jan.mevis(at)informavia.b Guest
Posted: Wed Apr 13, 2016 10:11 am Post subject: yak 52 towing equipment |
Each year I have the impression that our 52 is getting heavier and more difficult to handle on the ground…
So I’m looking for a good towing solution.
Before trying to reinvent the wheel, I suppose that there are Yak or Nanchang owners on the list that already found a good, workable solution?
BR,
Jan
Dawg
Posted: Wed Apr 13, 2016 10:40 am Post subject: yak 52 towing equipment |
F-350 Ford Dually diesel with optional towing package
Sent from my Samsung Galaxy smartphone.
-------- Original message --------
Date:04/13/2016 12:09 (GMT-07:00)
To: yak-list(at)matronics.com
Cc:
Subject: Yak-List: yak 52 towing equipment
BR,
Jan
_________________ Dawg |
fishmouth500
Joined: 07 Apr 2015 Posts: 43 Location: Southern California
Posted: Wed Apr 13, 2016 10:43 am Post subject: yak 52 towing equipment |
[img]cid:ii_15410ee8846bfb3b[/img]full disclosure...I'm his CAD guy....Very happy with it. No straining your gut over hangar rails etc etc
Contact Lin Kastan at Redline Aviation [url=tel:619%20992-0892]619 992-0892[/url]
On Wed, Apr 13, 2016 at 11:09 AM, Jan Mevis <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)> wrote:
| Quote: | Each year I have the impression that our 52 is getting heavier and more difficult to handle on the ground…
BR,
Jan
833.66 KB |
11955 Time(s) |
jblake207(at)comcast.net Guest
Posted: Wed Apr 13, 2016 11:33 am Post subject: yak 52 towing equipment |
Here's the cheapest ($99) solution that works great for my CJ and other airplanes...
http://www.sportys.com/pilotshop/universal-aircraft-towbar.html?___SID=U
I modified the hitch from the simple drop pin by adding a trailer hitch coupler from Harbor Freight for $12 that way I can tow the airplane with my truck or golf cart.
JB
Sent: Wednesday, April 13, 2016 1:09:52 PM
Subject: yak 52 towing equipment
BR,
Jan
Posted: Wed Apr 13, 2016 11:37 am Post subject: yak 52 towing equipment |
A golf cart works well and serves two purposes. Moving the Yak in and out of the hangar and ground transportation on the airport.
Dennis
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Sent: Wednesday, April 13, 2016 2:09 PM
BR,
Jan
Dawg
Posted: Wed Apr 13, 2016 11:42 am Post subject: yak 52 towing equipment |
All our 52s came with little Romanians that are voice activated; Stop, Go, Push, Pull. Where did you get yours?
On Apr 13, 2016, at 13:31, jblake207(at)comcast.net (jblake207(at)comcast.net) wrote:
| Quote: | Here's the cheapest ($99) solution that works great for my CJ and other airplanes...
JB
From: "Jan Mevis" <jan.mevis(at)informavia.be (jan.mevis(at)informavia.be)>
BR,
Jan
markdavis(at)wbsnet.org Guest
Posted: Wed Apr 13, 2016 1:32 pm Post subject: yak 52 towing equipment |
I use the same tow bar from Sporty's and added a 2" hitch to it I attach with 1/4" bolts and wing nuts when needed. Works well as a simple tiller when pushing/pulling by hand. Keep an eye on it, the sliding bar for tension has worked itself somewhat loose several times after the paint wore off in the sweet spot. I normally give it a good kick if I'm pulling it with a vehicle to set the tension tight.
Mark Davis
N44YK
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of jblake207(at)comcast.net
Sent: Wednesday, April 13, 2016 1:32 PM
To: Yak-List
Subject: Re: yak 52 towing equipment
JB
BR,
Jan
Posted: Wed Apr 13, 2016 1:43 pm Post subject: yak 52 towing equipment |
Mark, since I use it mostly for my CJ, I drilled a small hole in one side and have a small safety pin (came of an old OV-1 Mohawk ejection seat) to prevent the slippage you mentioned. In fact, I drilled two holes one for the CJ and the other was for my Arrow... Don't think it degrades the integral structure any. Maybe I should have thought of the Kick technique you mentioned...
Sent: Wednesday, April 13, 2016 4:31:24 PM
Subject: RE: yak 52 towing equipment
Mark Davis
N44YK
To: Yak-List
JB
BR,
Jan
cjpilot710(at)aol.com Guest
Posted: Wed Apr 13, 2016 1:59 pm Post subject: yak 52 towing equipment |
I have a Minimax Aircraft Tug. See their site below. Made in the US. Guaranteed for life. Very well built. Works great on my CJ. A Yak may need a different setup but I understand he has already designed and shipped a number. Fantastic support. Mine was the first he had to build for the CJ-6, so I'm sure there was engineering costs in it ($1,500). At 76 the airplane is heavy as hell - - I know what you mean.
https://www.minimaxtugs.com/Articles.asp?ID=251
Jim "Pappy" Goolsby
In a message dated 4/13/2016 2:11:34 P.M. Eastern Daylight Time, jan.mevis(at)informavia.be writes:
BR,
Jan
Viperdoc
Posted: Wed Apr 13, 2016 4:24 pm Post subject: yak 52 towing equipment |
This is what I use.
