jblake207(at)comcast.net Guest
Posted: Fri Apr 10, 2015 11:09 am Post subject: IFR Certification |
Does anyone have any recommendations for certifying a standard CJ6 for IFR ops here in the States? I am a seasoned instrument pilot and keep current in my Piper Arrow, so currency is not really an issue. As for instrumentation on the CJ... I'm installing a second radio a KX155 with Glide slope, 28V electric Western-style DG along with a new turn and bank indicator. I plan to use my hand-held Garmin for Direct once enroute and approved by ATC, but not for approaches. I'm keeping the Chinese attitude indicator. I'm also thinking about a new Trio AP... The intent is to not necessarily fly the airplane down to a Cat 1 approach minimums, rather to be able to recover to home base on a Sunday afternoon when weather is slightly less than VFR. One concern is possibly carb ice... even though my carb heat works, it isn't the greatest in the world. My peter heater works fine. So, having said all that as background, any words of wisdom are welcome.
Jon Blake
Ernie
Posted: Fri Apr 10, 2015 11:17 am Post subject: IFR Certification |
Jon,
Its experimental exhibition, as long as you have the appropriate radios and instruments and you're rated, and you have the IFR check done, you should be good to go if in a pinch you needed to file in your airplane. I do not believe there is any sort of certification of the airplane required.
Even a certified airplane, if I recall correctly doesn't have to have any special IFR certification, just the equipment to be TSO'd for that airplane. But I do recall someone having to go for a test flight in my Dakota after the installation of a Sandel and 430, and he did do some sort of sign off, so I may be wrong.
I had a 430 in my last CJ, and I used to file /G (not that I filed all that often, remember me and clouds That said, all I did was have the obligatory IFR check done by my local avionics shop and that was it.
On Fri, Apr 10, 2015 at 3:08 PM, <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
[quote]Does anyone have any recommendations for certifying a standard CJ6 for IFR ops here in the States? I am a seasoned instrument pilot and keep current in my Piper Arrow, so currency is not really an issue. As for instrumentation on the CJ... I'm installing a second radio a KX155 with Glide slope, 28V electric Western-style DG along with a new turn and bank indicator. I plan to use my hand-held Garmin for Direct once enroute and approved by ATC, but not for approaches. I'm keeping the Chinese attitude indicator. I'm also thinking about a new Trio AP... The intent is to not necessarily fly the airplane down to a Cat 1 approach minimums, rather to be able to recover to home base on a Sunday afternoon when weather is slightly less than VFR. One concern is possibly carb ice... even though my carb heat works, it isn't the greatest in the world. My peter heater works fine. So, having said all that as background, any words of wisdom are welcome.
Jon Blake
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
Ernie
Posted: Fri Apr 10, 2015 11:20 am Post subject: IFR Certification |
http://aviation.stackexchange.com/questions/1378/what-are-the-faa-requirements-for-an-aircraft-to-be-ifr-certified
On Fri, Apr 10, 2015 at 3:17 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]Jon,
| Quote: | Does anyone have any recommendations for certifying a standard CJ6 for IFR ops here in the States? I am a seasoned instrument pilot and keep current in my Piper Arrow, so currency is not really an issue. As for instrumentation on the CJ... I'm installing a second radio a KX155 with Glide slope, 28V electric Western-style DG along with a new turn and bank indicator. I plan to use my hand-held Garmin for Direct once enroute and approved by ATC, but not for approaches. I'm keeping the Chinese attitude indicator. I'm also thinking about a new Trio AP... The intent is to not necessarily fly the airplane down to a Cat 1 approach minimums, rather to be able to recover to home base on a Sunday afternoon when weather is slightly less than VFR. One concern is possibly carb ice... even though my carb heat works, it isn't the greatest in the world. My peter heater works fine. So, having said all that as background, any words of wisdom are welcome.
