Radioflyer
Posted: Mon Apr 27, 2015 4:26 pm Post subject: Starter Solenoid behavior with low Battery |
Recently my battery fell below 11 volts and so it could not provide enough power to completely turn over my engine. What surprised me more than the low battery was that after switching off my master and then switching it back on again, the starter attempted to turn the engine. Wow, the master isn't supposed to control the starter solenoid!
After charging the battery, the master and starter switches returned to normal operation and the engine started perfectly many times. All was good and I eventually figured out why my battery discharged. However, that still left me wondering how the master switch could possibly activate the starter solenoid without my pushing the start switch. My theory is that the low voltage only partially (weekly) engaged the starter solenoid spring and therefore the spring didn't exert full force to open the solenoid after it was de-energized. I'm not yet ready to conclude that the starter solenoid is actually defective. Anybody also experienced this?
--Jose
dfilkins(at)impulse.net Guest
Posted: Mon Apr 27, 2015 5:42 pm Post subject: Starter Solenoid behavior with low Battery |
At that low voltage the starter became a short because the armature was not turning. No back EMF. The starter solenoid may have welded the contacts and the internal spring was unable to push the contacts apart. I suggest you change the starter solenoid. I had this happen on my orchard wind machine,
Dale
Joined: 28 Mar 2008 Posts: 1961 Location: Riley TWP Michigan
Posted: Mon Apr 27, 2015 7:06 pm Post subject: Re: Starter Solenoid behavior with low Battery |
Cranking the engine with a low battery is very hard on the starter contactor because the contacts are not held tightly closed. The contacts arc and weld closed. Replace the starter contactor.
Joe
_________________ Joe Gores |
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Tue Apr 28, 2015 8:11 am Post subject: Re: Starter Solenoid behavior with low Battery |
Cessna Pilots Association (CPA) has recently uncovered a common error where starter contactors are sometimes installed upside down and where the weight of the plunger is working against plunger return spring. Contactors should always be installed with the case swaged lip facing DOWN. Terminal Studs should be nearer the bottom of the contactor, rather than the top. Unfortunately, some new contactors are appearing with labels inverted, which adds to the problem.
Even with the case lip facing down, CPA suggests adding sealant around the case perimeter at the lip to keep moisture out.
Ref: CPA Magazine, April 2015, p.47
_________________ Jerry King |
