iPad Reviews
jeff(at)westcottpress.com
PostPosted: Fri Sep 04, 2015 10:42 am    Post subject: iPad Reviews Reply with quote
I'm in the market for a new iPad to run Foreflight. Any suggestions/opinions?
Jeff Carpenter
Building hours so I can start flying my own plane.
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
Bob Turner
PostPosted: Fri Sep 04, 2015 11:17 am    Post subject: Re: iPad Reviews Reply with quote
Since this is a RV-10 forum, I'll assume you want to use it in a -10 or at least an airplane with a stick.
I just couldn't get comfortable with a full size iPad. I'm short, so I sit close to the stick, and it got in the way unless I used two hands to hold the iPad up or away. OTOH an iPad mini is just right for me. Portrait mode, on my right thigh. Just large enough to read approach plates without zooming (I wear bifocals). My mini has gps and wifi, the latter used to couple to a Skyradar ADSB-in box. The gps is nice to get geo-referencing on the charts.
Foreflight vs WingX: As you probably know Foreflight will only couple to a Stratus box, WingX works with a bunch of ADSB boxes. WingX uses more data compression, so memory size is not important. If you run Foreflight you will need an iPad mini with extra memory.
disclaimer: as a CFI I get WingX for free. However, even before it was free, I paid for it.
Bob Turner
RV-10 QB
kearney
PostPosted: Fri Sep 04, 2015 11:41 am    Post subject: Re: iPad Reviews Reply with quote
Jeff
This is a very personal decision in that everyone has to sort out what works for them. A few weeks ago I canvasses for opinions and ultimately landed on an IPAD AIR 2. For me the large size is great.
As I am in Canada, I need to get XM weather as ADSB is not available here (except in the far north).
I use Fltplan.Com on the IPAD as it gives me all the US and CANADA maps and approach plates for free and supports XM weather. It also supports a few ADSB receivers so I would check this out if that is what you plan to use.
I also picked up a MYGOFLIGHT mount for the IPAD that I plan to install in a couple of weeks. It will allow the IPAD to be secured up and to my right for easy viewing and access.
If you can, try to borrow a large and small IPAD and see what works best for you. I would also check out FLTPLAN.COM and its IPAD app.
Cheers
Les
Tim Olson
PostPosted: Fri Sep 04, 2015 11:47 am    Post subject: iPad Reviews Reply with quote
I'll fill in with my 2 cents. Unlike Bob, I'm tall, but I don't
know how much that matters. I like the full size one myself.
I think the mini that my daughter has does an OK job too. It all
depends on how you use it. I hand mine off to someone or set it
on the seat next to me if I'm alone. So it doesn't get in the way
for me, and I only use it when I need it.
Regarding hardware, my advice is to buy bigger (more GB of capacity)
than you need, for future growth, because you don't want to have to
upgrade if your apps take up more space. Also, always get one
with cellular capability, just for the GPS. And, I'd say go with
one of the newer models...better performance and displays. If
you are thinking of buying soon, I'd wait a few weeks. All the
new stuff should be announced next week. So delay a purchase for
a month or so.
Bob's right that the stratus ads-b only works with foreflight.
But there is an exception. I think FlyQ hacked the interface
and now supports the stratus also. I have Foreflight, WingX,
and FlyQ. WingX is my current favorite, but the almost released
FlyQ 2.0 (maybe it's even released already) is getting it closer
to catching up. It works pretty well. I get no benefits from
any of the apps, as I'm not a CFI nor get any kickbacks. But I
buy them all. Foreflight is the nicest one that has iphone
integration if that means anything to you. WingX I find is best
for IFR flying. My hope is that with just a couple more additions
to FlyQ, that it can become the favorite, because I get the most
bang for the buck with FlyQ and have a lifetime subscription.
But for right now at this point in time, I prefer WingX.
It would be hard to give up Foreflight on the iphone though, so
I may maintain the non-pro subscription to that one too...we'll see.
On 9/4/2015 2:17 PM, Bob Turner wrote:
<bobturner(at)alum.rpi.edu>
or at least an airplane with a stick. I just couldn't get comfortable
the charts. Foreflight vs WingX: As you probably know Foreflight will
-------- Bob Turner RV-10 QB
rv10flyer(at)live.com
PostPosted: Fri Sep 04, 2015 11:49 am    Post subject: iPad Reviews Reply with quote
1) wait until after the 9th when a (unofficial ) new iPad is being released. That will reduce pricing on older models and give another option.