Jon Blake
Posted: Fri Apr 10, 2015 11:57 am Post subject: IFR Certification |
Good stuff Ernie... many thanks. See you at SNF in a couple weeks. JB
To: "Yak-List" <yak-list(at)matronics.com>
Sent: Friday, April 10, 2015 2:19:50 PM
Subject: Re: IFR Certification
| Quote: | Jon,
Jon Blake
et=_blank>http://www.matronics.com/Navigator?Yak-List
dabear
Joined: 21 Jan 2011 Posts: 92 Location: Warrenton, VA
Posted: Fri Apr 10, 2015 4:08 pm Post subject: IFR Certification |
I took out ALL my Chinese wiring and put in three 10” Dynon EFIS panels (2 in front pit, 1 in back), 2 axis autopilot, dual adhars, etc. and got the log book entry for IFR. I’ve flown it IFR (NO LOW IFR) some and really recommend the auto pilot I’ve flown dozens of approaches (real/hood) with it and it is a good plane but I still would recommend the AP.
Check out the Dynon D2 backup instrument (attitude, alitimeter, heading, etc.) gps based for not a lot of cash.
Let me know if you have any questions.
Bear
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of jblake207(at)comcast.net
Sent: Friday, April 10, 2015 3:09 PM
To: Yak-List
Subject: IFR Certification
Jon Blake
| Quote: | | http://www.matronics.com/Navigator?Yak-List | 01234567
Posted: Fri Apr 10, 2015 6:09 pm Post subject: IFR Certification |
Thanks Bear... Good stuff. JB
Sent from my Verizon Wireless 4G LTE DROID
Bear
To: Yak-List
Subject: Yak-List: IFR Certification
Jon Blake
clouddog22(at)gmail.com Guest
Posted: Sat Apr 11, 2015 5:50 am Post subject: IFR Certification |
John, First I would check you Operating Limitations to make sure your airplane has been blessed for IFR or as I would say you are not restricted to VFR only. My OPS Specs says my airplane is approved for VFR and IFR. If not, then that opens up another can of worms to get it changed. If your good there then FAR91 says you need day and night VFR stuff plus the IFR Specific instruments. Approved and current updates if your using a GPS, log of VOR checks if using a VOR for navigation and obviously the pitot static and transponder and encoder. Current charts electronic or paper and don't mention the crazy Chinese attitude indicator. But if you are IFR using that indicator, I believe your asking for trouble in an upset recovery. I'm going through same process as you and Ernie. I don't gave or want an all glass cockpit. It would be nice but U really don't plan on flying hard IFR. An autopilot is a MUST with single pilot IFR. I'll be looking at an extra radio and the TRIO autopilot at Sun n Fun. Take care. On Apr 10, 2015 9:11 PM, "Jon Blake" <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:[quote]Thanks Bear... Good stuff. JB
Bear
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of jblake207(at)comcast.net (jblake207(at)comcast.net)
To: Yak-List
Jon Blake
01234567
8[b]
Posted: Sat Apr 11, 2015 8:11 am Post subject: IFR Certification |
Good advice and info Greg. Before you buy your AP at SNF, let's go together and maybe they'll give us the brother-in-law discount. Looking forward to seeing you there. Jon
Bear
To: Yak-List
Jon Blake
01234567
8[b]
Posted: Sat Apr 11, 2015 8:21 am Post subject: IFR Certification |
Works for me
I'll be there Monday-Thursday On Apr 11, 2015 11:16 AM, "Jon Blake" <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:[quote]Good advice and info Greg. Before you buy your AP at SNF, let's go together and maybe they'll give us the brother-in-law discount. Looking forward to seeing you there. Jon
Greg Wrobel <clouddog22(at)gmail.com (clouddog22(at)gmail.com)> wrote:
John, First I would check you Operating Limitations to make sure your airplane has been blessed for IFR or as I would say you are not restricted to VFR only. My OPS Specs says my airplane is approved for VFR and IFR. If not, then that opens up another can of worms to get it changed. If your good there then FAR91 says you need day and night VFR stuff plus the IFR Specific instruments. Approved and current updates if your using a GPS, log of VOR checks if using a VOR for navigation and obviously the pitot static and transponder and encoder. Current charts electronic or paper and don't mention the crazy Chinese attitude indicator. But if you are IFR using that indicator, I believe your asking for trouble in an upset recovery. I'm going through same process as you and Ernie. I don't gave or want an all glass cockpit. It would be nice but U really don't plan on flying hard IFR. An autopilot is a MUST with single pilot IFR. I'll be looking at an extra radio and the TRIO autopilot at Sun n Fun. Take care. On Apr 10, 2015 9:11 PM, "Jon Blake" <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote: | Quote: | Thanks Bear... Good stuff. JB
Bear
To: Yak-List
Jon Blake
01234567
8 | 9[b]
dabear
Posted: Sat Apr 11, 2015 8:48 am Post subject: IFR Certification |
I know you said you don’t want a glass cockpit, but while there, check out the Dynon booth. At least check out the D2 as a backup for ~$1,000 ; http://dynonavionics.com/docs/PocketPanel.html
Here is quick picture of my pit… Note: it’s in the hangar so synthetic vision isn’t on.
