budyerly(at)msn.com Guest
Posted: Sat Apr 30, 2016 9:29 am Post subject: Rotax Engine Troubleshooting |
To all,
I did another late night brain dump some months ago. I asked on the forum for some inputs on Rotax Troubleshooting. Well no one else wanted to participate so I figure I’ll start it.
This is a compilation of some of the problems I have seen at my shop and helped handle over the phone or read on the internet over the last 10 years of working with the Rotax.
I would appreciate other inputs. Most of my clients will recognize some of these as will some forum folks. It is in Word format so either add to it or send a separate email off line so as not to clutter the forum.
For those with download problems I am also attaching a .pdf file.
Bud Yerly
 Download |
| Filename: |
Rotax_Engine_Troubleshooting_Yerly_Draft.docx |
62.91 KB |
| Downloaded: |
664 Time(s) |
 Download |
| Filename: |
Rotax_Engine_Troubleshooting_Yerly_Draft.pdf |
320.04 KB |
| Downloaded: |
14567 Time(s) |
Remi Guerner
Posted: Sun May 01, 2016 11:43 am Post subject: Re: Rotax Engine Troubleshooting |
Thank you Bud for your interesting memo on the maintenance of the Rotax. This confirm my personal experience: maintaining these engines is time consuming and becomes very expensive when you have to replace parts, actually a lot more time consuming and significantly more expensive than for any four cylinder Lycoming or Continental.
Remi Guerner
Posted: Sun May 01, 2016 1:19 pm Post subject: Rotax Engine Troubleshooting |
Remi,
If you saw the Lycomings around my EAA Chapter here, I am thankful for my
Rotax. In Florida I am alarmed at how often cylinders are losing
compression at so few hours, and how nasty and oily they are.
I've spent only a few thousand in over 300 hours. But my experiment with
ethanol caused most of it. It is what Gary Leinberger calls "The Dumb Tax".
Boy does that learning curve cost a bunch of money.
Hopefully this will help some folks stop the bleeding of time on the secrets
the Rotax factory does not want to put out. Even the classes are
disappointing to the more experienced guy.
Bud Yerly
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Fri May 06, 2016 6:39 pm Post subject: Re: Rotax Engine Troubleshooting |
It's long after midnight and I can't sleep, so an ideal opportunity to do some uninterrupted email composing. What better than joining in with Bud's initiative? Here are a few thoughts:
When I first installed my current and renovated engine, it proved impossible to get it to run smoothly throughout the rev range, even though the ignition was working well and the carbs were supposedly balanced with a proper balancer. Eventually both were opened and a very rare problem was revealed. One of the sliding "pistons" had above the diaphragm a spring which had lost much of its elasticity. Replacing the springs inside both vacuum chambers completely solved that problem.
In my experience, if you believe that the carbs aren't balanced, then check that both throttle arms which have the cables linking them to the throttle lever are all the way back at their closed positions with the idle screws screwed fully out of the way so as not to be touching the arms. If they are moving exactly together when you start advancing the throttle, then the balance will be nearly correct and only slight adjustment might be needed. This assumes that there aren't other problems like air leaks.
A couple of people including a good friend have sent their little black box ignition control units (solid state) to an address in the Netherlands to be rebuilt seemingly with improved electronic components. It cost my friend about £350 from the UK for both units including delivery etc. He is delighted with the result, claiming that his engine feels much smoother. So no need to throw away your old faulty CDI's.
I would dearly like to see an improvement to the starter sprag clutch to make it last much longer. I think that an average life for this item in the 912S engine of around 500 hours and a replacement cost of over £500 not including labour is a disgrace!
There was a slight weep of oil from two of the cylinder head rocker covers, so I took out the O-rings and boiled them in water for 15 minutes. After replacing them the leak was only a little less, so I ordered a new set of O-rings. These were no better so I wonder what to do next.
A large difference in the "mag" drops was solved by raising the needles in the carburettors one notch to make the mixture ritcher. Now there is almost no difference to be seen, which ties in well with my experience on another large radial-engined aircraft having a cockpit mixture control.
Someone else was using waterless coolant and didn't like it, so I've always used 50/50 glycol/water with the higher pressure radiator cap and found no undue problems with cooling. Having said that, it's a good idea to ensure that the oil cooler gets the full intended airflow through it and that air can't escape through poor ducting which would allow it to bypass the cooler.
In my experience excellent propeller balancing can be achieved by balancing the whole propeller hub/blades/spinner assembly together off the aircraft using a static balancer.
Off to bed now.
pete(at)lawless.info Guest
Posted: Fri May 06, 2016 10:13 pm Post subject: Rotax Engine Troubleshooting |
Hi Jonathan
You don't happen to know what the "address in the Netherlands" is do you?
Pete
G-RMAC Classic #109
On 07/05/16 03:39, jonathanmilbank wrote:
| Quote: | | Quote: | --> Europa-List message posted by: "jonathanmilbank" <jdmilbank(at)yahoo.co.uk> (jdmilbank(at)yahoo.co.uk)
nigel_graham(at)m-tecque. Guest
Posted: Fri May 06, 2016 11:14 pm Post subject: Rotax Engine Troubleshooting |
Pete,
Jonathan is probably still asleep as he didn't get to bed till so late so I hope he doesn't mind me jumping in.
The company is "Carmo"
Rooseinndestraat 54a
5705BV
Helmond
Netherlands
[url=Tel:+31]Tel:+31[/url] 492 565 220
Contact is Kevin ( kevin(at)carmo.nl (kevin(at)carmo.nl) )
Web: https://www.carmo.nl/index.php?main_page=about_us&zenid=2ehjm35bincu889agim2s56jt0
I've not heard a bad thing about them - good prices and very fast turn-around.
Nigel
On 07/05/2016 07:12, Pete Lawless wrote:
Hi Jonathan
Pete
G-RMAC Classic #109
Posted: Fri May 06, 2016 11:33 pm Post subject: Rotax Engine Troubleshooting |
Thanks. It's not happened yet but it must be due soon.
Pete
On 07/05/16 08:13, nigel_graham(at)m-tecque.co.uk (nigel_graham(at)m-tecque.co.uk) wrote:
Pete,
5705BV
Helmond
Netherlands
Nigel
Hi Jonathan
Pete
G-RMAC Classic #109
JonathanMilbank
Posted: Sat May 07, 2016 1:38 am Post subject: Re: Rotax Engine Troubleshooting |
Hi Pete,
This is the contact info given by my friend
https://www.carmo.nl/index.php?main_page=index&cPath=671_2711_4731
However what you were given above may possibly be more correct or up-to-date.
Jonathan
Posted: Sat May 07, 2016 4:01 am Post subject: Rotax Engine Troubleshooting |
Thanks Jonathan
Always good to have alternatives to the ridiculous prices now being
charged by Rotax.
Pete
