Herbgh(at)nctc.com Guest
byoungplumbing(at)gmail.c Guest
Posted: Tue Jul 07, 2015 7:47 am Post subject: horiz stab cables |
As I remember the contortions were not that bad... the top only braces, how big are they? Weight and drag? Is there a length maximum? If a tube got bent In flight,, (bird strike) would that lock up your elevator so it would not move? Have you put together a list of pros and cons.. maybe that is what you are doing now.
Kis. Keep it simple
Boyd
On Jul 7, 2015 8:40 AM, "Herb" <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:[quote]--> Kolb-List message posted by: Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)>
Just soliciting opinions... and I know the danger in that!!!
I can see that using two aluminum tubes to brace the top of the horizontal stab as is done with the two Mini Maxes that I have owned would be easily done...and would not require the contortion that is necessary to install the tension cables underneath the horiz stab... Just two tubes on top in compression and tension......that could be removed by pulling the clevis pins... would necessitate the installation of two brackets on each side...
Herb ...should have been flying the Firefly by now..!!!
Leland.Lam
Posted: Tue Jul 07, 2015 9:01 am Post subject: Re: horiz stab cables |
I just remade my Cable Tabs for the Horizontal Stab. I considered a few option as I don't need to fold my tail, but in the end I figured Mr. Kolb had a reason for the cables so I stayed with them. I did change the cable tabs due to the failures that have occurred. Attached is the print I made and a picture of the finished tabs.
56.03 KB |
14416 Time(s) |
58 KB |
14416 Time(s) |
Posted: Tue Jul 07, 2015 9:22 am Post subject: horiz stab cables |
Just thinking out loud...the top tube in tension and compression certainly works...for Wayne Ison...(UL hall of fame member, likely along with Homer?) designed his beefiest plane, the V Max that way, and others..
The difference is that the Horizontal stab on the Max does not hinge...is in one part...and therefore stronger to start with...
this modification would be more simple...than fitting the 4 cables...with adjustable fitting on one or both ends...and could be made from Cro Molly if necessary... Herb
Kis. Keep it simple
Boyd
On Jul 7, 2015 8:40 AM, "Herb" <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote: | Quote: | --> Kolb-List message posted by: Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)>
| [b]
Posted: Tue Jul 07, 2015 9:23 am Post subject: horiz stab cables |
Looking at the picture...what kind of bends did you make...The look
rather sharp ? Herb
On 07/07/2015 12:01 PM, Leland.Lam wrote:
Richard Pike
Posted: Tue Jul 07, 2015 10:25 am Post subject: Re: horiz stab cables |
Just thinking here - With the cable method, the strongest point of everything in the 4 cable system is the lower 7/8" chromemoly tube that ties into the tail wheel support and is welded to the aft boom ring. This provides the primary anchor for the whole system, which is kept at a high tension. Therefore, the cables not only hold the horizontal tail in place, they also hold the vertical tail in place.
If you tied every thing into the upper vertical fin instead, now your primary anchor point becomes a 1" .058 aluminum tube with the tie in point several feet above the boom tube where the horizontal tail can exert substantial leverage should it choose to wiggle or shake. You have removed the lower cables that keep the upper vertical tube from being able to move from side to side. The design relies on the cables to keep things rigid, now all it has to keep from bending from side to side is whatever strength is in the tube itself.
Check out this diagram listed as Page 20 in the construction manual and you'll see what I mean. Picture removing the 2 lower cables and replacing the upper cables with rigid tubing. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html
I am not an engineer, but your idea strikes me as being not nearly as strong, and not a good idea at all. You have completely redesigned all the inherent strength out of the tail assembly. I encourage you to at least get this idea looked at by more than one competent engineer before going ahead with it.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Last edited by Richard Pike on Tue Jul 07, 2015 10:30 am; edited 1 time in total |
Leland.Lam
Posted: Tue Jul 07, 2015 10:30 am Post subject: Re: horiz stab cables |
"Looking at the picture...what kind of bends did you make...The look
rather sharp ? Herb "
Herb,
Thank you for pointing that out. I too was somewhat concerned when I made these.
The bends were made in a Mill by bringing the Z axis Knee up into a pseudo forming die. There is a substantial radius on the far side surface. I was somewhat concerned about the 70 degree bend and the effect it would have on the overall strength, so I made an extra tab. I then made a test fixture cable using (7/7) 3/32" galvanized cable. I secured a thimble in place and clamped the assembly together using my Nico press and two copper sleeves.
I placed this system in tension until failure occurred. The cable broke and the steel remained unchanged. I then used a hardened steel bolt through the .193 and the .250 holes and placed this in tension until it failed using a 20 ton hydraulic press. The .193 hole failed not the bend.
I did not perform any test on the 20 or 45 degree tabs.
I realize these test are not completely scientific, but I do feel comfortable knowing the cable failed long before the tab.
A rough conservative guesstimate since I do not have a strain gauge at my disposal is the tab failed around 4000 Lbs of force
Leland
Posted: Tue Jul 07, 2015 11:58 am Post subject: horiz stab cables |
Too...your stainless brackets are much thicker than normal for these
attach points..
