jbsoar(at)gmail.com Guest
Posted: Mon Jan 25, 2016 12:27 am Post subject: Air charging valve? |
What valve are most folks using on the air bottle?There seems to be a Russian valve, and sometimes this is removed an a shreader valve is installed. Spelled correctly?
Thank you!
richard.goode(at)russiana Guest
Posted: Mon Jan 25, 2016 1:09 am Post subject: Air charging valve? |
I know that a number of people do use the Schrader valve, but I have always been concerned since the normal operating pressure is up to 5 bar (that is for automotive tires), and in our air systems the pressure can be over 50 bar!
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +94 (0) 81 241 5137 (Sri Lanka)
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
I’m currently in Sri Lanka but this Mail is working,and my local phone is +94 779 132 160.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of John B
Sent: Monday, January 25, 2016 1:54 PM
To: Yak-List Digest Server
Subject: Air charging valve?
Thank you!
believed to be clean.
cabbott(at)dragnet.com.au Guest
Posted: Mon Jan 25, 2016 1:54 am Post subject: Air charging valve? |
Has anyone removed the self centring springs from a yak 52 ?,
if so is it as easy as removing the complete "Spring units" or do they have to be removed disassembled and the springs removed and then reinstalled ?
How is the elevator and aileron stops effected?
Chris Abbott
On 25 Jan 2016, at 8:06 PM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of John B
Thank you!
Posted: Mon Jan 25, 2016 4:19 am Post subject: Air charging valve? |
Yes I have. Easy to do. Remove the complete assembly. There is no
affect on the elevator and aileron stops.
A word of caution. When you first fly the airplane after removing the
self centering you will have a tendency to over-control the airplane
because you have been used to the spring back-pressure.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 1/25/2016 4:49 AM, CHRIS ABBOTT wrote:
| Quote: | Has anyone removed the self centring springs from a yak 52 ?,
reinstalled ?
Chris Abbott
> Richard Goode
> Rhodds Farm
> Lyonshall
> Hereford
> HR5 3LW
> United Kingdom
> www.russianaeros.com <http://www.russianaeros.com>
> *From:*owner-yak-list-server(at)matronics.com
> <mailto:owner-yak-list-server(at)matronics.com>
> [mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *John B
> *Sent:* Monday, January 25, 2016 1:54 PM
> *To:* Yak-List Digest Server
> *Subject:* Air charging valve?
> Thank you!
> This message has been scanned for viruses and
> dangerous content by *MailScanner* <http://www.mailscanner.info/>,
> and is
Posted: Mon Jan 25, 2016 4:37 am Post subject: Air charging valve? |
My question is why do you need to install any type of valve directly on
the air bottle?
When we install a Schrader valve on the external air fill port cover
(for ease of refilling), we most definitely remove the valve core
completely because it serves no purpose since the port is protected by
check valves on both the main and emergency systems. Now if one chooses
to leave a valve core inthe Schrader valve, then a high pressure valve
core must be used. Here is an excerpt from anarticle I found on valve cores.
"Even on small aircraft, the pressures that exist inside of
a landing gear strut, especially on landing, are quite high
compared to that of a typical tire. The typical Schrader
valve that we fi nd in aviation tire applications is usually
part number 6035 which has a standard operating pressure
from 0 to 400 PSI and a normal operating pressures normally
not over 70 PSI. However, the typical Schrader valve
that we should find in an aviation shock strut or hydraulic
accumulator should be Schrader part number 2300TV.
This valve has an operating pressure from 0 to 2000 PSI."
This high pressure valve core is available from Aircraft Spruce.
http://www.aircraftspruce.com/catalog/lgpages/2300hv.php
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
On 1/25/2016 4:06 AM, Richard Goode wrote:
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
is +94 779 132 160.
