fdeloera
Joined: 02 Aug 2012 Posts: 4 Location: Phoenix, Arizona
Posted: Sun Aug 30, 2015 7:06 pm Post subject: Protective tape |
Does anyone know of a protective tape that I can put on the top edges of the side rails of my Firestar? As I work on the plane, the tops of the side rails get all beat-up and dirty. Maybe the tape will help.
Thanks in advance,
Fred
Phoenix
_________________ Fred
Phoenix |
lcottrell
Posted: Sun Aug 30, 2015 8:21 pm Post subject: Protective tape |
You can buy leading edge tape from Spruce I am sure in most sizes. It is rubber based, and really tough. I however took a thin piece of alum. beat it into a U over a like sized rod, placed it over the tubing and used a hammer to finish the bends around the rod.Larry
On Sun, Aug 30, 2015 at 9:06 PM, fdeloera <fdeloera(at)att.net (fdeloera(at)att.net)> wrote:
| Quote: | --> Kolb-List message posted by: "fdeloera" <fdeloera(at)att.net (fdeloera(at)att.net)>
Thanks in advance,
Fred
Phoenix
Fred
Phoenix
http://forums.matronics.com/viewtopic.php?p=446600#446600
FORUMS -
b Site -
-Matt Dralle, List Admin.
The older I get, the less tolerant I am of those who are intolerant.
Herbgh(at)nctc.com Guest
Posted: Mon Aug 31, 2015 3:36 am Post subject: Protective tape |
I used the same book binding tape that is used as aileron gap seal... Herb
On 08/30/2015 10:06 PM, fdeloera wrote:
Thanks in advance,
Fred
Phoenix
Fred
Phoenix
Signature text; This the byline area?
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Mon Aug 31, 2015 6:44 am Post subject: Re: Protective tape |
I used PVC tubing from Home Depot. Split it down the middle with a band saw then riveted it to the top of the tubes. Very light and has worked great so far.
Posted: Mon Aug 31, 2015 8:11 am Post subject: Protective tape |
All of these suggestions are good...but for simplicity and long lasting
and cheap..the book binding tape stays put...but will show the dirt on
the fabric !
