Engine Bolts
MJKTuck(at)cs.com
PostPosted: Wed Apr 08, 2015 5:56 pm    Post subject: Engine Bolts Reply with quote
Hi Folks,
I'm changing out the rubber engine mounts and performing Mo 72. I had a
terrible job getting the split pins out of the two lower engine mounting
bolts. I was thinking, is there anything preventing me from reinstalling
these lower bolts backwards so I can easily get the split pins back in?
Good idea or not advisable?
Martin Tuck
N152MT
kingsnjan(at)westnet.com.
PostPosted: Thu Apr 09, 2015 1:29 am    Post subject: Engine Bolts Reply with quote
Martin,
I inserted mine from the rear. SO much easier as you suggest. Have to wonder why it wasn't called out in the manual??
Best regards
Kingsley in Oz.
On 9 Apr 2015, at 11:55 am, Martin Tuck <MJKTuck(at)cs.com> wrote:
I'm changing out the rubber engine mounts and performing Mo 72. I had a terrible job getting the split pins out of the two lower engine mounting bolts. I was thinking, is there anything preventing me from reinstalling these lower bolts backwards so I can easily get the split pins back in? Good idea or not advisable?
John Wighton
PostPosted: Thu Apr 09, 2015 2:14 am    Post subject: Re: Engine Bolts Reply with quote
Martin,
There should be no structural reason why the bolt needs to be aligned in a particular direction, as they are fore-aft the 'normal' convention (for vertical bolts) does not apply.
Reading the manual (XS 912 installation) it states that the AN5-41 should be mounted lower two pointing forward and upper two pointing aft. This applies to the MT05 mount.
But for the Classic with the MT01 mount the orientation shows the lower bolts as pointing aft.
John
 Filesize:  160 KB
 Viewed:  6331 Time(s)
John Wighton
Europa XS trigear G-IPOD
MJKTuck(at)cs.com
PostPosted: Thu Apr 09, 2015 4:03 am    Post subject: Engine Bolts Reply with quote
Thanks John, they must have changed the manual at some point. I would have used the first set of instructions ( pre-official manual).
Martin
On Apr 9, 2015, at 5:14 AM, John Wighton <john(at)wighton.net> wrote:
Martin,
John
John Wighton
http://forums.matronics.com/viewtopic.php?p=440481#440481
http://forums.matronics.com//files/912_xs_174.jpg
John Wighton
PostPosted: Thu Apr 09, 2015 12:10 pm    Post subject: Re: Engine Bolts Reply with quote
Martin,
They are all online now.
See: http://www.europa-aircraft.com/assistance/manuals.php
John
John Wighton
MJKTuck(at)cs.com
PostPosted: Thu Apr 09, 2015 2:49 pm    Post subject: Engine Bolts Reply with quote
Thanks John, never knew they were there!
All the best,
Martin
On Apr 9, 2015, at 3:10 PM, John Wighton <john(at)wighton.net> wrote:
Martin,
John
John Wighton
http://forums.matronics.com/viewtopic.php?p=440528#440528
