Dee One
Posted: Fri Jul 17, 2015 11:40 pm Post subject: Flaparons vs flaps & ailerons |
I have only experience with flaps. What are the pros and cons of flaparons vs flaps and ailerons? Thanks for your experience, Dee
_________________ The Past is History
The Future is a Mystery
Today is a Gift
That’s Why They Call it the Present |
patrickjladd(at)hotmail.c Guest
Posted: Sat Jul 18, 2015 3:34 am Post subject: Flaparons vs flaps & ailerons |
Hi,
I only have experience in my old Challenger. Changing the angle of the
flaperon altered the trim considerably. Lowering the flaps for landing made
the plane nose heavy. Not uncontrollably so, just heavy on the stick. I
considered this a plus as if my attention wandered on the approach the plane
tended to go faster instead of slowing up and stalling.
I compromised on take off by only applying a little flap.. Not really
convinced it made much difference.
When building the Challenger we contrived a Bowden cable control for the
flaps with a small winding handle which enable the application of tiny
increments and an angle indicator in the cockpit.
For what iys worth.
Pat
colin.scott.hudson(at)gma Guest
Posted: Sat Jul 18, 2015 4:48 am Post subject: Flaparons vs flaps & ailerons |
In my case they are all con and no pro. I've got flaparons on my M3X. First off you loose a lot of square footage on your wing as the flaps are missing and the ailerons don't extend all the way across the aft portion of the wing. Major problem I have is the flaparons are much longer than the standard ailerons. In flight it takes excessive force to move them, to the point that I had to remove my dual controls as singles stick control gives more leverage. I never use my flaparons as I've noticed only a 2 knt improvement on stall speed and as hard as it is to get to the handle, it's not worth it. Kolb makes a larger 15 gal fuel tank for the M3X but I couldn't use it as the flaparons control tubes are in the way. I've actually talked with Kolb about coming to the factory and having my aircraft converted to normal flaps.
Scott Hudson
A/P ATP
N424AL
| Quote: | On Jul 18, 2015, at 2:39 AM, Dee LeBlanc <leblancds(at)cox.net> wrote:
russk50(at)gmail.com Guest
Posted: Sat Jul 18, 2015 6:11 am Post subject: Flaparons vs flaps & ailerons |
Dee
FWIW I’ve had no problems with flaperons on my Mk3Xtra. But I’ve never flown with separate flaps either
Russ K
| Quote: | On Jul 18, 2015, at 8:48 AM, Colin Hudson <colin.scott.hudson(at)gmail.com> wrote:
Scott Hudson
A/P ATP
N424AL
> Sent from my iPhone
rickofudall
Posted: Sat Jul 18, 2015 6:32 am Post subject: Flaparons vs flaps & ailerons |
I've only flown the 3C and 3X with flaps. With one notch of flaps both aircraft would take off without moving the stick in 200 to 250 feet even in no wind.I flew the Challenger 2 for a couple of hours when I had one in the shop. Big trim changes as Pat Ladd said.
Good luck,
Rick Girard
On Sat, Jul 18, 2015 at 9:10 AM, kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)> wrote:
| Quote: | --> Kolb-List message posted by: kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)>
Dee
Russ K
> On Jul 18, 2015, at 8:48 AM, Colin Hudson <colin.scott.hudson(at)gmail.com (colin.scott.hudson(at)gmail.com)> wrote:
> --> Kolb-List message posted by: Colin Hudson <colin.scott.hudson(at)gmail.com (colin.scott.hudson(at)gmail.com)>
> Scott Hudson
> A/P ATP
> N424AL
> Sent from my iPhone
>> On Jul 18, 2015, at 2:39 AM, Dee LeBlanc <leblancds(at)cox.net (leblancds(at)cox.net)> wrote:
>> --> Kolb-List message posted by: Dee LeBlanc <leblancds(at)cox.net (leblancds(at)cox.net)>
>> Sent from my iPhone
FORUMS -
b Site -
-Matt Dralle, List Admin.
Believe those who are seeking the truth, doubt those who find it.
-Andre Gide
