byoungplumbing(at)gmail.c Guest
Posted: Sat Aug 22, 2015 6:02 am Post subject: Kolb-List Digest: 9 Msgs - 08/21/15 |
If you can't pull the tape into a straight line,,, make it a curved line.... follow the scallops in the fabric...
Boyd [quote][b]
Herbgh(at)nctc.com Guest
Posted: Sat Aug 22, 2015 6:43 am Post subject: Kolb-List Digest: 9 Msgs - 08/21/15 |
Boyd
That became the straw that broke the camel's back...I made a straight line and pressed the tape into the scallops one at a time..trying not to stretch the tape....later..discovered that the tape had pulled loose.. !!
Boyd --
Signature text; This the byline area? [b]
Posted: Sat Aug 22, 2015 6:54 am Post subject: Kolb-List Digest: 9 Msgs - 08/21/15 |
By the way...did a static wt on the little puppy this morning...with 4.5 gals of gas...wt was 293....empty 266.. with full enclosure...not bad..for a Firefly Herb
On 08/22/2015 09:42 AM, Herb wrote:
[quote] Boyd
Boyd --
