				 Posted: Fri Feb 07, 2020 1:21 pm    Post subject: Are Huosai magnetos "handed"? |
				Mags are interchangeable left to right/right to left.
 Check the high voltage stick for arcing On the sides. This will cause the mag to become inop. Do this b4 you replace the entire mag.
 Dennis
  	  | Quote: | 	 		   On Feb 7, 2020, at 3:27 PM, jay-dub <flyjnw(at)gmail.com> wrote:
  I've just had mag failure (number 1) and have managed to source a replacement if necessary. I haven't had chance to diagnose yet so it may just be a short but if it does require replacement, are Huosai mags handed? As in are mag 1 and mag 2 the same or different? The answer determines the next steps.
  Thanks.
  CJ and Yak-52 owner
  http://forums.matronics.com/viewtopic.php?p=494698#494698
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Feb 07, 2020 1:57 pm    Post subject: Are Huosai magnetos "handed"? |
				Also make sure the points are opening and closing. If the points don’t open, the mag will be dead.
 Dennis
  	  | Quote: | 	 		   On Feb 7, 2020, at 4:22 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
  Dennis
 > Thanks.
 > CJ and Yak-52 owner
		jay-dub
				 Posted: Sun Feb 09, 2020 1:51 am    Post subject: Re: Are Huosai magnetos |
				Thanks Dennis, we will do that. The aircraft is stranded away from base so we want to have parts in place if required to avoid doing multiple journeys.
  _________________ CJ owner |
