AeroElectric-List Digest: 2 Msgs - 01/03/16
tllaz330(at)gmail.com
PostPosted: Mon Jan 04, 2016 6:12 am    Post subject: AeroElectric-List Digest: 2 Msgs - 01/03/16 Reply with quote
I am new to the forum.  Is this where I can ask a question?
Mike L.
On Mon, Jan 4, 2016 at 2:59 AM, AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)> wrote:
Today's complete AeroElectric-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the AeroElectric-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2016-01-03&Archive=AeroElectric
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2016-01-03&Archive=AeroElectric
                           AeroElectric-List Digest Archive
                     Total Messages Posted Sun 01/03/16: 2
Today's Message Index:
     1. 11:53 AM - Re: Switch question  (Robert L. Nuckolls, III)
     2. 11:30 PM - Re: Re: Alternator and regulator connections  (Bob Verwey)
________________________________  Message 1  _____________________________________
Time: 11:53:52 AM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Subject: Re: Switch question
At 11:47 AM 1/3/2016, you wrote:
>Bob,
>    I am looking to use the switch that you show in your book,
> labeled 2-10. I have searched for such a switch that I can obtain
> locally, but have not had any success using the S700-2-10
> nomenclature. I believe that you reference Carling switches, but
> have not found one in their catalog. Would you have another number
> that would reference this switch? Thanks.
   The S700 series switches are a catalog number
   first assigned by the AeroElectric Connection
   and later adopted by B&C Specialty Products.
   These catalog numbers defined a functionality
   in a standard bat-handled, 15/32" mounted toggle
   switch. This allowed us to offer switches from
   a variety of sources under one part number . . .
   a number you will not find cited 'in the wild'.
   The 2-10 suffix describes the two pole, three
   position, progressive transfer switch as and
   on-on-on function. You can order that switch
   from B&C as the S700-2-10 or seek out its
   equivalent based on functional description
   from a host of suppliers . . .
________________________________  Message 2  _____________________________________
Time: 11:30:06 PM PST US
From: Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)>
Subject: Re: Re: Alternator and regulator connections
What is the function of the AUX connection?
On 1 January 2016 at 09:09, Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)> wrote:
> Bob thanks,
> I have the EFIS alarm so will ignore the warning lite connection.
> On 31 December 2015 at 21:51, Robert L. Nuckolls, III <
> nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
>> At 10:17 AM 12/31/2015, you wrote:
>> Guys thanks for all the replies!
>> So I connected everything as postulated by Joe and Bob, and I am seeing
>> 14.2 volts on the Bus, which I believe to be correct.
>> The only thing is that the warn lite connection shows +12v when the
>> master is turned on, and it does not extinguish when the voltage stabilizes
>> and the amp meter is showing a good charge.
>>   As a general rule, alternator failure lights
>>   built into regulators are of limited value
>>   and should never take the place of ACTIVE
>>   NOTIFICATION of low bus voltage. I presume
>>   you have this function in place with
>>   other hardware. I never hook up the built-in
>>   lights.
>>   Bob . . .
> Best...
> Bob Verwey
Best...
Bob Verwey
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
jmjones2000(at)mindspring
PostPosted: Mon Jan 04, 2016 6:50 am    Post subject: AeroElectric-List Digest: 2 Msgs - 01/03/16 Reply with quote
Welcome Mike!
You can ask a question right here. Just reply to this email, or create a new email and send it to: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)
Justin
On Jan 4, 2016, at 05:09, Michael Lazarowicz <tllaz330(at)gmail.com (tllaz330(at)gmail.com)> wrote:
Mike L.
HTML Version:
Text Version:
>Bob,
> Bob thanks,
>> lights.
>> Bob . . .
> Best...
> Bob Verwey
Best...
Bob Verwey
br> fts!)
PostPosted: Mon Jan 04, 2016 8:20 am    Post subject: Re: AeroElectric-List Digest: 2 Msgs - 01/03/16 Reply with quote
I like to go here:
http://forums.matronics.com/viewforum.php?f=3
Then click on "New Topic".
Or
Click on someone else's post, then click on "PostReply".
Joe Gores
