rvdave
Posted: Tue Jan 19, 2016 10:17 am Post subject: Engine mount ground? |
I'm running a braided ground from firewall/forest of tabs to engine, is it necessary to ground the engine mount?
_________________ Dave Ford
Cadillac, MI |
Posted: Tue Jan 19, 2016 10:24 am Post subject: Engine mount ground? |
At 12:17 PM 1/19/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: "rvdave" <rv610dave(at)gmail.com>
I'm running a braided ground from firewall/forest of tabs to engine, is it necessary to ground the engine mount? |
No.
jbsoar(at)gmail.com Guest
Posted: Tue Jan 19, 2016 4:17 pm Post subject: Engine mount ground? |
The engine mount probably doesn't require a dedicated ground strap as it is bolted to the firewall and aircraft primary structure.
On Tue, Jan 19, 2016 at 11:17 AM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=452108#452108
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
n992dn(at)gmail.com Guest
Posted: Tue Jan 19, 2016 4:39 pm Post subject: Engine mount ground? |
It is not necessary to ground the engine mount since it is bolted to the FW, it is however necessary to ground the engine itself, in many cases the engine is mounted to the engine mount using rubber mount, these are not great conductors.....
Nati
On Tue, Jan 19, 2016 at 6:11 PM, John B <jbsoar(at)gmail.com (jbsoar(at)gmail.com)> wrote:
| Quote: | The engine mount probably doesn't require a dedicated ground strap as it is bolted to the firewall and aircraft primary structure.
rvdave
Posted: Tue Jan 19, 2016 5:22 pm Post subject: Re: Engine mount ground? |
Sort of what I thought but I've been getting some feedback that there should also be a ground cable to the engine mount in case the firewall ground disconnects? The thinking is that if the one cable disconnects the ground for alternator, starter may come through braided oil or fuel lines. Is this valid thinking?
Cadillac, MI |
neal.george(at)gmail.com Guest
Posted: Tue Jan 19, 2016 5:39 pm Post subject: Engine mount ground? |
| Quote: | On Jan 19, 2016, at 6:34 PM, Nati Niv <n992dn(at)gmail.com> wrote:
Nati
Engine mounts should never be used as a ground path. Strap the crankcase to the ground post. No excuses.
Even though the bolts and bushings that pass thru the rubber components will ohm out and indicate continuity, carrying electrical loads is not part of their job description. Many relatively recent aircraft designs incorporate bonding straps bolted to either side of the vibration isolator and to the crankcase specifically to keep current out of the mounting points.
Steel is a relatively poor conductor. Joints make it worse by inserting resistance. High current passed thru a resistive path makes heat, which accelerates the chemical reaction that we describe as corrosion. Add insidious Galvanic corrosion due to dissimilar metals in constant contact.
Apart from that, assuming one removes the paint from the mating surfaces, the 4130-steel engine mount bolted to the stainless or galvanized firewall makes a poor ground when new and an awful ground as corrosion forms over time.
And it will corrode, despite application of DC 4, Par-al-ketone, ACF-50, (etc., pick your favorite goop)...
Neal
Yes, it is valid thinking. You want a good ground, that is mechanically sound. It goes from the crankcase to the firewall ground. You can include the engine mount if you wish. Does the engine mount have a convenient ground tab? If it does, then run another ground strap to your firewall ground. This won't weigh much, or cost much. (Belt and suspenders, so to speak.)Bob Nuckolls writes about this in the manual. A good read!
On Tue, Jan 19, 2016 at 6:22 PM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=452119#452119
br> fts!)
Joined: 28 Mar 2008 Posts: 1970 Location: Riley TWP Michigan
Posted: Tue Jan 19, 2016 8:11 pm Post subject: Re: Engine mount ground? |
Yes, it is valid thinking. But it is not necessary or even desired to ground the engine mount. It will not hurt anything if the engine mount is grounded. But if a backup ground path is wanted, then run a second ground strap from the engine block to the firewall.
_________________ Joe Gores |
glastar(at)gmx.net Guest
Posted: Wed Jan 20, 2016 2:05 am Post subject: Engine mount ground? |
taking a different path is valid thinking (ask me how I know!!)
But then I rather would prefer to have a 2nd strap as backup as
otherwise you would need a bridge strap at the rubbermounts.
Cheers Werner
On 20.01.2016 02:22, rvdave wrote:
Posted: Wed Jan 20, 2016 7:48 am Post subject: Engine mount ground? |
At 04:03 AM 1/20/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net>
But then I rather would prefer to have a 2nd strap as backup as otherwise you would need a bridge strap at the rubbermounts. |
As Neal pointed out earlier . . . and I have asserted
many times over the years, engine mounts are for holding
engines onto airplanes. They should not be pressed into
service as any part of the electrical system . . . voltages
impressed across structural joints due to large circulating
currents exacerbates corrosion. Not that this is a
demonstrated hazard but diligent failure mode effects
analysis dictates that using the engine mount as part of
the electrical system is simply not necessary and elevates
an otherwise zero-risk to some non-zero number.
Another point of interest is the risk for 'burning ship's
wiring' with starter currents should a firewall-to-crankcase
bond strap become unhooked. Throughout the 'Connection and
here on the List, builders have been cautioned about having
ANY pathway grounded in two places on the airplane . . .
with p-lead shields being the most common violation of that
philosophy. Multiple grounds for engine instrumentation run
a close second. These are 'ground loops by design', easy
(and sometimes important) to avoid.
Lastly, the firewall-to-crankcase bond strap should be
as "reliable as prop bolts". The only incident for loss
of crankcase grounding I witnessed was a mechanic's slip-
up on one of our airplanes at K1K1 . . . and yeah, it
burned the p-lead shields wired per Cessna factory
drawings. I recommend an flat braid strap from some
structural bold on engine to the firewall ground stud.
Alternatively, a 2AWG piece of WELDING CABLE with lugs
installed per
http://tinyurl.com/gm8lqxo
. . . and attached with robust hardware will give
your prop bolts a serious challenge in the longevity/
reliability race.
