynon needs to offer a dual band ADS-B receiver.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=456477#456477
WIKI -
Kellym
PostPosted: Mon May 23, 2016 5:25 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
I think you are confusing yourself with too much information. What you
have is the Dynon(Trig) SV-261 transponder, which is the Out unit on
1090-ES. This should be connected to your existing monopole transponder
antenna. Then you have the SV-470 ADS-B Receiver or In unit. It needs
the same variety antenna, but not a ground plane, and can be anywhere
that is at least 2 ft away from your existing transponder antenna.
Do not get confused about the GTN-650. It is a GPS/Nav/Com unit that
does NOT receive any ADS-B or other traffic information on its own. It
is only able to display information received by your transponder or
ADS-B In unit.
I have the same equipment in my RV-10. My transponder antenna is a short
distance behind the firewall on the belly. My ADS-B receiver antenna is
on the belly in the tailcone. I realize with a canard, your convenient
locations are different...just get the distance you need. Under the
Canard should be fine, if you can get the distance and easy mounting.
On 5/22/2016 9:56 PM, William Hunter wrote:
Joe,
Bill Hunter
<mailto:fransew(at)gmail.com>> wrote:
<fransew(at)gmail.com <mailto:fransew(at)gmail.com>>
in real life.
Joe Gores
Electric-List" rel="noreferrer"
target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
Kelly McMullen
KCHD
PostPosted: Mon May 23, 2016 6:38 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
THANKS Kelly!!!
What you have is the Dynon(Trig) SV-261 transponder, which is the Out unit on 1090-ES. This should be connected to your existing monopole transponder antenna.
Yes. My existing monopole antenna is attached to the "corner" (edge) of the existing egg shaped ground plane. I really want to get this ground plane issue squared away (sorry could not resist).
My question is what is the best size and shape for this transponder monopole antenna? The Dynon manuals says 120 MM X 120 MM is minimum and 700 MM X 700 MM is best but way too big for my airplane. Then it says intervals of wave length distance "should be avoided" however what are the intermediate steps that are best and what should be avoided?
Then you have the SV-470 ADS-B Receiver or In unit. It needs the same variety antenna, but not a ground plane, and can be anywhere that is at least 2 ft away from your existing transponder antenna.
Yes. Reading the Dynon manual it says to make sure there is a ground plane
Same question as above... What are the intervals that the ADSB ground plane should be?
130 MM X 130 MM is minimum and their best size is 780 MM X 780 MM but that is too big for my airplane...and intermediate steps are bad so what are the intermediate steps that are best and what should be avoided?
Do not get confused about the GTN-650. It is a GPS/Nav/Com unit that does NOT receive any ADS-B or other traffic information on its own. It is only able to display information received by your transponder or ADS-B In unit.
Good call Kelly...I did not gather that fine point.
THANKS AGAIN!!!!
Cheers!!!
Bill Hunter
Kellym
PostPosted: Mon May 23, 2016 6:47 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
Go with the minimum disk on the receiving antenna and leave the existing
alone, it probably is working and has been tested. If my metric
calculator and decimal point placer are working today, that would be
about a 5" diam alum foil disk. Given the antenna length, probably
double what is actually needed.
On 5/23/2016 7:35 AM, William Hunter wrote:
THANKS Kelly!!!
THANKS AGAIN!!!!
Cheers!!!
Bill Hunter
Kelly McMullen
KCHD
Kellym
PostPosted: Mon May 23, 2016 7:10 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
Well, to some degree that is what experimental is about. Your
transponder will need to be tested on the aircraft to meet the every two
years requirement. That will show whether the signal meets requirements
or not. You are sending around 200-250 watts up to perhaps 100nm for
radar sites, less for ADS-B ground receivers. Compared to your com
transmitter of 8-10 watts.
As for your ADS-B receiver, you still want the antenna to have line of
site view of transmitters, so you want it exposed on the belly, not up
in a wheel well. Is there space right under the canard? Is the canard
removable like on the Long EZ models?
