JohnFrance
Joined: 17 Sep 2014 Posts: 84 Location: Grenoble France
Posted: Thu Sep 03, 2015 4:47 am Post subject: Weight of Warpdrive tapered blade propeller? |
Hello to All,
Does anyone happen to know the weight of the Warpdrive 62" tapered blade propeller, XS spinner, it's support and all the necessary hardware?
I seem to remember seeing 6.7 kg for the propeller on it's own but I have been unable to find the information again now that I need it
The reason for this is to change the prop for an E Props, Durandal ground adjustable model that is supposed to give high takeoff rpm and then not over speed when in the cruise with their "clever" blade design.
If I get authorisation to go ahead from the French DGAC I will of course give feedback on performance compared to the Warpdrive on my Rotax 912 UL
John
_________________ Europa mono Nr 192 |
mau11(at)orange.fr Guest
Posted: Thu Sep 03, 2015 10:13 pm Post subject: Weight of Warpdrive tapered blade propeller? |
Hello John je t'envoie les panneaux du tableau de bord coté gauche et
droit, en dxf je n'ai plus solidworks c'est trop cher, sauf si je
trouvais une version déplombée... je peux te les donner aussi en DWG si
tu veux. Je terappelles utilises du 2017 dural 2 mm. c'est disponible
chez ANFI à seyssinet
Pour la butée de roulette de queue je recherche et te donnerai des
nouvelles.
MA
Le 03/09/2015 14:47, JohnFrance a écrit :
Hello to All,
John
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=446722#446722
This email has been protected by YAC (Yet Another Cleaner) http://www.yac.mx
TB_Coté_radio_05-12-2012.dxf |
2.72 KB |
492 Time(s) |
clivesutton
Posted: Thu Sep 03, 2015 11:52 pm Post subject: Re: Weight of Warpdrive tapered blade propeller? |
Hello John,
I happen to have these items as components sitting in my workshop - just weighed for you:
Each free blade is 925g
The spinner, glass back and front-plates as well as the metal clamp disc and nuts and bolts all together are 1325g
The magnesium tri-clamshell hub is 1545 including all nuts and bolts
regards,
Clive Sutton