2) get a iPad Air not a mini, I found the mini easier to handle but the iPad easier to read charts and the extra features in the foreflight.
I use FltPlan GO but think foreflight offers more hence the iPad Air . For sure I am happy with electric charts and features.
On Sep 4, 2015, at 11:46 AM, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
Jeff Carpenter
Westcott Press
1121 Isabel Street
Burbank, CA 91506
818-861-7300
Bob Turner
PostPosted: Fri Sep 04, 2015 2:44 pm    Post subject: Re: iPad Reviews Reply with quote
I should have been clearer about my preference for the mini.
I use the electronic device for approach charts, and, when doing approaches without the autopilot (I do have one but feel I should be able to hand fly) I do not have a free hand to hold the iPad. I want the chart on my leg or lap, and the full size iPad doesn't fit. Otherwise, the full size would be fine and in point of fact I do have and use an original iPad when vfr, someone else is flying, etc.
Bob Turner
RV-10 QB
daviid(at)gmail.com
PostPosted: Fri Sep 04, 2015 2:56 pm    Post subject: iPad Reviews Reply with quote
This is what I use with my full size iPad Air
http://www.amazon.com/gp/product/B005IZ0QU6?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=446808#446808
Bob Turner
PostPosted: Fri Sep 04, 2015 3:11 pm    Post subject: Re: iPad Reviews Reply with quote
I looked at this. For me, personally, I felt there was some interference with right aileron motion.
daviid(at)gmail.com wrote:
Bob Turner
RV-10 QB
Bob Turner
RV-10 QB
johngoodman
PostPosted: Sat Sep 05, 2015 4:16 am    Post subject: Re: iPad Reviews Reply with quote
I elected to go with an iPad Mini. My first one was the cheapest they make - only 16 gigs. The second one was one step up - 32 gigs. You need 32 if you want the entire US on ForeFlight. For GPS, I bought a Dual XGPS150 from Spruce for less than a hundred dollars, it works great, and is exceptionally accurate.
The iPad Mini is primarily for my wife to use on cross countries. I did fly to Oshkosh by myself, but mostly relied on my GRT HX and GNS 430W. It did come in handy when looking for a fuel stop.
The big thing for me is that the electronic charts legally replace the paper ones.
Mauledriver(at)nc.rr.com
PostPosted: Mon Sep 07, 2015 10:23 am    Post subject: iPad Reviews Reply with quote
I'd suggest that figuring out how and where you will mount it is a key decision, particularly with respect to mini vs non-mini.  Guessing as to exactly how you will end up using it is another important factor - but guessing is what it is.
I have a long-in-the-tooth multi-screen GRT-HX panel with a G430w for smarts and Navworx ADSB for wx and traffic.  This gives me everything I need to fly IFR, permanently mounted and fully integrated into my HX screens... except for approach plates.  (there is a plate option available for the HX but I chose to stay with Foreflight)
But I always fly with an iPad running Foreflight.  It's used for flight planning, briefings, map work, and procedure information.  The one thing it is missing that I wish I had is Nexrad display.  I have them on the HX but map work using Foreflight on the iPad is so much more flexible and quicker that I'd like to have Nexrad imagery there as well.  Plus I don't have to disturb my flight displays to explore weather driven options.  Traffic on the iPad is not needed in my configuration.
I originally had the iPad 1 or 2 in the largest size.  My wife later got a mini and I determined that I still preferred a larger screen when I replaced my first one.  I now have what I guess is an iPad Air... I little smaller than the original but still with the big screen.
I paid a lot of attention to how I would mount it.  I ended up fabricating a center console with the triple role of 1) providing an optimal mount for a RAM mounted iPad, 2) holding an O2 tank and 3) an elbow rest.  In retrospect I'm not sure there is a perfect mounting location but I think I have the optimal one for me.  No stick interference, no panel interference, falls easily under my right hand for reading and writing (I've gone completely paperless by using the less than optimal FF/iPad scratch pad for notes).  However, it does interfere with my view and access to the power quadrant.  So on takeoff and most landings I just shift it out of the way on the RAM mount.  On x-windy landings I remove the RAM mount completely.  But since 95%+ of my flying is in cruise, 100% clear and free power quadrant access is not a concern.
I think the mounting location might drive the iPad size decision but in any case, the mounting question deserves your attention.   I added a charging jack as well.  The iPhone is an important backup for IFR work if you manage it as such.