Bear
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Greg Wrobel
Sent: Saturday, April 11, 2015 12:21 PM
To: yak-list(at)matronics.com
Works for me
On Apr 11, 2015 11:16 AM, "Jon Blake" <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote: | Quote: |
Bear
To: Yak-List
Jon Blake
01 | 234567 | 890123456789012345
1.7 MB |
6018 Time(s) |
Posted: Sat Apr 11, 2015 10:35 am Post subject: IFR Certification |
Cool panel. Very attractive. JB
| Quote: | <!-- /* Font Definitions */ (at)font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;} (at)font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} (at)font-face {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman",serif;} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} a:visited, span.MsoHyperlinkFollowed {mso-style-priority:99; color:purple; text-decoration:underline;} p {mso-style-priority:99; mso-margin-top-alt:auto; margin-right:0in; mso-margin-bottom-alt:auto; margin-left:0in; font-size:12.0pt; font-family:"Times New Roman",serif;} pre {mso-style-priority:99; mso-style-link:"HTML Preformatted Char"; margin:0in; margin-bottom:.0001pt; font-size:10.0pt; font-family:"Courier New";} span.HTMLPreformattedChar {mso-style-name:"HTML Preformatted Char"; mso-style-priority:99; mso-style-link:"HTML Preformatted"; font-family:Consolas;} span.EmailStyle20 {mso-style-type:personal-reply; font-family:"Calibri",sans-serif; color:#1F497D;} .MsoChpDefault {mso-style-type:export-only; font-family:"Calibri",sans-serif;} (at)page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in;} div.WordSection1 {page:WordSection1;} -->
Bear
Subject: Re: Yak-List: IFR Certification
Works for me
Bear
To: Yak-List
Jon Blake
http://forums.matronics.com
Viperdoc
Posted: Sat Apr 11, 2015 6:38 pm Post subject: IFR Certification |
I could see that in the 50! Nice panel DeBear!
Doc
On Apr 11, 2015, at 1:32 PM, Jon Blake <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
[quote]Cool panel. Very attractive. JB
Bear
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Greg Wrobel
Works for me
I took out ALL my Chinese wiring and put in three 10†Dynon EFIS panels (2 in front pit, 1 in back), 2 axis autopilot, dual adhars, etc. and got the log book entry for IFR. I’ve flown it IFR (NO LOW IFR) some and really recommend the auto pilot I’ve flown dozens of approaches (real/hood) with it and it is a good plane but I still would recommend the AP.
Bear
To: Yak-List
Jon Blake
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž8^a©ŠËD™¨¥Šî™K¶ŒjÚèž',.+-溷¬5«â«h®Ú®Œ,zØ^™©ò.+-ºØ¥ŠØž²Ëœ…«ŠËTŸô®nÇ+Š›b¢p+r¯y'šÈC£ å¡§{ ¬®Œ,x(Z´P>-¢ÈZæ§vkœ†kœ†j+y¨kyøm¶ŸÿÃ&jÚèž',r‰¿5«â«h†¤.+-†Ûiÿü0Âf®‰ârÇ(›óZ¾(¶ŠØjBâ²ßÚ0Ñ8ÒIaäT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›ŠîšÆ¡çá¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿h¸¬´*'¶¸›ºØ¨g›J+^N§“*.~Šò¢êàzw«¢ë,ºšh®Ó¶ÐëjY^.+-Ù¢¨kyøm¶ŸÿÃ&jÚèž',r‰¿r‰í®&î¶*'†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢Úý¿ß¢{¦·¿n‡rþf
_________________ Viperdoc |
