JL2A
Posted: Thu May 28, 2015 3:55 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Hi all, my formation partner had a bit of engine trouble last time we flew then I took the same plane up for a shake down and got the same result -
cruise power, 10 minutes into the flight, engine cuts abruptly, goes, cuts again, goes. Mixture full rich, carb heat on, didn't do it again but then these items were actioned after running fine for a few seconds.
The cuts were hard, as in no power not just roughness, and only for a split second, but enough to get your attention.
Speaking to two local CJ/Yak experts and they say it is likely the 'mid-range' mixture adjustment (I think the CJ book calls it 'cruise' mixture, same thing).
Has anyone here experienced the same? Would be curious as to what an earth is going on, intermittent failures are the worst!
hkgibby(at)yahoo.com Guest
Posted: Thu May 28, 2015 4:46 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
I would say your mag coils are going bad after getting hot. Experienced it myself and know of another case and once mags were either replaced or at least the coil/s the problem disappeared. I would consult the experts directly though for more in-depth troubleshooting.
Good luck- Hoot
| Quote: | On May 28, 2015, at 4:55 PM, "JL2A" <info(at)flyingwarbirds.com.au> wrote:
http://forums.matronics.com/viewtopic.php?p=442717#442717
GeorgeCoy
Posted: Thu May 28, 2015 4:48 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
I suspect you're getting air in the system someplace. The pressure carburetor will not tolerate any air bubbles. Check the gas collator had all the fittings.
George
| Quote: | On May 28, 2015, at 7:55 PM, JL2A <info(at)flyingwarbirds.com.au> wrote:
Viperdoc
Posted: Thu May 28, 2015 5:48 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Mag coil going bad will also do that. Typically occurs about 10 to 15 minutes of the flight.
Doc
| Quote: | On May 28, 2015, at 6:55 PM, JL2A <info(at)flyingwarbirds.com.au> wrote:
_________________ Viperdoc |
migfighter42(at)gmail.com Guest
Posted: Thu May 28, 2015 7:04 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
my experience with that problem is the same as Doc mentioned. the aircraft would run fine until warmed up, normally in flight, then dramatic misses. replaced the coils in the magnetos, the problem went away.
Bill
Sent from my T-Mobile 4G LTE Device-------- Original message --------
Date: 05/28/2015 8:47 PM (GMT-06:00)
To: yak-list(at)matronics.com
Subject: Re: Yak-List: Engine roughness, as in stops. starts. stops. starts.
Doc
dantpayne(at)icloud.com Guest
Posted: Thu May 28, 2015 7:39 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Diving? 80 & 8?
Airspeed builds...engine starts to miss?
Dennis Savarese is the man to talk to...he will tell you the fix...I would tell you how to do it, but do not wish the glory...For Dennis informed me, and it worked.
Keep 'em Flyin',
Dan Payne
Owner, Pilot, A&P-IA
(423)-544-8946
Volunteer Aero
Dallas Bay Skypark
1824 E Crabtree Road
Hixson, TN 37343
"Where Airworthiness Means Business!"
On May 28, 2015, at 11:03 PM, migfighter42 <migfighter42(at)gmail.com (migfighter42(at)gmail.com)> wrote:
[quote]my experience with that problem is the same as Doc mentioned. the aircraft would run fine until warmed up, normally in flight, then dramatic misses. replaced the coils in the magnetos, the problem went away.
Bill
From: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
Subject: Re: Engine roughness, as in stops. starts. stops. starts.
