Reconsider Garmin Purchases
Site Admin
PostPosted: Wed Jun 17, 2015 10:13 am    Post subject: Reconsider Garmin Purchases Reply with quote
In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6.
I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior.
I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable.
Status: 182+ Hours TTSN - Version 2.0 Now Flying!
Status: 300+ Hours - Full Flyer Mode!
stein(at)steinair.com
PostPosted: Wed Jun 17, 2015 11:16 am    Post subject: Reconsider Garmin Purchases Reply with quote
This doesn't sound right. Sounds to me like someone just didn't want to deal
with you (and it likely wasn't Garmin in this case). I don't know what or
how you handled yourself, but sometimes you'll get more with honey than with
vinegar - or perhaps the person you spoke with perhaps was slightly
mis-informed.
To be blunt, the lenses should be readily available (at least they were last
time we got some). I'm sorry they aren't a $4 piece of plexi (there is some
fancy schmancy coatings on them and such), but the GTX lens is around $26
and I think the SL lens around $65.
My recommendation would be to calm down a bit, sit back and take a breath
before indicting Garmin in their entirety based on a conversation with one
person.
Not defending anyone or indicting or flaming anyone, but your experience
just sounds like we don't have the "whole story".....might I humbly suggest
that before blasting this to every list you manage that you perhaps speak to
someone else first (or maybe even Garmin directly)?
Stein
jjessen01
PostPosted: Wed Jun 17, 2015 11:48 am    Post subject: Reconsider Garmin Purchases Reply with quote
Yep. I got the same message for a $0.50 part for my SL-30. I just wanted the part. It can be replaced without opening the unit. Amazing arrogance.
deanpichon(at)msn.com
PostPosted: Wed Jun 17, 2015 12:26 pm    Post subject: Reconsider Garmin Purchases Reply with quote
A year ago, I replaced the lens on my SL-60.  Garmin sold it to me for $20 or so.  In May, I learned that after June 30, they will no longer service the SL-60 and a number of other SL products (-50, -60, -70).  I begrudgingly sent my (working) radio to Garmin and paid $550 for a flat rate repair.  I hope this (expensive) step gives me a few more years before my radio becomes worthless.  It is very frustrating that Garmin will no longer work on it and no one else can.
Date: Wed, 17 Jun 2015 11:10:36 -0700
To: rv-list(at)matronics.com
Subject: Reconsider Garmin Purchases
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
_====
Site Admin
PostPosted: Wed Jun 17, 2015 1:38 pm    Post subject: Reconsider Garmin Purchases Reply with quote
Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses.
Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00.
Matt
acepilot(at)bloomer.net
PostPosted: Wed Jun 17, 2015 2:00 pm    Post subject: Reconsider Garmin Purchases Reply with quote
I'm kind of going through the same thing with Wag Aero here in Wisconsin. I need replacement landing gear springs, but all they sell is a "kit" with the springs AND gear leg blanks. I do NOT intend to build a whole new landing gear...my legs are fine...just the srpings are shot. What a CROCK when a company will not sell replacement parts for "complete assemblies" they sell. Chaps my a$$ (ie, $300 just to get a set of springs)...
Ace
On 6/17/2015 6:10 PM, Matt Dralle wrote:
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com> (dralle(at)matronics.com)
[img]cid:part1.03080908.05080507(at)bloomer.net[/img]
 Filesize:  6 KB
 Viewed:  12458 Time(s)
HCRV6(at)comcast.net
PostPosted: Wed Jun 17, 2015 2:59 pm    Post subject: Reconsider Garmin Purchases Reply with quote
Matt,
No apology required or warranted, the only way suppliers will learn to treat their customers decently and to get their own house in order if that's the problem here, is to broadcast this kind of outrageous policy to the entire customer community. Maybe an abrupt drop in sales will get their attention. I for one just eliminated the G3X from consideration for my future panel upgrade unless this kind of BS ceases.
Harry Crosby
RV-6 N16CX, 1286 hours.
