rickofudall
Posted: Sat Aug 22, 2015 7:07 am Post subject: Striping tape |
While reworking a friend's cowling I learned that striping tape is easy to get off, just shave it off with a single edge razor blade. Getting the tape's adhesive off is another matter. The stuff is absolutely tenacious and the solvents that remove it also remove Polytone. If you're thinking of using striping tape on fabric, make sure you really, REALLY like your paint job and have no intention of repainting at some point in the future. If you're unsure keep the striping tape away from glued joints or tapes as you are very likely to weaken or completely destroy their bond while trying to remove the adhesive.
Rick Girard
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
Herbgh(at)nctc.com Guest
Posted: Sat Aug 22, 2015 8:19 am Post subject: Striping tape |
I will put about 25 hours on this bird,sell it and move on to the Firestar project...
did not know that the better 3m tape leaves residue?? I have discovered that N Butanol seems to clean residues from Poly vinyl paints...Herb
On 08/22/2015 10:07 AM, Richard Girard wrote:
[quote] While reworking a friend's cowling I learned that striping tape is easy to get off, just shave it off with a single edge razor blade. Getting the tape's adhesive off is another matter. The stuff is absolutely tenacious and the solvents that remove it also remove Polytone. If you're thinking of using striping tape on fabric, make sure you really, REALLY like your paint job and have no intention of repainting at some point in the future. If you're unsure keep the striping tape away from glued joints or tapes as you are very likely to weaken or completely destroy their bond while trying to remove the adhesive.
Rick Girard
Signature text; This the byline area? [b]
ceengland7(at)gmail.com Guest
Posted: Sat Aug 22, 2015 10:46 am Post subject: Striping tape |
On August 22, 2015 11:19:21 AM CDT, Herb <Herbgh(at)nctc.com> wrote: | Quote: | I will put about 25 hours on this bird,sell it and move on to the Firestar project... did not know that the better 3m tape leaves residue?? I have discovered that N Butanol seems to clean residues from Poly vinyl paints...Herb On 08/22/2015 10:07 AM, Richard Girard wrote:
| Quote: | While reworking a friend's cowling I learned that striping tape is easy to get off, just shave it off with a single edge razor blade. Getting the tape's adhesive off is another matter. The stuff is absolutely tenacious and the solvents that remove it also remove Polytone. If you're thinking of using striping tape on fabric, make sure you really, REALLY like your paint job and have no intention of repainting at some point in the future. If you're unsure keep the striping tape away from glued joints or tapes as you are very likely to weaken or completely destroy their bond while trying to remove the adhesive.
Rick Girard
-- “Blessed are the cracked, for they shall let in the light.” Groucho Marx
| | Quote: | --
I'll bet there are some crossed electrons. There is tape to define painted stripes, and then there's tape that makes stripes...
Sent from my Android device with K-9 Mail. Please excuse my brevity. [quote][b]