Thank you!
dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
GeorgeCoy
Posted: Mon Jan 25, 2016 6:01 am Post subject: Air charging valve? |
There is a high pressure version typically used on Cessna nose struts and Piper main struts The Cessna unit is S1827-1
George
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
Sent: Monday, January 25, 2016 4:06 AM
To: yak-list(at)matronics.com
Subject: RE: Air charging valve?
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Thank you!
GeorgeCoy
Posted: Mon Jan 25, 2016 6:05 am Post subject: Air charging valve? |
After they are removed, the remaining tabs make a perfect place to mount your autopilot servos. The 52W and 52TW came without the centering springs.
George
migfighter42(at)gmail.com Guest
Posted: Mon Jan 25, 2016 6:13 am Post subject: Air charging valve? |
Russian valve with Schrader valve in the cap for backup. Russian valve is a quarter turn vs screw on and has no threads to strip. Gaskets are becoming hard to find though.
N81FS
Sent from my T-Mobile 4G LTE Device
-------- Original message --------
Date: 1/25/2016 2:23 AM (GMT-06:00)
To: Yak-List Digest Server <yak-list(at)matronics.com>
Subject: Yak-List: Air charging valve?
Thank you!
Posted: Mon Jan 25, 2016 6:17 am Post subject: Air charging valve? |
Is it possible, or even advisable, to charge the air system with oxygen? The high-pressure Schreader valve might allow this to be done, if one was stuck at an airport with no SCUBA tank available.Thanks!
On Mon, Jan 25, 2016 at 6:57 AM, George S. Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)> wrote:
George
Â
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Richard Goode
Â
Â
Richard Goode
Â
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel:Â Â [url=tel:%2B44%20%280%29%201544%20340120]+44 (0) 1544 340120[/url]
Fax:Â [url=tel:%2B44%20%280%29%201544%20340129]+44 (0) 1544 340129[/url]
I’m currently in Sri Lanka but this Mail is working,and my local phone is [url=tel:%2B94%20779%20132%20160]+94 779 132 160[/url].
Â
Â
Thank you!
GeorgeCoy
Posted: Mon Jan 25, 2016 6:37 am Post subject: Air charging valve? |
Hmmm if you try it, I suggest you stand back about a mile, notify your insurance company in advance and have the fire dept. on standby as high pressure oxygen and oils make dandy explosives.
It has been done with the obvious resulting explosions.
George
Sent: Monday, January 25, 2016 9:14 AM
Subject: Re: Air charging valve?
Thanks!
George
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: [url=tel:%2B44%20%280%29%201544%20340120]+44 (0) 1544 340120[/url]
Fax: [url=tel:%2B44%20%280%29%201544%20340129]+44 (0) 1544 340129[/url]
Thank you!
William Halverson
Posted: Mon Jan 25, 2016 8:37 am Post subject: Air charging valve? |
Not a good idea ...
Typos courtesy of Siri
On Jan 25, 2016, at 09:14, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
| Quote: | Is it possible, or even advisable, to charge the air system with oxygen? The high-pressure Schreader valve might allow this to be done, if one was stuck at an airport with no SCUBA tank available.Thanks!
George
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Thank you!
draftsjust417(at)gmail.co Guest
Posted: Mon Jan 25, 2016 9:41 am Post subject: Air charging valve? |
Pure O2 is terribly volatile, more likely as not to bring on an explosion what with the oils & greases abounding in and around the system.
Out of desperation once off-base I had to use nitrogen to recharge my CJ system, and found it works very very well, plus is completely harmless and widely avail in high pressure containers.
I keep a 2500 psi cylinder in hangar for all my maintenance ($18 for a refill at any welding supply shop).
Fyi,
Justin Drafts (A&P)
N280NC
On Jan 25, 2016 8:01 AM, <jlpartington(at)reagan.com (jlpartington(at)reagan.com)> wrote:[quote]
most places that have oxygen should have nitrogen, cheaper and less likely to cause problems with much oxygen around in case of fire.