--> Yak-List message posted by: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
Doc
| Quote: | On May 28, 2015, at 6:55 PM, JL2A <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)> wrote:
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)>
http://www.matronics.com/Navig==========================p; -====================================================nbsp; -Matt Dralle, List Admin.<===================================================
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž8^a©ŠËD™¨¥Šî™K¶ŒjÚèž',.+-溷¬5«â«h®Ú®Œ,zØ^™©ò.+-ºØ¥ŠØž²Ëœ…«ŠËTŸô®nÇ+Š›b¢p+r¯y'šÈC£ å¡§{ ¬®Œ,x(Z´P>-¢ÈZæ§vkœ†kœ†j+y¨kyøm¶ŸÿÃ&jÚèž',r‰¿5«â«h†¤.+-†Ûiÿü0Âf®‰ârÇ(›óZ¾(¶ŠØjBâ²ßÚ0Ñ8ÒIaäT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›ŠîšÆ¡çá¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿h¸¬´*'¶¸›ºØ¨g›J+^N§“*.~Šò¢êàzw«¢ë,ºšh®Ó¶ÐëjY^.+-Ù¢¨kyøm¶ŸÿÃ&jÚèž',r‰¿r‰í®&î¶*'†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢Úý¿ß¢{¦·¿n‡rþf
Posted: Thu May 28, 2015 7:42 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Also,
Have you pulled the top cover (MAG) and lubed the breaker felts with Machine oil (I.e. 3-1 singer seeing machine oil) ??
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero Sevive
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
&g==========================nbsp; - The Yak-List Email Forum -==========================nbsp; - MATRONICS WEB FORUMS -
--> http://forums.ma==========================nbsp; - List Contributnbsp; &nba href="http://www.matronics.com/contribution">http://www.matronics.com/co=========================================
Posted: Thu May 28, 2015 7:47 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Adjust the points/ breaker felts on the mags...
Let not forget the dwell timing / distributor advance in our GTOs we drove to high school...
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero Service
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
Posted: Thu May 28, 2015 7:51 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
I have to reapectfully disagree with Doc Kemp on that accord...I suspect a broken lead in the ignition harness, or a cracked ceramic in one if you 18 existing plugs...
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero Services
Dallas Bay Skypark
Hixson, TN 37343
On May 28, 2015, at 11:42 PM, Dan Payne <dantpayne(at)icloud.com (dantpayne(at)icloud.com)> wrote:
[quote]Also,
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
| Quote: | my experience with that problem is the same as Doc mentioned. the aircraft would run fine until warmed up, normally in flight, then dramatic misses. replaced the coils in the magnetos, the problem went away.
Bill
Doc
| | Quote: |
"3D"courier" new,courier"="">[url=3D"http://www.matronics.com/Navigator?Yak-List"]http://www.matronics.com/Navigator?Yak-List[/url]
Posted: Thu May 28, 2015 8:00 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
P.S.:
Why don't you all adjust your valves??
I do many annuals on "rich" people's airplanes who know nothing about Radials....
The engines are reliable. The airframes are bullet proof, and Denis Savarese is your go to guy on 4th & 10!
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
On May 28, 2015, at 11:46 PM, Dan Payne <dantpayne(at)icloud.com (dantpayne(at)icloud.com)> wrote:
[quote]Adjust the points/ breaker felts on the mags...
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
ist"">http://www.matronics.com/Navigator?Yak-List
Dawg
Posted: Thu May 28, 2015 9:01 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Adjust my what?? v-a-l-v-e-s? Like consonants?
You do many annuals? You must be “rich"
I’m not “rich”, no nothing about radials, why should I, we have guys like you that are willing to do it while we lounge by the pool, fly, camp, hike, bike, fly some more etc.So everyone gets what they want.
I see your company name says “Volunteer” well, don’t. Problem for you, solved.
Shot mine, NOT bullet proof.
Keep smiling.
Bill Geipel
Owner, pilot, not A&P-IA
can’t afford cell phone.
On May 29, 2015, at 1:00 PM, Dan Payne <dantpayne(at)icloud.com (dantpayne(at)icloud.com)> wrote:
[quote]P.S.:
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
| Quote: | Adjust the points/ breaker felts on the mags...
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
http://www.matronics.com/Navig==========================p; -===========================nbsp; -Matt Dralle, List Admin.<==========================
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
_________________ Dawg |
Posted: Thu May 28, 2015 9:14 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Do you "no" or "Know" nothing about radials?
I'm not on this list to get into a dick measuring contest. Your wife may be hotter than mine, but I can assure you that I pay more attention to my airplanes than my own "better half"
Let me remind you we are all on this list to help each other...
