Question on 912 O-rings
dlj04(at)josephson.com
PostPosted: Sun May 15, 2016 11:39 pm    Post subject: Question on 912 O-rings Reply with quote
There seem to be differing reports on whether you need the
cylinder-to-case o-ring on standard 912UL and ULS. Comments? Are there
recommended alternate sources? Confirmation that they are ordinary
buna-n or Viton? Thanks!
David Josephson
Santa Cruz
Roger Lee
PostPosted: Mon May 16, 2016 5:32 am    Post subject: Re: Question on 912 O-rings Reply with quote
There is an "O" ring at the base of the cylinders. See Parts manual section
72-20-00 pg. 16. Item #14 and part #250510. It is a Viton 87mmx2mm "O" ring. I buy my "O" rings from Maryland Metrics
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
rickofudall
PostPosted: Mon May 16, 2016 3:26 pm    Post subject: Question on 912 O-rings Reply with quote
Get the size from the IPC then look for it at McMaster Carr. They have an extensive supply of differing materials and a good chart to help make a selection.
Rick Girard
On Mon, May 16, 2016 at 2:37 AM, D L Josephson <dlj04(at)josephson.com (dlj04(at)josephson.com)> wrote:
--> RotaxEngines-List message posted by: D L Josephson <dlj04(at)josephson.com (dlj04(at)josephson.com)>
There seem to be differing reports on whether you need the cylinder-to-case o-ring on standard 912UL and ULS. Comments? Are there recommended alternate sources? Confirmation that they are ordinary buna-n or Viton? Thanks!
David Josephson
Santa Cruz
xEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
WIKI -
“Blessed are the cracked, for they shall let in the light.”   Groucho Marx
