Weight of Warpdrive tapered blade propeller?
JohnFrance
PostPosted: Thu Sep 03, 2015 4:42 am    Post subject: Weight of Warpdrive tapered blade propeller? Reply with quote
Hello to All,
Does anyone happen to know the weight of the Warpdrive 62" tapered blade propeller, XS spinner, it's support and all the necessary hardware?
I seem to remember seeing 6.7 kg for the propeller on it's own but I have been unable to find the information again now that I need it
The reason for this is to change the prop for an E Props, Durandal ground adjustable model that is supposed to give high takeoff rpm and then not over speed when in the cruise with their "clever" blade design.
If I get authorisation to go ahead from the French DGAC I will of course give feedback on performance compared to the Warpdrive on my Rotax 912 UL
John
Europa mono Nr 192
