Governor control cable
johnwigney(at)windstream.
PostPosted: Wed Aug 05, 2015 5:54 am    Post subject: Governor control cable Reply with quote
Hi Greg,
I use an A-750 vernier control with a blue knob from Aircraft Spruce for the Jihostroj governor which controls my WhirlWind constant speed prop. It has served perfectly since 2001. I do not remember the length but if you need any pics of the setup, please let me know.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
[img]cid:part2.04050608.08000907(at)windstream.net[/img][img]cid:part3.05030401.00030301(at)windstream.net[/img]
ORIGINAL MESSAGE
From: "Greg Fuchs " <gregoryf.flyboy(at)comcast.net> (gregoryf.flyboy(at)comcast.net)
Subject: governer control cable
Europhiles,
For those that have a hydraulic governor such as jihostroj, commonly used on 914 constant speed applications, what did you use for the control cable / where did you get it? I cannot seem to find any info on the normal 914 parts sites.
Thanks, Greg F
 Filesize:  145.22 KB
 Viewed:  2121 Time(s)
 Filesize:  33.23 KB
PostPosted: Wed Aug 05, 2015 7:14 am    Post subject: Governor control cable Reply with quote
Hi John,
Yes, by all means send me some pics. My setup is for the whirlwind as well. I especially want to know what kind of bracket you used to hold the cable (near the governor) and how long the shaft is that connects up to the swivel joint (I think I will have a tight turning radius). A few pics should answer all my questions. I have a bracket for another common aircraft that is supposed to work with the jihostroj, but it is not a good fit. It can be modified however, but there appears to be a bracket built-in at the top of the Rotax too that just might work, but I have not found any info on it yet..it is in the approximate correct position to potentially hold the cable.
I would also like a pic of where you placed the knob, and where the cabling went through the firewall as well. The cabling might be stiff and I am not sure I can get it to exit the top of the engine cage, similar to the throttle and choke cables.
My intention is to use a lever, and not a vernier, but it is all similar, except for the end. Vernier is the contingency plan if the lever doesn't work well.
Thanks much in advance!
Greg Fuchs A050
From: John Wigney [mailto:johnwigney(at)windstream.net]
Sent: Wednesday, August 05, 2015 6:53 AM
To: gregoryf.flyboy; Europa-List
Subject: Re: Governor control cable
Hi Greg,
Cheers, John
[img]cid:912325014(at)05082015-12A0[/img][img]cid:912325014(at)05082015-12A7[/img]
ORIGINAL MESSAGE
Europhiles,
Thanks, Greg F
 Filesize:  145.22 KB
 Viewed:  2117 Time(s)
 Filesize:  33.23 KB
