Fuel System Schematic for M14 engines.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
Cliff.Coy
PostPosted: Mon Jan 18, 2010 12:22 pm    Post subject: Fuel System Schematic for M14 engines. Reply with quote
Good afternoon all,
I've attached a schematic for the M14 series engine.
If there are any questions, feel free to give me a shout!
Best regards,
Cliff
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
FUEL_SYSTEM_SCHEMATIC.pdf
 Filename:  FUEL_SYSTEM_SCHEMATIC.pdf
 Filesize:  19.79 KB
 Downloaded:  1206 Time(s)
n223rv(at)wolflakeairport
PostPosted: Mon Jan 18, 2010 5:22 pm    Post subject: Fuel System Schematic for M14 engines. Reply with quote
One question, why would you not put the electric fuel pump inline with the mechanical fuel pump? Inline is typically what the RV guys are doing with Lycoming engines.....
-Mike
On Jan 18, 2010, at 3:10 PM, Cliff Coy <[url=mailto:cliff.coy(at)gmail.com]cliff.coy(at)gmail.com (cliff.coy(at)gmail.com)[/url]> wrote:
Good afternoon all,
Best regards,
Cliff
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
<FUEL SYSTEM SCHEMATIC.pdf>
HBaker
PostPosted: Sun Mar 06, 2016 7:28 am    Post subject: Re: Fuel System Schematic for M14 engines. Reply with quote
Hello Cliff
We have purchased the Airflow Performance Fuel injection for the moose and they recommend the debubbler to prevent vapour lock . Their kit came with an electric fuel pump and it has the check valve built in with it , it runs on 35-45 psi. I like the way you done it with the gasolator, Do you think it will still work with the increased fuel pressure , or if I'll need a restrictor in the return line . I would prefer to go your way If you could help me.
Thanks Henry
Currently building a Murphy Moose - any help would be appreciated.
HBaker
PostPosted: Wed Mar 09, 2016 3:13 pm    Post subject: Re: Fuel System Schematic for M14 engines. Reply with quote
Because the debubbler is on the pressure side of the pumps do I need anything on the vent line? example ; restrictor valve or anything? What would stop the fuel from flowing through on the 1\4 ' vent back up in the tank, Wouldn't this prevent her from reaching full fuel pressure ?
Could you please clear this up for me?
Thanks again
Henry
GeorgeCoy
PostPosted: Thu Mar 10, 2016 6:51 am    Post subject: Fuel System Schematic for M14 engines. Reply with quote
Yes, usually a .040 hole in the line. Take a steel fitting , fill it with
solder and drill a hole.
George
HBaker
PostPosted: Fri Mar 11, 2016 3:24 pm    Post subject: Re: Fuel System Schematic for M14 engines. Reply with quote
Thanks for your help George as always.
Henry
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