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero
Dallas Bay Skypark
Hixson, TN 37343
On May 29, 2015, at 1:01 AM, Bill Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
[quote]Adjust my what?? v-a-l-v-e-s? Like consonants?
Keep smiling.
Bill Geipel
| Quote: | P.S.:
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
Posted: Thu May 28, 2015 9:20 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Ps....if you throw fuel to it mid-flight and it burst back to life...I would suspect a worn out engine driven pump..
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero
Dallas Bay Skypark
Hixson, TN 37343
Keep smiling.
Bill Geipel
| Quote: | P.S.:
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
Posted: Thu May 28, 2015 9:28 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
However..."engine cuts abruptly, goes, cuts again, goes. Mixture full rich, carb heat on, didn't do it again but then these items were actioned after running fine for a few seconds."
If you went full rich, then turned on the carb heat (making the mixture even more rich) that's answers you own dilemma / question.
Change the fuel pump
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
On May 29, 2015, at 1:19 AM, Dan Payne <dantpayne(at)icloud.com (dantpayne(at)icloud.com)> wrote:
[quote]Ps....if you throw fuel to it mid-flight and it burst back to life...I would suspect a worn out engine driven pump..
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero
Dallas Bay Skypark
Hixson, TN 37343
| Quote: | Adjust my what?? v-a-l-v-e-s? Like consonants?
Keep smiling.
Bill Geipel
| Quote: | P.S.:
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
richard.goode(at)russiana Guest
Posted: Thu May 28, 2015 11:56 pm Post subject: Engine roughness, as in stops. starts. stops. starts. |
Without any doubt the problem will be a magneto coil - we have experienced
this on at least 30 aircraft over the last 25 years! The important point is
that it is related to engine temperature, so only becomes apparent after
15/25 minutes of flight. If you then land and allow the engine to cool, the
problem will disappear. But, it will get steadily worse.
One aspect that I have never understood is that the engine will cut
completely, usually only for a second or so but still very alarming, and it
does not seem to run on the other magneto for that brief period!
This is why, when we overhaul magnetos we then test them in a
high-temperature box (well in excess of operating temperatures) for an hour
to make sure that this problem will not happen.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
JL2A
Posted: Fri May 29, 2015 4:40 am Post subject: Re: Engine roughness, as in stops. starts. stops. starts. |
Hi all, thanks for the on and off list replies. Very greatly appreciated believe me, the owner has delivered the aircraft to the mechanics and they were starting with their belief it is the mixture setting.
He has been informed and will be starting with new magneto coils instead now though!
I had a points spring break on one mag once, so it killed the mag completely and I do remember an attention-grabbing splutter and then the engine continued sounding more or less normal (was at low power on base). Strange how one mag dropping off seems to momentarily affect the other...
PS how good are forums! no way we would have got this analysis so quick anytime before, and while some of it dubious, absolutely no different to riding around to a different mechanics/pilots hangar and asking their opinion
Posted: Fri May 29, 2015 5:44 am Post subject: Engine roughness, as in stops. starts. stops. starts. |
If its the fuel pump, you should see it on the fuel pressure gauge.
if it is the valve train, that should be a problem noticed at all times, a loss of perforce irrespective of time and temperature.
If it is always happening after a certain period of time in flight everytime, its coil related. We had this exact problem a year ago, took us forever to find it. Dennis and Jill finally got us on the right path.
Good luck.
Bill
Date: 05/29/2015 12:28 AM (GMT-06:00)
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
[quote]Ps....if you throw fuel to it mid-flight and it burst back to life...I would suspect a worn out engine driven pump...
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Volunteer Aero
Dallas Bay Skypark
Hixson, TN 37343
Keep smiling.
Bill Geipel
| Quote: | P.S.:
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
(423)-544-8946
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
Ernie
Posted: Fri May 29, 2015 5:55 am Post subject: Engine roughness, as in stops. starts. stops. starts. |
Quick question.
