jbsoar(at)gmail.com Guest
Posted: Tue Apr 26, 2016 12:45 am Post subject: Yak 55 Russian tailwheel... Revisited... |
Fellow Listers-Who has had good luck with the original Russian tailwheel tire and tube? I'm thinking of trying the original set-up.
Are new tires and tubes available? From where? Do they hold air? Russian, or are they from somewhere else?
Thank you!
John B
dougsappllc(at)gmail.com Guest
Posted: Tue Apr 26, 2016 8:35 am Post subject: Yak 55 Russian tailwheel... Revisited... |
I have a mystery tail wheel here, I have no clue as to it's origin or application, but think it might be Russian. It is NOS in perfect condition.
The OD of the rim is 128.62mm
One rim has 156, the other 141 stamped on it
Rim halves are serrated to prevent tire from spinning on the rim.
Side to side the wheel is 129.11mm wide
The bearing ID (axle size) is about 19.09mm
Bearing has the number 7604 on it
Anyone out there know it's application??
Best,
Doug
On Tue, Apr 26, 2016 at 1:44 AM, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
| Quote: | Fellow Listers-Who has had good luck with the original Russian tailwheel tire and tube? I'm thinking of trying the original set-up.
Thank you!
John B
51.01 KB |
2189 Time(s) |
