Posted: Wed Apr 13, 2016 3:47 pm Post subject: Level flight position |
Guys
I am installing the magnetometer before having installed the gear legs or the wheels.
Is it correct to assume that, in the RV-10, leveling the Mid cabin decks (those 2 mid-fuselage surfaces below the doors bottoms) does correspond to a 0 degree pitch attitude n flight?
Carlos
Enviado do meu iPhone
jdriggs49(at)MSN.COM Guest
Posted: Wed Apr 13, 2016 5:45 pm Post subject: Level flight position |
Yes
Put a level on them and also laterally across the cockpit
| Quote: | On Apr 13, 2016, at 4:53 PM, Carlos Trigo <trigo(at)mail.telepac.pt> wrote:
Guys
Carlos
glastar(at)gmx.net Guest
Posted: Thu Apr 14, 2016 12:44 am Post subject: Level flight position |
So with what sytem did you settle at the end and what did you buy?
Cheers
Werner
> Guys
> Thanks
> Carlos
Posted: Fri Apr 15, 2016 9:08 am Post subject: Level flight position |
Hi Werner
There were other than technical reasons to choose the GARMIN G3X.
I bought all the G3X parts necessary for the "internal" installation, so I will buy later the Displays and the Autopilot panel.
Cheers
Carlos
No dia 14/04/2016, às 09:43, Werner Schneider <glastar(at)gmx.net> escreveu:
Cheers
Werner
>> Guys
>> Thanks
>> Carlos