Here are some pics iPad RAM mount on center console
Bill "who's learned to love closed systems while longing for open ones" Watson
On 9/4/2015 2:38 PM, Jeff Carpenter wrote:
[quote]I'm in the market for a new iPad to run Foreflight. Any suggestions/opinions?
Jeff Carpenter
kearney
PostPosted: Mon Sep 07, 2015 10:48 am    Post subject: iPad Reviews Reply with quote
Hi Bill
I picked up a mygoflight.com clip mount for an iPad at KOSH. I plan to mount it on the tunnel similar in position to yours.
It has a single point adjustment on the elbow that locks all the joints. A vey innovative feature. I will post pic when I have it in.
Cheers
Les
On Sep 7, 2015, at 12:19, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] I'd suggest that figuring out how and where you will mount it is a key decision, particularly with respect to mini vs non-mini. Guessing as to exactly how you will end up using it is another important factor - but guessing is what it is.
Jeff Carpenter
Bob Turner
PostPosted: Mon Sep 07, 2015 1:25 pm    Post subject: Re: iPad Reviews Reply with quote
Bill, I'm not sure I understand your set up. You put departure and approach procedures on your iPad? But at the most critical times - takeoff into or approaches in low ifr - you need to move the iPad for throttle access? Is it still easily seen?
Bob Turner
RV-10 QB
PostPosted: Tue Sep 08, 2015 6:57 am    Post subject: iPad Reviews Reply with quote
I understand the confusion - didn't know how many words to wrap around
the description.
I don't actually need to move the iPad for throttle access. I can fully
access the quadrant and operate it without moving the iPad or mount from
it's normal position. It does require me to reach around the iPad just
a bit. If I want to see the entire quadrant I need to shift my head
position slightly to the right to see around the iPad. I do this for
the 'big pull' to my LOP setting for example.
I can also simply nudge the iPad to the side with my right arm as I
reach for the quadrant which gives me a fuller view of the quadrant and
eliminates any reach around. I can still see the iPad if needed but I'm
likely to set the power and nudge it back into position. The RAM mount
is easily set so that it's stiff enough to maintain position but also
easily nudged side to side as desired.
None of the above requires any thought or causes any concern in any
phase of flight. Just an observation of how I use it given its mounting
position. Put another way, the quadrant and the iPad naturally want to
occupy the same space when operated, i.e. falling naturally under the
right hand. In my installation they do occupy the same space visually -
the quadrant being a little further away than the iPad.
I do find myself sometimes removing the iPad and its mount for gusty
xwind type landings, particularly if it's the last landing of the day
(because the iPad goes in the flight bag after landing). It gives me a
completely unobstructed space to whack the stick around and fool with
the power. If it's a fuel stop, I'll tend to keep it in place for
convenience. There's no requirement to demount it for takeoffs and
landings, just something I tend to do on last landings of the day and/or
in gusty conditions. As you know, gusty conditions and low weather
rarely go together....
On the very positive side, I do a fair number of departures into low
conditions from my uncontrolled field that is right up against a busy
Class C. It sometimes gets busy launching into VFR and picking up my
clearance while staying below a low ceiling. More rarely flying a
clearance into controlled airspace against a void time is also a busy
time. The iPad and its mount shine really shine in those situations.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=446868#446868
Checked by AVG - www.avg.com
PostPosted: Tue Sep 08, 2015 7:07 am    Post subject: iPad Reviews Reply with quote
Those look real good Les.  I probably would have gone with that if they were available 4-5 years ago.  I considered trying to fabricate something like it but ended up doing the full monty with the console.
BTW, while an elbow rest for using the iPad in that position is 'nice', it doesn't really seem to be a need.  But I find that an elbow rest for just cruising is very nice.  However, center consoles remove some of the spacious feel of the cockpit.  I tried to minimize the bulk of my console so it didn't impinge on hip room (aka ass clearance).
If an O2 tank isn't involved, the ideal config might be a mount like the MyGoFlight and a pull down arm connected to the seat back like mid-90s Dodge minvans had.  Keeps the spacious feel and provides a place to rest the arm.
On 9/7/2015 2:43 PM, Les Kearney wrote:
[quote] Hi Bill
Cheers
Les
On Sep 7, 2015, at 12:19, Bill Watson <[url=mailto:Mauledriver(at)nc.rr.com]Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)[/url]> wrote:
Jeff Carpenter
Date: 09/07/15 [b]
