danbooker
Posted: Wed Mar 23, 2016 4:18 pm Post subject: Start button, then whoosh |
When pushing start button, all I got was whoosh of air and no propeller movement. Heard air leaking, I think from behind dash. Any ideas?
_________________ Daniel Booker
"Stealth-Eagle Aviation"
2312457798
danbooker@hotmail.com |
Ernie
Posted: Wed Mar 23, 2016 4:31 pm Post subject: Start button, then whoosh |
Pull the prop through a few blades and try again.
Ernie
On Wednesday, March 23, 2016, danbooker <danbooker(at)hotmail.com (danbooker(at)hotmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "danbooker" <[url=javascript:;]danbooker(at)hotmail.com[/url]>
Daniel Booker
2312457798
http://forums.matronics.com/viewtopic.php?p=454055#454055
br> fts!)
r> > w.buildersbooks.com" target="_blank">www.buildersbooks.com
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
Viperdoc
Posted: Wed Mar 23, 2016 4:45 pm Post subject: Start button, then whoosh |
Air start valve is tits. Get a new one from Doug Sapp. It is on the inside firewall at about the level of your left big toe. If you have a YAK. 52. A pain in the ass to change.
Doc
_________________ Viperdoc |
Viperdoc
Posted: Wed Mar 23, 2016 4:51 pm Post subject: Start button, then whoosh |
Agree with Ernie. But if you heard the rush of air on pressing the start button the air start is failing. Did you hear a pop when the air start was engaged? If not the solenoid is failing.
Doc
On Mar 23, 2016, at 7:27 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | Pull the prop through a few blades and try again.
Ernie
hkgibby(at)yahoo.com Guest
Posted: Wed Mar 23, 2016 4:53 pm Post subject: Start button, then whoosh |
Could be a blown air distributor check valve located on the compression cylinder; I had one so corroded it broke in half and was hanging on by the safety wire. There are 9 of course. Similar symptom you described.
Hoot Gibson
On Mar 23, 2016, at 8:27 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
Ernie
jbsoar(at)gmail.com Guest
Posted: Wed Mar 23, 2016 5:30 pm Post subject: Start button, then whoosh |
My 55 does something similar. The starter button is real springy, and soft. When I press on it, with the master switch off, it makes a faint hissing sound. It is an air valve, and an electrical switch as well, correct?John B
On Wed, Mar 23, 2016 at 5:43 PM, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
| Quote: | --> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
Doc
> On Mar 23, 2016, at 7:18 PM, danbooker <danbooker(at)hotmail.com (danbooker(at)hotmail.com)> wrote:
> --> Yak-List message posted by: "danbooker" <danbooker(at)hotmail.com (danbooker(at)hotmail.com)>
> Daniel Booker
> [url=tel:2312457798]2312457798[/url]
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
Ernie
Posted: Wed Mar 23, 2016 6:39 pm Post subject: Start button, then whoosh |
It's an air solenoid, and electrically actuated air valve. It is very common however for the air distributor to get caught "in between" cylinders for lack of a better description, thereby venting air out an exhaust or intake valve. Pulling the prop through a little usually corrects the issue. If it happens often then you need to look at the distributor timing, which I have never done, but I understand it to be magic.
Ernie
On Wednesday, March 23, 2016, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
| Quote: | My 55 does something similar. The starter button is real springy, and soft. When I press on it, with the master switch off, it makes a faint hissing sound. It is an air valve, and an electrical switch as well, correct?John B
On Wed, Mar 23, 2016 at 5:43 PM, Roger Kemp <[url=javascript:_e(%7B%7D,'cvml','f16viperdoc(at)me.com');]f16viperdoc(at)me.com[/url]> wrote:
| Quote: | --> Yak-List message posted by: Roger Kemp <[url=javascript:_e(%7B%7D,'cvml','f16viperdoc(at)me.com');]f16viperdoc(at)me.com[/url]>
Doc
> On Mar 23, 2016, at 7:18 PM, danbooker <[url=javascript:_e(%7B%7D,'cvml','danbooker(at)hotmail.com');]danbooker(at)hotmail.com[/url]> wrote:
> --> Yak-List message posted by: "danbooker" <[url=javascript:_e(%7B%7D,'cvml','danbooker(at)hotmail.com');]danbooker(at)hotmail.com[/url]>
> Daniel Booker
br> fts!)
