ROTAX 914 engine oil
f.kyle(at)sympatico.ca
PostPosted: Wed Nov 04, 2015 11:40 am    Post subject: ROTAX 914 engine oil Reply with quote
I have recently begun to prepare to run the title engine for the first time. I turned to the engine oil specs to find that the one recommended is AeroSHELL Sport plus 4 - not available in Canada.
I have therefore sent the following to Austria: “Would you be kind enough to send me a case of AeroSHELL Sport plus 4 engine oil so that, placed in my oil reservoir, I can fly to U.S.A. to buy a case of AeroSHELL Sport plus 4 oil?
Fergus Kyle
Europa C-FFGG"
Guy Buchanan
PostPosted: Wed Nov 04, 2015 12:56 pm    Post subject: ROTAX 914 engine oil Reply with quote
I go with the Honda HP4 10-40w. You might find that in Canada.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again.
Now a glider pilot, too.
 Fergus Kyle
Europa C-FFGG"
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
dashwoodlock(at)yahoo.ca
PostPosted: Wed Nov 04, 2015 2:10 pm    Post subject: ROTAX 914 engine oil Reply with quote
aero shell sport plus 4 is available through arcraft spruce in brantford and rotec in britich columbia... i switch to amsole 5/ 40 or 10 /40 motercycle oil in the winter months...
Sent: Wednesday, November 4, 2015 2:39 PM
Subject: RotaxEngines-List: ROTAX 914 engine oil
Fergus Kyle
Europa C-FFGG"
PostPosted: Wed Nov 04, 2015 5:32 pm    Post subject: ROTAX 914 engine oil Reply with quote
I've used Shell Rotella T-6 full synthetic, and sometimes make my own semi-synthetic by mixing T-6 and Rotella dino oil 50/50, for the past several thousand hours.  Never had a problem with it.  Seems to suspend lead as well as the full dino recommended by Rotax.  Wal-Mart sells for less than 20.00 a gal.
Don't want to shock the Rotax purist, but I have also used Fram filters since my first 912 back in 1993, plus another two 912ULS engines since then.  My filter of choice is the Fram TG 3614 (that's the Tough Guard filter).  Only time I have flown with Rotax oil filters was the one that came with each new engine.
Same for spark plug connectors.  Last time I found some on line they were about 4 or 5 dollars each.  Searched the part number on the connector.
Kolb MKIII
hauck's holler, Alabama
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Dashwoodlock
Sent: Wednesday, November 04, 2015 4:10 PM
Subject: Re: ROTAX 914 engine oil
From: Fergus Kyle <f.kyle(at)sympatico.ca (f.kyle(at)sympatico.ca)>
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: ROTAX 914 engine oil
Fergus Kyle
Europa C-FFGG"
