Wiring schedule?
clivesutton
PostPosted: Sun Apr 10, 2016 3:17 am    Post subject: Wiring schedule? Reply with quote
Hi,
Does anyone have a Europa wiring schedule based on the manual electrical layout but replicated in package like ExpressSCH or DesignSpark Electrical (or any other wiring schedule type package)? I'm ready to pay . . .
I realise every a/c has a bespoke electric and instrumentation configuration, but access to such a layout would be an excellent starting point and save me considerable time in generating a new one that will be adapted for my a/c - as well as for creating some electrical documentation that reflects what is actually installed in the a/c.
I can't be the first person to do this . . .
rowlandcarson(at)gmail.co
PostPosted: Sun Apr 10, 2016 5:27 am    Post subject: Wiring schedule? Reply with quote
On 2016-04-10, at 12:17, Clive Sutton <clive.maf(at)googlemail.com> wrote:
Hi, does anyone have a Europa wiring schedule based on the manual electical layout but in a layout package like ExpressSCH or DesignSpark Electrical (or any other package)? I'm ready to pay for it . . .
Clive - I’m not quite sure what you mean by a wiring schedule, and I’ve never heard of the tools you mention, but I wonder if either of the documents you can find at:
http://www.rowlandcarson.org.uk/aviation/europa_435/wirebook.php
would be helpful to you. These are PDF documents, but I imagine you would want to edit them for your own use, so would need the source files from which they were produced.
I made the wiring diagrams in the CAD application CADintosh (Mac-only); they can be exported as .DXF which should be readable by most drawing applications. (NB DXF does not support all entities that can be created in CADintosh so there could be some differences in appearance.) CADintosh can also export IGES and HPGL but I suspect those formats are less likely to be of use in your context.
I made the list of wires in FileMaker Pro (runs on Mac & Windows); if you don’t have FMP, I can make an export from it in tab-text, CSV, DBF, merge, HTML table, XML (specify your .XSL stylesheet) or .xlsx spreadsheet format.
Hope this goes some way to answering your question, but please get back to me if you need more info.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
clivesutton
PostPosted: Sun Apr 10, 2016 5:54 am    Post subject: Re: Wiring schedule? Reply with quote
Hi Rowland,
Thanks for your prompt reply and info.
By schedule i mean the kind of wiring diagram one would find in your Haynes Manual for your car - a graphic depicting the wiring layout rather than lists (though they are fine of course).
ExpressSCH (http://www.expresspcb.com/expresssch) and DesignSpark electrical (http://www.rs-online.com/designspark/automation/designspark-electrical) are CAD-based tools one would use to create these layouts.
What i am after is a layout in one of these (or other similar free package tools) as a starting point based upon the generic electrical layut in the manual - that i could then extend.
If the list you linked for me has a CAD/DXF or other format data file that shows the layout/connections etc, that could really help me.
regards,
Clive
Burrilla
PostPosted: Sun Apr 10, 2016 6:02 am    Post subject: Wiring schedule? Reply with quote
What about the one in the build manual. That covers all the basics and gas a similar layout to the car type your speaking off.
Alan
G-OBJT
On 10 Apr 2016, at 14:54, Clive Sutton <clive.maf(at)googlemail.com> wrote:
Hi Rowland,
regards,
Clive
http://forums.matronics.com/viewtopic.php?p=454777#454777
clivesutton
PostPosted: Sun Apr 10, 2016 6:11 am    Post subject: Re: Wiring schedule? Reply with quote
Hello Alan,
The reason for my ask is that the schematic in the manual is generic, only in paper format and not specific to my aircraft. When it is finished i want to have a set of documents that give the precise detail of how it is wired up.
Clive
PostPosted: Sun Apr 10, 2016 7:14 am    Post subject: Wiring schedule? Reply with quote
Clive - have a look at the PDF wirebook at the URL I posted and let me know which pages you’d like as DXF files.
in friendship
Rowland
clivesutton
PostPosted: Sun Apr 10, 2016 7:37 am    Post subject: Re: Wiring schedule? Reply with quote
Hi Rowland,
Could you email me your first page and i can see how that loads/looks like?
Unfortunately i can't seem to see to view whole wirebook PDF - it starts but then hangs on my PC.
My email is clive.maf(at)googlemail.com
thanks in anticipation
Clive.
PostPosted: Sun Apr 10, 2016 9:55 am    Post subject: Wiring schedule? Reply with quote
Please can anyone else having trouble seeing or downloading the PDF of the wirebook on my website build journal at:
contact me direct at rowlandcarson(at)gmail.com.
I’d like to know if there’s something I need to fix for the majority of viewers or if Clive’s is an isolated problem.
in friendship
Rowland
Burrilla
PostPosted: Sun Apr 10, 2016 10:01 am    Post subject: Wiring schedule? Reply with quote
Rowland just tried on the `MAC and it hangs here as well. No download.
Alan
in friendship
Rowland
rlborger(at)mac.com
PostPosted: Sun Apr 10, 2016 10:09 am    Post subject: Wiring schedule? Reply with quote
Rowland,
I tried to download both PDFs shown on the page and neither one would download.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Apr 10, 2016, at 12:54 PM, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
Paul M 383
PostPosted: Mon Apr 11, 2016 4:21 am    Post subject: Wiring schedule? Reply with quote
Works fine for me - PC, Windows 7 Pro, Chrome, Adobe Pro.
Result attaché.
Rgds,
Paul M
Kit 383
XS Mono 912S
wire_list.pdf
 Filename:  wire_list.pdf
 Filesize:  189.16 KB
 Downloaded:  526 Time(s)
PostPosted: Mon Apr 11, 2016 7:06 am    Post subject: Wiring schedule? Reply with quote
Clive, and all those who responded - thanks for your time and trouble, and I’m sorry I gave you such bother! It’s working fine today, but when I tried that page myself yesterday it took forever to download. Several other pages of the website were extremely slow to respond, and I couldn’t even get ftp access to it at one point. It appears that it was a temporary problem at my hosting company (although another site they host was not affected).
It seems it was just bad luck that the site had a problem at the very time when I pointed Clive to it. I do apologise for all the fuss!
in friendship
Rowland
rlborger(at)mac.com
PostPosted: Mon Apr 11, 2016 8:09 am    Post subject: Wiring schedule? Reply with quote
Rowland,
Downloaded to my Mac this morning. Works just fine!
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Apr 11, 2016, at 10:05 AM, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