Ernie
I was referring to the air distributor.
On Wednesday, March 23, 2016, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | It's an air solenoid, and electrically actuated air valve. It is very common however for the air distributor to get caught "in between" cylinders for lack of a better description, thereby venting air out an exhaust or intake valve. Pulling the prop through a little usually corrects the issue. If it happens often then you need to look at the distributor timing, which I have never done, but I understand it to be magic.
Ernie
On Wednesday, March 23, 2016, John B <[url=javascript:_e(%7B%7D,'cvml','jbsoar(at)gmail.com');]jbsoar(at)gmail.com[/url]> wrote:
Dawg
Posted: Wed Mar 23, 2016 6:46 pm Post subject: Start button, then whoosh |
Just low on air. Fill up the tank.
On Mar 23, 2016, at 20:39, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | I was referring to the air distributor.
Ernie
On Wednesday, March 23, 2016, John B <[url=javascript:_e(%7B%7D,\'cvml\',\'jbsoar(at)gmail.com\');]jbsoar(at)gmail.com[/url]> wrote:
_________________ Dawg |
javiercarrascob
Posted: Thu Mar 24, 2016 11:44 am Post subject: Start button, then whoosh |
That happened to mine, and the mechanic cleaned up the solenoid and replace something like a spring, issue resolved
To: "yak-list(at)matronics.com" <yak-list(at)matronics.com>
Sent: Wednesday, March 23, 2016 10:39 PM
Subject: Re: Yak-List: Start button, then whoosh
I was referring to the air distributor.On Wednesday, March 23, 2016, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote: | Quote: | It's an air solenoid, and electrically actuated air valve. It is very common however for the air distributor to get caught "in between" cylinders for lack of a better description, thereby venting air out an exhaust or intake valve. Pulling the prop through a little usually corrects the issue. If it happens often then you need to look at the distributor timing, which I have never done, but I understand it to be magic.
ErnieOn Wednesday, March 23, 2016, John B <[url=]jbsoar(at)gmail.com[/url]> wrote: | Quote: | My 55 does something similar. The starter button is real springy, and soft. When I press on it, with the master switch off, it makes a faint hissing sound. It is an air valve, and an electrical switch as well, correct?John B
On Wed, Mar 23, 2016 at 5:43 PM, Roger Kemp <[url=]f16viperdoc(at)me.com[/url]> wrote: | Quote: | | --> Yak-List message posted by: Roger Kemp <[url=]f16viperdoc(at)me.com[/url]> Air start valve is tits. Get a new one from Doug Sapp. It is on the inside firewall at about the level of your left big toe. If you have a YAK. 52. A pain in the ass to change. Doc Sent from my iPad > On Mar 23, 2016, at 7:18 PM, danbooker <[url=]danbooker(at)hotmail.com[/url]> wrote: > > --> Yak-List message posted by: "danbooker" <[url=]danbooker(at)hotmail.com[/url]> > > When pushing start button, all I got was whoosh of air and no propeller movement. Heard air leaking, I think from behind dash. Any ideas? > > -------- > Daniel Booker > "Stealth-Eagle Aviation" > [url=]2312457798[/url] > [url=]danbooker(at)hotmail.com[/url] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=454055#454055 > > > > > > > > > > == br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. =========== List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =========== |
bwade154(at)yahoo.com Guest
Posted: Thu Mar 24, 2016 5:09 pm Post subject: Start button, then whoosh |
could be a stuck Ex or In valve also
To: yak-list(at)matronics.com
Sent: Wednesday, March 23, 2016 8:18 PM
Subject: Start button, then whoosh
Daniel Booker
2312457798
http://www.matronics.com/Navigator?Yak-Li> http://foru - List Contribution Web Site -http://www.matronic====================