On 5/23/2016 7:57 AM, William Hunter wrote:
Wow…this inherent anal retentive desire I have to “do it right the first
time” is a real pain in the butt!!!
With respect to the ADS-B antenna…I would like to mount it under the
canard essentially in the nose compartment wheel well area…do you
suppose this would work? What size should the aluminum ground plane
be? Disk or square or egg shaped?!?!
Kelly McMullen
KCHD
PostPosted: Mon May 23, 2016 9:40 am    Post subject: Re: Transponder and ADS Antenna Mounting Location Questions Reply with quote
I agree with Kelly. Connect the SV-261 transponder to the existing transponder antenna. If the previous transponder worked with that ground plane, then the new one will too. If you insist on making a new transponder ground plane, then 120 -130 mm square or round will be fine.
As for the ADSB-470 receiver, mount the antenna with or without a ground plane anywhere you want, inside or outside, where it is 2 or more feet away from the transponder antenna. Like Bob said, the signal from the ground station or nearby aircraft will be so strong that a perfect receiving antenna is not required.
Both the SV-261 and the ADSB-470 are ADS-B. One is OUT and one is IN.
Do you also have the SV-GPS-2020?
After your plane is flying with the new system, you can go flying and then request a report from the government to see if your transponder meets 2020 requirements. See this article:
http://macsblog.com/2015/01/the-faa-likes-my-ads-b-out-performance/
Joe Gores
PostPosted: Mon May 23, 2016 10:01 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
Hi all, thank you so much for your help it is greatly appreciated.
I did not get the dynon GPS 2020 because the Garmin has a GPS that is supposed to be 2020 compliant and it is connected to the arinc bus and that communicates all of the magic to the dynon Skyview system and that apparently makes everything legal.
Thanks again for your help!
Bill Hunter On May 23, 2016 10:47 AM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=456505#456505
WIKI -
PostPosted: Tue May 24, 2016 4:57 am    Post subject: Re: Transponder and ADS Antenna Mounting Location Questions Reply with quote
Here is a link to articles written by Bob Archer, including the transponder antenna.
http://www.aeroelectric.com/articles/Antennas/Antennas_for_Aircraft.pdf
He says, "I would not recommend putting the ground plane on the inside with the antenna element extending through the skin of the aircraft."
I assume that means that the fiberglass should not be sandwiched between the mounting nut and the ground plane. The problem with compressing any type of plastic material within an electrical terminal is that plastic will flow over time resulting in loosening of the connection.
Joe Gores
yellowduckduo(at)gmail.co
PostPosted: Tue May 24, 2016 7:27 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
That "problem" might not really be much of an issue.
I have a fibreglass spinner back plate mounted under the prop bolts with
large washers. It's a tractor installation with the back plate forward
of the aluminum prop hub.
To my surprise the bolts do not lose torque even after several hundred
flight hours.
Ken
Joe Gores
http://forums.matronics.com/viewtopic.php?p=456526#456526
PostPosted: Tue May 24, 2016 7:56 am    Post subject: Transponder and ADS Antenna Mounting Location Questions For Reply with quote
Thanks Joe,
My strategy will be to mount the base of the monopo antenna directly to the ground plane sheet and then drill a hole down through the floor for the antenna to stick down through and screw the ground plane to the floor board... then just caulk around the hole.
I shall report my progress.
Bill Hunter
Bill Hunter
+1 408-464-1902 On May 24, 2016 8:34 AM, "C&K" <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: C&K <yellowduckduo(at)gmail.com (yellowduckduo(at)gmail.com)>
I have a fibreglass spinner back plate mounted under the prop bolts with large washers. It's a tractor installation with the back plate forward of the aluminum prop hub.
To my surprise the bolts do not lose torque even after several hundred flight hours.
Ken
Joe Gores
WIKI -