Â
Looigi
Joined: 20 Apr 2015 Posts: 81 Location: Christchurch, New Zealand
Posted: Mon Jan 25, 2016 12:08 pm Post subject: Re: Air charging valve? |
Pure oxygen under high pressure will spontaneously combust when exposed to grease and oils, without the need of any other source of ignition.
When we replenish aircraft oxygen systems at work (I am an Aircraft Engineer) we make sure we have clean hands, clean overalls and we use a dedicated set of clean tools that are only used on oxygen systems. Seriously guys, yes you are sitting in a room full of it, but under high pressure oxygen is lethal.
To relate this back to the topic on hand, I will put it bluntly; ONLY FILL YOUR YAK AIR SYSTEM WITH OXYGEN IF YOU WANT TO DIE!!
Schrader valves are commonly used on commercial aircraft for applications far exceeding the pressures we are talking about here, but they are these type: https://www.schraderinternational.com/Products/Product-Folder/NA-High-Pressure-Valves-and-Connectors?sc_lang=en-US-AP
My question is, what is wrong with the Russian type os fitting that comes fitted to the aircraft as standard? I personally think the design is very clever and reliable. I looked at getting some machined up a while ago and the price was very reasonable at $100 or so each. As it happened, I was given one, but if enough people want one, I will get some made.
Chris
pa3arw(at)ziggo.nl Guest
Posted: Mon Jan 25, 2016 1:13 pm Post subject: Air charging valve? |
I can confirm that! If I am not mistaken this is what happened a couple of
years back in Belgium: on a ferry flight a Yak52 arrived on a small airfield
in Belgium. After staying overnight and not having closed the main valve all
air was lost from the system. Since there was nothing else available than a
bottle with oxygen (for welding purposes) the pilot decided to fill the
system with this pure oxygen.
As soon as he hit the start button the whole plane exploded, that is all
tubing, actuators the whole lot was blown up. Result: a big bang, a fully
lost Yak52 and a bended ego....
Moral: never, never use pure oxygen!
Fly safe!
Hans O.
PH-YAK
Op 25-01-16 21:08, Looigi <cdoburton(at)gmail.com> schreef:
grease and oils without any other source of ignition.
sitting in a room full of it, but under high pressure oxygen is lethal. To
Chris
http://forums.matronics.com/viewtopic.php?p=452269#452269
Posted: Mon Jan 25, 2016 6:43 pm Post subject: Air charging valve? |
Air pressure inlet questions.
This thread is getting quite interesting, and I thank all of you for your contributions. There are tens of thousands of hours of experience on this forum, and it is nice that this knowledge is being shared.
Most of twenty years ago, I got a ride in a CJ-6. Of course, I squeezed the bicycle brake handle that was mounted on the control stick, and was rewarded with a whoosh of air, as the brakes cycled. Interesting. The engine was easy to start, and the airplane flew well. I casually wondered why Western airplanes didn't use a similar air starting system.Â
Most of five years ago, at the Casa Grande airport in Arizona, I spoke with a foreign pilot who was ferrying a Sukhoi. He had stopped for fuel, and then ran the airplane out of air while trying to start it. He was in luck, as, at the time, there was a scuba diving school in town that was open. Somebody took him to the scuba store, and, after messing around with a scuba tank, he started the engine and departed.
During the two hour sit in the pilot's lounge, I learned that oxygen couldn't be used, as it created an explosive mixture, and I was told that nitrogen wouldn't work, as nitrogen would tend to discourage combustion. Â
Now, after buying a Yak 55M, I'd like to operate the airplane safely, and in a reliable manner. No Oxygen, for obvious reasons. I did not know that Nitrogen could be used. The Yak I bought has the original Russian quarter turn fitting behind the wing on the left side of the fuselage. This past weekend, I looked at a CJ-6 that had a similar fitting, except that someone had modified it with the installation of a Schreader valve, presumably of the high-pressure type. The owner had a scuba tank in his hangar with the brass thread-on Schreader valve attached via a hose. This set-up might provide two advantages:  1. If one gets stuck away from one's own scuba tank, they might get their airplane started via a borrowed Nitrogen bottle, which is common at most sizable airports.  2. The original Russian fitting has a dust cap that is held on with a cable lanyard. With a Schreader valve, one wouldn't have to use, and leave off, this cap. Thus far, the original Russian set-up has been working fine. Â
Folks, if my thinking is defective, please educate me. I appreciate your feedback!
