Richard Pike
Posted: Sun Dec 27, 2015 1:08 pm Post subject: Odd float needle problems |
Three weeks ago replaced the primer bulb on the Firestar II, and then unintentionally spammed the list with more than 1 post - will try not to do that today.
Two weeks ago got ready to fly the Firestar, it has a 582 with the usual Bing 54's. Once again could not get the engine to prime, and eventually discovered that the float needles of both carbs were stuck up in the seats, and would not let any gas in. Eventually got them to let gas in by rapidly flicking the float arm until I could see the needles drop down, then it primed and ran normally.
Ordered 2 carb kits. (Interestingly, carb kits with float needle, gaskets, O-rings, etc. are cheaper than just ordering only the float needles. ???) Since it got up 74 degrees today in E. Tennessee, seemed like a good day to fix things. With the carbs on the work bench, one of the float needles was once again stuck in the float seat, and did not want to come out. Slipped a needle awl through the little spring that goes through the float needle pin, and almost broke the little spring trying to get the needle to release & come out of the seat.
Once out, inspected the seat, appeared normal. However - the ends of both float needles are not the usual black, but sort of deep peach or almost brick color. With everything back together with new parts, everything primed normally and the floats, etc. did OK.
Not sure what to think of all this, but since things have been slow on the list lately, thought I would pass it along and one of you guys might know what to make of it. Bogus parts in the last rebuild? No idea here.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Sun Dec 27, 2015 1:42 pm Post subject: Odd float needle problems |
A probability the fuel needles were not Bing. Always a chance of "junk"
getting into the normal parts supply system.
Experienced an engine failure on my second flight to the Flight Farm,
Monterey, NY, in 1989. Flew the Firestar up, powered with a 447. Figured
it was time to replace the Mikuni fuel pump diaphragm because I had a lot of
hours on the old one. Didn't want an engine out. Put the replacement
diaphragm in and did a quick test flight. Lost the engine about 100 feet
AGL right over a nice hay field. Checked it out. Flew back to the Flight
Farm very gently. Dug my old diaphragm out of the garbage can. Reinstalled
it. Flew from there to Oshkosh and back to Alabama. Got home, called LEAF.
Told them they had sold me a no name fuel pump diaphragm for my Mikuni.
They were not interested. I am only one customer, but they lost me that
day.
Make sure you are getting what you think you are getting.
MKIII
_________________ John Hauck
Titus, Alabama |
rickofudall
Posted: Mon Dec 28, 2015 6:28 pm Post subject: Odd float needle problems |
Richard, I believe the reddish colored needle valves are the latest formula to deal with ethanol gas. I got them for rebuilding a pair of 64's a couple of years ago and again when I needed just a needle valve last year. Sounds more like the steel portion is oversize. Since it's three lobed you can't just measure them with a micrometer. A ring gauge might work if you know someone with these very specialized gauges.Good luck and Happy New Year.
Rick Girard
On Sun, Dec 27, 2015 at 3:08 PM, Richard Pike <thegreybaron(at)charter.net (thegreybaron(at)charter.net)> wrote:
| Quote: | --> Kolb-List message posted by: "Richard Pike" <thegreybaron(at)charter.net (thegreybaron(at)charter.net)>
Not sure what to think of all this, but since things have been slow on the list lately, thought I would pass it along. and one of you guys might know what to make of it. Bogus parts in the last rebuild? No idea here.
Richard Pike
Kingsport, TN 3TN0
Would you consider yourself to be a good person?
https://www.youtube.com/watch?v=VWcDXT6pH7A
http://forums.matronics.com/viewtopic.php?p=451442#451442
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