Wouldn't a coil problem only manifest itself on 1 side? A complete loss of 1 Mag shouldn't cause an abrupt and complete loss of power should it?
Ernie
On Fri, May 29, 2015 at 9:43 AM, migfighter42 <migfighter42(at)gmail.com (migfighter42(at)gmail.com)> wrote:
[quote]If its the fuel pump, you should see it on the fuel pressure gauge.
Good luck.
Bill
From: Dan Payne <dantpayne(at)icloud.com (dantpayne(at)icloud.com)>
Keep 'em Flyin',
Dan Payne
[url=tel:%28423%29-544-8946](423)-544-8946[/url]
Dallas Bay Skypark
Hixson, TN 37343
| Quote: | Ps....if you throw fuel to it mid-flight and it burst back to life...I would suspect a worn out engine driven pump...
Keep 'em Flyin',
Dan Payne
Volunteer Aero
Dallas Bay Skypark
Hixson, TN 37343
Keep smiling.
Bill Geipel
| Quote: | P.S.:
Keep 'em Flyin',
Dan Payne
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§ r‹«‰êç{ (º¸ž8^a© ŠËD™¨¥ Šî™K ¶ ŒjÚèž',.+- 溷¬5«â «h®Ú ®Œ,zØ^™©ò.+-ºØ¥ŠØž²Ëœ…« ŠËTŸô®nÇ+Š›b¢p+r ¯y'šÈC£ å¡§{ ¬ ®Œ,x(Z´P > -¢ÈZæ§vkœ†kœ†j+y¨kyøm¶ŸÿÃ&jÚèž',r‰¿5«â «h†¤.+-†Ûiÿü0Âf®‰ârÇ(›óZ¾( ¶ŠØjBâ²ßÚ0 Ñ8Ò Ia äT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg› ŠîšÆ¡çá¶Ú ýú+ºk&jÚèž',r‰¡¶Ú ýú+ºk&jÚèž',r‰¿h¸¬´*'¶¸›ºØ¨ g›J+^N §“*.~Šò¢êàzw«¢ë,ºšh®Ó ¶ÐëjY^.+- Ù¢ ¨kyøm¶ŸÿÃ&jÚèž',r‰¿r‰í®&î¶*'†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢ Úý¿ß¢{ ¦·¿n‡rþ f
et="_blank">http://www.matronics.com/Navigator?Yak-List
Posted: Fri May 29, 2015 6:15 am Post subject: Engine roughness, as in stops. starts. stops. starts. |
That is what one would assume, and I have no explanation for the fact that the coil beginning to break down in one magneto will cause rough running and indeed stopping, but it definitely does!
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Ernest Martinez
Sent: 29 May 2015 14:55
To: yak-list
Quick question.
Ernie
Good luck.
Bill
Keep 'em Flyin',
Dan Payne
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
Volunteer Aero
Dallas Bay Skypark
Hixson, TN 37343
Keep smiling.
Bill Geipel
P.S.:
Keep 'em Flyin',
Dan Payne
Dallas Bay Skypark
Hixson, TN 37343
Keep 'em Flyin',
Dan Payne
Dallas Bay Skypark
Hixson, TN 37343
Bill
Doc
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§ r‹«‰êç{ (º¸ž8^a© ŠËD™¨¥ Šî™K ¶ ŒjÚèž',.+- 溷¬5«â «h®Ú ®Œ,zØ^™©ò.+-ºØ¥ŠØž²Ëœ…« ŠËTŸô®nÇ+Š›b¢p+r ¯y'šÈC£ å¡§{ ¬ ®Œ,x(Z´P > -¢ÈZæ§vkœ†kœ†j+y¨kyøm¶ŸÿÃ&jÚèž',r‰¿5«â «h†¤.+-†Ûiÿü0Âf®‰ârÇ(›óZ¾( ¶ŠØjBâ²ßÚ0 Ñ8Ò Ia äT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg› ŠîšÆ¡çá¶Ú ýú+ºk&jÚèž',r‰¡¶Ú ýú+ºk&jÚèž',r‰¿h¸¬´*'¶¸›ºØ¨ g›J+^N §“*.~Šò¢êàzw«¢ë,ºšh®Ó ¶ÐëjY^.+- Ù¢ ¨kyøm¶ŸÿÃ&jÚèž',r‰¿r‰í®&î¶*'†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢ Úý¿ß¢{ ¦·¿n‡rþ f D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dist"">http://www.matronics.com/Navigator?Yak-ListD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D//forums.matronics.comD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dot;">http://www.matronics.com/contributionD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | | 012345
6789 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 1 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 2 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 3 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 4 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 5
D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 6 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 7 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 8 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 9012345
ist"">http://www.matronics.com/Navigator?Yak-List | 6789 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 1
| Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 2 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 3 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 4 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 5 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 6 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 7 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 8 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 90123456789
believed to be clean.