John B
Phoenix, AZ
On Mon, Jan 25, 2016 at 1:08 PM, Looigi <cdoburton(at)gmail.com (cdoburton(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "Looigi" <cdoburton(at)gmail.com (cdoburton(at)gmail.com)>
Pure oxygen under high pressure will spontaneously combust when exposed to grease and oils without any other source of ignition.
When we replenish aircraft oxygen systems at work (I am an Aircraft Engineer) we make sure we have clean hands, clean overalls and we use a dedicated set of clean tools that are only used on oxygen systems. Seriously guys, yes you are sitting in a room full of it, but under high pressure oxygen is lethal. To relate this back to the topic on hand, I will put it bluntly; ONLY FILL YOUR YAK AIR SYSTEM WITH OXYGEN IF YOU WANT TO DIE!!
Chris
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
Viperdoc
Posted: Mon Jan 25, 2016 8:29 pm Post subject: Air charging valve? |
Oxygen not no but Hell No. Unless you have a death wish. Light off a cylinder filled with O2 in the air start lines with a push of the shower of sparks and watch the explosions begin. For some nitrogen has worked but it will be diluted out after the compressor begins recharging the system.
On Jan 25, 2016, at 8:14 AM, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
George
Subject: RE: Yak-List: Air charging valve?
Richard Goode
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Thank you!
_________________ Viperdoc |
Viperdoc
Posted: Mon Jan 25, 2016 8:38 pm Post subject: Air charging valve? |
The pictures posted at the time were impressive. Do not remember did the wayward soul survive?
Doc
| Quote: | On Jan 25, 2016, at 3:04 PM, Hans Oortman <pa3arw(at)ziggo.nl> wrote:
Fly safe!
Hans O.
PH-YAK
> Chris
jan.mevis(at)informavia.b Guest
Posted: Mon Jan 25, 2016 9:05 pm Post subject: Air charging valve? |
Nobody was hurt.
But the plane was almost a total loss.
Big holes in the wings in the neighborhood of the gear actuators and the
fuselage had many small holes at one side as if it was fired upon with a
machine gun.
The Yak 52 has been rebuilt by Termikas and is in perfect shape again.
Jan
On 26/01/16 05:34, "Roger Kemp" <owner-yak-list-server(at)matronics.com on
behalf of f16viperdoc(at)me.com> wrote:
Doc
>of
>airfield
>valve all
>than a
>fully
> Fly safe!
> Hans O.
> PH-YAK
>>exposed to
>>Engineer)
>>dedicated set of
>>you are
>>lethal. To
>>FILL YOUR
>>applications far
>>type:
>>essure
>>comes
>>very
>>and the
>>given
>> Chris
Posted: Mon Jan 25, 2016 9:12 pm Post subject: Air charging valve? |
Sometimes starting up does work with nitrogen.
I’ve done it several times when we ran out of industrial-compressed air and scuba-bottles empty.
Jan
From: <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)>
Reply-To: "yak-list(at)matronics.com (yak-list(at)matronics.com)" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Date: Tuesday 26 January 2016 at 03:34
Subject: Re: Re: Air charging valve?
John B
Phoenix, AZ
Chris
br> fts!)
Looigi
Posted: Mon Jan 25, 2016 9:30 pm Post subject: Re: Air charging valve? |
I forgot to mention that the other disadvantage of a schrader valve is that you need spanners to operate it. The quarter turn Russian one, you don't!
Chris