Herb
On 07/07/2015 01:30 PM, Leland.Lam wrote:
Herb,
Leland
http://forums.matronics.com/viewtopic.php?p=444526#444526
Posted: Tue Jul 07, 2015 12:01 pm Post subject: horiz stab cables |
Richard
That is why I posted in the first place....Your observations appear
to be on the money...so I will certainly give more thought to the whole
idea...and it was an idea to start...Not going to jump into a
modification without a lot of input...and thought...Herb
On 07/07/2015 01:25 PM, Richard Pike wrote:
Check out this diagram listed as Page 20 in the construction manual and you'll see what I mean. http://oh2fly.net/oldpoops/Lexan%20rear%20enclosure.html
I am not an engineer, but your idea strikes me as being not nearly as strong. Frankly, I think this is not a good idea at all. You have completely redesigned all the inherent strength out of the tail assembly. I encourage you to at least get this idea looked at by more than one competent engineer before going ahead with it.
Richard Pike
Kingsport, TN 3TN0
There are two kinds of people: those who say to God, 'Thy will be done,' and those to whom God says, 'All right, then, have it your way.'
http://forums.matronics.com/viewtopic.php?p=444525#444525
Posted: Tue Jul 07, 2015 1:38 pm Post subject: horiz stab cables |
I probably see things a little different than most folks. I
apologize for that.
Never had a problem with tail wires and tail post on the
Ultrastar or Firestar, but the MKIII configured the way mine
is is a different story. During the last 3,000+ hours I've
had the tail post fail 4 or 5 times, usually at the welds on
the lower tail boom ring or the tube separate just below
those welds. The reason it failed was all the side loads
from the tail wheel during taxi are concentrated at this
point.
Most folks refer to the tail wires at "tail wire bracing".
To me they are actually spacers that keep the vertical and
horizontal stabilizers located where they belong. Not much
bracing power to them, except for those welds at the tail
post ring that harden the tube and assist in failure.
We experimented many times with welded gussets, splices,
etc., to find a remedy for my tail post failures, but it was
Dan Horton, a local builder, that came up with the idea of
an external tail post brace that we welded from the tail
boom ring to the bottom of the tail post. Amazing how much
this stiffened the lateral movement of the tail post. I can
grab the top of the upper vertical stabilizer, shake it
laterally, and there is no give. Try that with your Kolb
and see the results. Since this fix, no more tail post
failures.
Several others have borrowed our fix. Most use aluminum
strap, bolting to the tail boom ring and the attachment bolt
for the tail wheel strut. No welding and fabric replacement
required.
I remember one year, back in the early 1990's at Oshkosh
while flying passengers in the Kolb Aircraft Company MKIII,
breaking the tail post as I turned onto the ultralight strip
to take off. This MKIII had very low hours, not nearly what
my MKIII has.
Another time my tail post broke within an hour of returning
from my last flight to Alaska in 2004. That would have
certainly put me in a bind had it happened a week or so
earlier.
I would not modify and fly with rigid braces on the tail
section on a Kolb.
I found some photos of my tail post and one of Gary Haley's
fix with aluminum strip and a couple bolts. It works.
Rock House, OR
145.54 KB |
14389 Time(s) |
179.04 KB |
14389 Time(s) |
234.6 KB |
14389 Time(s) |
134.82 KB |
14389 Time(s) |
_________________ John Hauck
Titus, Alabama |
Posted: Tue Jul 07, 2015 2:23 pm Post subject: horiz stab cables |
thanks for the refresher on your failures...been here long enough to
recall one or two of the incidents...
Side loads and hitting the rudder to get the break away tail wheel to
caster are the likely culprits. Probably cable stretch
contributed..? I think that replacing the cables top with and bottom
with tubing would stiffen the assy just as well as the additional
bracing... penalty would be a bit more drag... Then again...not what I
want to do....so....I shall go with a bit heavier cable and check/adjust
tension as part of pre flight.. secondly , I shall install a safety
strap in case of a failure of the tensioning bolt.. That little bolt has
worried me for years!! same with the top one ... Likely never been a
failure...however.... Herb
On 07/07/2015 04:38 PM, John Hauck wrote:
[quote] I probably see things a little different than most folks. I
apologize for that.
point.
failures.
required.
my MKIII has.
earlier.
section on a Kolb.
Rock House, OR
zeprep251(at)aol.com Guest
Posted: Tue Jul 07, 2015 3:02 pm Post subject: horiz stab cables |
Just take a half hour and install flat strap braces on the tail from the ring to the tail rod through bolt. Just do it.
[quote] On Jul 7, 2015, at 6:23 PM, Herb <Herbgh(at)nctc.com> wrote:
thanks for the refresher on your failures...been here long enough to recall one or two of the incidents...
Side loads and hitting the rudder to get the break away tail wheel to caster are the likely culprits. Probably cable stretch contributed..? I think that replacing the cables top with and bottom with tubing would stiffen the assy just as well as the additional bracing... penalty would be a bit more drag... Then again...not what I want to do....so....I shall go with a bit heavier cable and check/adjust tension as part of pre flight.. secondly , I shall install a safety strap in case of a failure of the tensioning bolt.. That little bolt has worried me for years!! same with the top one ... Likely never been a failure...however.... Herb
> apologize for that.
> point.
> failures.
> required.
> my MKIII has.
> earlier.
> section on a Kolb.
> john h
> Rock House, OR