Posted: Fri May 29, 2015 7:17 am Post subject: Engine roughness, as in stops. starts. stops. starts. |
Yes, it does Ernie. If you've never experienced a coil failure in one
mag, I can tell you it WILL get your attention because if feels like the
engine completely shuts down for one heartbeat, then picks back up again.
I was told by someone with a lot more life experiences than me that
another older radial (can't remember if it was one of the small
Continental's like was used on the Stearmanor Wright or Pratt)the
engineers determined when the coil failed like being discussed here, the
fuel charge through the supercharger (ie: fuel distribution point) is
completely purged for one heartbeat causing the sensation of a complete
shutdown for a few millisecondsand then recharged and the engine picks
back up. It's really weird. But I can tell you from many experiences,
that's what it feels like. Maybe someone onthe list can better define
why it feels like a complete shutdown for a heartbeat.
FWIW, I have been able to duplicate the problem on the ground by heating
up the engine to above about 250 degrees C as read on the CHT. As
Richard Goode has stated, it definitely is a heat problem with the coil
which typically occurs in the first 20-30 minutes of the flight.
Repeating it on the ground is more difficult. But it can be done. If you
can get the coil hot enoughon the ground, the engine will start to
misfire. Once THAT occurs, you can isolate the problem to the left or
right mag with the mag switch.
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 5/29/2015 8:54 AM, Ernest Martinez wrote:
| Quote: | Quick question.
should it?
Ernie
right path.
Good luck.
Bill
From: Dan Payne <dantpayne(at)icloud.com <mailto:dantpayne(at)icloud.com>>
To: yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
stops. starts.
Keep 'em Flyin',
Dan Payne
(423)-544-8946 <tel:%28423%29-544-8946>
Dallas Bay Skypark
Hixson, TN 37343
> Keep 'em Flyin',
> Dan Payne
> Volunteer Aero
> Dallas Bay Skypark
> Hixson, TN 37343
>> for you, solved.
>> Keep smiling.
>> Bill Geipel
>>> P.S.:
>>> about Radials....
>>> Keep 'em Flyin',
>>> Dan Payne
>>> Dallas Bay Skypark
>>> Hixson, TN 37343
>>>> Keep 'em Flyin',
>>>> Dan Payne
>>>> Dallas Bay Skypark
>>>> Hixson, TN 37343
>>>>> Bill
>>>>> <mailto:f16viperdoc(at)me.com>>
>>>>> stops. starts.
>>>>> <f16viperdoc(at)me.com <mailto:f16viperdoc(at)me.com>>
>>>>> Doc
>>>>> Sent from my iPad
>>>>> <mailto:info(at)flyingwarbirds.com.au>> wrote:
>>>>> <info(at)flyingwarbirds.com.au <mailto:info(at)flyingwarbirds.com.au>>
>>>>> worst!
>>>>> > Read this topic online here:
>>>>> ¶ÐëjY^.+- Ù¢
>>>>> ¦·¿n‡rþ f
>>>> //forums.matronics.com <http://forums.matronics.com>
>>> href="http://forums.matronics.com/">http://forums.matronics.com
>>> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D <http://www.matronics.com/Navigator?Yak-ListD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>
> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D <http://www.matronics.com/contributionD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D>