Doc
40 EZ[img]http://www.powertow.com/thumbnail.asp?file=assets/images/40ez%20clipped%20product%20page.jpg&maxx=62&maxy=0[/img][img]http://www.powertow.com/thumbnail.asp?file=assets/images/55%20BARON%20HOOKUP.JPG&maxx=62&maxy=0[/img][img]http://www.powertow.com/thumbnail.asp?file=assets/images/catalogpictures/Scott%20Hook-Up%20Kit.JPG&maxx=62&maxy=0[/img][img]http://www.powertow.com/thumbnail.asp?file=assets/images/catalogpictures/Cessna%20Pants%20Hook-Up.JPG&maxx=62&maxy=0[/img]
40 EZ Aircraft Tug from Power Tow.
On Apr 13, 2016, at 2:31 PM, jblake207(at)comcast.net (jblake207(at)comcast.net) wrote:
JB
BR,
Jan
_________________ Viperdoc |
hess737(at)aol.com Guest
Posted: Wed Apr 13, 2016 4:27 pm Post subject: yak 52 towing equipment |
I use the same
Richard HessC 404-964-4885
On Apr 13, 2016, at 8:23 PM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
Viperdoc
Posted: Wed Apr 13, 2016 4:47 pm Post subject: yak 52 towing equipment |
My little 3 ft RU with 12 in. Fingers that came with my YAK escaped from the container at the POE facility in 2003. Supposedly it happened when customs opened the container for inspection in Charleston. I have my suspicions though. After all how could Big Dog have gotten his big self up in the tail of his 52 to change the cable guide for the upper elevator cable? I know he claims it was Bull Dog that climbed back in empennage but that's impossible, BD is 2 feet taller than that midget Russian and his fingers are only 6 inches long or so his wife claims. I personally have not measured. But, if you see that little bugger running around in YAK tails at the Aiken airport let me know.
Doc
On Apr 13, 2016, at 2:42 PM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
| Quote: | All our 52s came with little Romanians that are voice activated; Stop, Go, Push, Pull. Where did you get yours?
JB
BR,
Jan
Viperdoc
Posted: Wed Apr 13, 2016 4:56 pm Post subject: yak 52 towing equipment |
You know Mark there are not many things that can't be fixed with a good kick. I tell you though, my wife is not one of them.
Doc
On Apr 13, 2016, at 4:31 PM, Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)> wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Mark Davis
N44YK
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of jblake207(at)comcast.net (jblake207(at)comcast.net)
To: Yak-List
JB
BR,
Jan
Viperdoc
Posted: Wed Apr 13, 2016 5:01 pm Post subject: yak 52 towing equipment |
Mongoose,
Just discovered they make replacement kits for them to include the frame.
Doc
On Apr 13, 2016, at 7:26 PM, Richard Hess <hess737(at)aol.com (hess737(at)aol.com)> wrote:
| Quote: | I use the same
kendal(at)acronut.com Guest
Posted: Wed Apr 13, 2016 5:06 pm Post subject: yak 52 towing equipment |
Still talking about the wife???
On Apr 13, 2016, at 21:01, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
| Quote: | Mongoose,
Doc
Posted: Wed Apr 13, 2016 6:02 pm Post subject: yak 52 towing equipment |
Doc, I fixed a catapult tow link on a Prowler with a good swift kick one night to go on a night training strike on Carl Vinson. Told the tweaks it needed adjusted and they didn't believe me until they checked it after my "adjustment". Still have a large calcium deposit on top of my foot for proof. Made the flight. Boot was a little tight when I took it off after I trapped.
Mark Davis
N44YK
On Apr 13, 2016, at 6:56 PM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
| Quote: | You know Mark there are not many things that can't be fixed with a good kick. I tell you though, my wife is not one of them.
Doc
Mark Davis
N44YK
To: Yak-List
JB
BR,
Jan
Viperdoc
Posted: Wed Apr 13, 2016 6:26 pm Post subject: yak 52 towing equipment |
Gotta admit that was using the heel bone. Getting to old and brittle to be kicking immovable things like that. Hammers have to work now. Have not met a cannon ball my son could not dismantle with a ball pin.
Doc
On Apr 13, 2016, at 9:01 PM, Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)> wrote:
| Quote: | Doc, I fixed a catapult tow link on a Prowler with a good swift kick one night to go on a night training strike on Carl Vinson. Told the tweaks it needed adjusted and they didn't believe me until they checked it after my "adjustment". Still have a large calcium deposit on top of my foot for proof. Made the flight. Boot was a little tight when I took it off after I trapped.
Mark Davis
N44YK
Doc
Mark Davis
N44YK
To: Yak-List
JB
BR,
Jan
Posted: Wed Apr 13, 2016 7:54 pm Post subject: yak 52 towing equipment |
Thanks! This looks quite nice!
BR,
Jan
From: <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of John Warwick <john.warwick1(at)gmail.com (john.warwick1(at)gmail.com)>
Reply-To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Date: Wednesday 13 April 2016 at 20:42
BR,
Jan
833.66 KB |
11935 Time(s) |
Thanks for sharing!
Jan
From: <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
Date: Thursday 14 April 2016 at 02:23
This is what I use.
Doc
JB
BR,
Jan