To: "RV-List" <rv-list(at)matronics.com>
Sent: Wednesday, June 17, 2015 2:36:32 PM
Subject: Re: Reconsider Garmin Purchases
Matt
For entertainment purposes only. h &nbsp=
ceengland7(at)gmail.com
PostPosted: Thu Jun 18, 2015 4:00 am    Post subject: Reconsider Garmin Purchases Reply with quote
I see no reason for an apology, and I'm glad you posted your experience. I've heard the exact same story (outrageous flat-rate fees for *any* repair, even a 'checkout') about Garmin for many years from many different owners. I've even experienced it myself, with Garmin wanting around $150 to replace the $4 backup battery in my GPS III Pilot portable. When I cornered a Garmin rep about it at a major flyin, he offered to give me a 'deal' at $70 if I sent it to his attention after the flyin. And the portable isn't even a 'certified' device.
BTW, I'd like to thank Matt for keeping these lists up and running and avoiding the ugliness of censorship, which is rampant on the VAF forum. For those who don't follow it closely, Matt's recent thread on the Garmin service subject didn't last a day before it was deleted (can't have one of your advertisers called out in public, can you.....). I sometimes go for much longer than I should without donating to Matt, and incidents like that remind me why I should donate every year.
On Wed, Jun 17, 2015 at 4:36 PM, Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)> wrote:
[quote]--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Matt
>Matt Dralle
ist" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV-List
Bob Collins
PostPosted: Thu Jun 18, 2015 5:58 am    Post subject: Reconsider Garmin Purchases Reply with quote
Just to put in my plug for the local guy.
When I first read Matt’s post, my thought was, “didn’t buy it from Stein.” Which is why I was also interested in Stein’s response.
Remember, this is a guy who took a personal bath a few years ago when the alternative was a big company was going to screw his customers.
So this is just a reminder to support those shops that have a history of supporting the RV community, especially those who ARE in the RV community. It makes a big difference.
Glad all of this worked out.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of HCRV6(at)comcast.net
Sent: Wednesday, June 17, 2015 5:59 PM
To: RV-List
Subject: Re: Re: Reconsider Garmin Purchases
Matt,
Harry Crosby
From: "Matt Dralle" <dralle(at)matronics.com (dralle(at)matronics.com)>
To: "RV-List" <rv-list(at)matronics.com (rv-list(at)matronics.com)>
Matt
For entertainment purposes only. h =
<         - The RV-List Email Forum -http://www.matronics.com/Navigator?RV-List
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/
vanremog(at)aol.com
PostPosted: Thu Jun 18, 2015 7:48 am    Post subject: Reconsider Garmin Purchases Reply with quote
I'd like to pipe up here and defend Matt as well. If we don't identify these issues, then we can't effect change. There are phases in the process of resolve issues. Near the top of the list is initial outrage at the injustice of a particular action.
Matt strikes me as a smart responsible individual and his outrage is understandable. If we are going to get a large corporation to rethink their strategy then we too need to stand up as say we're mad as hell and are not gong t take this anymore. Let Garmin know that there are consequences to their actions.
-GV
PostPosted: Thu Jun 18, 2015 1:51 pm    Post subject: Reconsider Garmin Purchases Reply with quote
I've also been successful with Wag Aero for replacement landing gear springs for my Corben.  Their complete "kit" of gear leg blanks and springs is $307.  I just got an email from them today and can get just what I need (the SPRINGS ONLY) for $49.50 each...so $100 vs $307.  Another win getting the grease (concession) applied to the squeaky wheel (ME!)...
Ace
On 6/18/2015 3:47 PM, vanremog(at)aol.com (vanremog(at)aol.com) wrote: [quote] I'd like to pipe up here and defend Matt as well.  If we don't identify these issues, then we can't effect change.  There are phases in the process of resolve issues.  Near the top of the list is initial outrage at the injustice of a particular action.
-GV
 Filesize:  6 KB
 Viewed:  12449 Time(s)
