Herbgh(at)nctc.com Guest
byoungplumbing(at)gmail.c Guest
Posted: Mon Aug 10, 2015 10:11 am Post subject: Lift strut length...Firefly |
On my mkiii the instructions said that the bottom of the outside rib should be 1 1/2 inches higher than the inside... At that point I had negative roll stability. I doubled the diheaderal and the roll stability went to. Almost neutral.
Boyd Young On Aug 10, 2015 12:04 PM, "Herb" <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:[quote]--> Kolb-List message posted by: Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)>
Before anyone jumps at me for not reading the plans or build manual.....all Kolbs have some dihedral(another memory lapse)
54 inch lift struts is correct for the Firefly....a string from leading edge wing tip to wing tip should show about an inch dihedral at the middle of the string...Herb
FORUMS -
b Site -
-Matt Dralle, List Admin.
