GeoB
Posted: Thu Mar 31, 2016 12:13 am Post subject: Kinked vent tube |
| Quote: | but on one side the tube had kinked. I asked for a bit of safetywire.
I have had troublesome plastic tubing in other situations. Sometimes it
works well to insert a spring.
_________________ GeoB
"Members of Congress should be compelled to wear uniforms like NASCAR drivers, so we could identify their corporate sponsors" |
byoungplumbing(at)gmail.c Guest
Posted: Thu Mar 31, 2016 6:33 am Post subject: Kinked vent tube |
That was my thought as well. I tried a spring from a pen, but it was to large to go in. Maybe I could have found a smaller one. I suppose it could have been wrapped it on the outside of the tube. Or A small wire instead of the spring wrapped on the outside would do as well. What I've ended up with is a tube , same quarter inch od. But the ID. Is about 15 thousands smaller. The heavier wall is less likely to kink, as seen in side by side comparison. Who knows what time, heat, vibration, fuel vapors, etc will do.
Boyd y
354.27 KB |
4800 Time(s) |
Richard Pike
Posted: Sat Apr 02, 2016 11:46 am Post subject: Re: Kinked vent tube |
I have tried to eliminate plastic tubing from my airplane to the extent possible; it is incredibly unreliable. For those places where it does not seem possible to eliminate it, and all you want is a vent, how about something like this in 1/8 OD inside your plastic tubing instead of a spring? At 18 cents a foot, you have nothing to lose...
http://www.aircraftspruce.com/catalog/appages/nylaflow.php?clickkey=8311
Or this?
http://www.aircraftspruce.com/catalog/appages/nyloseal.php?recfer=5272
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sat Apr 02, 2016 3:16 pm Post subject: Kinked vent tube |
If the stock tubing is installed correctly, it normally doesn't crimp, but
Nyloflow tubing would certainly keep it from it.
_________________ John Hauck
Titus, Alabama |
