Switch ID
sam.marlow
PostPosted: Thu Oct 29, 2015 2:35 pm    Post subject: Switch ID Reply with quote
Can someone help me identify what kind of connectors are used on this
switch? I want to use it on the flaps for an RV7A. Part # 13AT437-T2
7711 or M8805/26-010, not sure which one is the part number.
Thanks!
Sam Marlow
 Filesize:  1.64 MB
 Viewed:  3796 Time(s)
edpav8r(at)yahoo.com
PostPosted: Thu Oct 29, 2015 5:13 pm    Post subject: Switch ID Reply with quote
Those are called solder turrets:
There is no mating connector. They're meant to have bare wires wrapped around them then soldered, like this:
I'll leave it to others here to discuss their suitability for use in aircraft.
Eric
On Oct 29, 2015, at 3:32 PM, Sam Marlow <sam.marlow(at)roadrunner.com> wrote:
Can someone help me identify what kind of connectors are used on this switch? I want to use it on the flaps for an RV7A. Part # 13AT437-T2 7711 or M8805/26-010, not sure which one is the part number.
Thanks!
Sam Marlow
 Filesize:  19.43 KB
 Viewed:  3793 Time(s)
 Filesize:  45.07 KB
sam.marlow
PostPosted: Thu Oct 29, 2015 7:02 pm    Post subject: Switch ID Reply with quote
Thanks for the reply!
Eric
> Thanks!
> Sam Marlow
</b></font></pre>
