w0odi
Posted: Sun May 03, 2015 7:58 pm Post subject: what kind of seat do you have in your Kolb Firestar II |
I just would like to see what kind of a seat you have in your Kolb Firestar II..
I am 6'2" and 260 and I sat in one recently and it seemed like i was leaning way back is that normal? I won't bee needing the room for the second seat since I am to heavy for passengers..
I hope to see some pics of your seat configurations..or any ideas on how to make it more comfortable for me..
I tried to ad a pic dunno if it worked or not..... my wife told me I looked like a bull in a china shop...lol
Larry
w0odi
Posted: Sun May 03, 2015 8:00 pm Post subject: Re: what kind of seat do you have in your Kolb Firestar II |
try again
Posted: Mon May 04, 2015 12:52 am Post subject: what kind of seat do you have in your Kolb Firestar II |
I have an old original Firestar, and when sitting on level ground it gives the impression of leaning way back. I have the sling seat. When flying yours, the tail will come up above level, and the seat will seem normal. Try sitting in it while the tail is lifted up a few inches above level.
Bill Sullivan
Windsor Locks, Ct.
original FS, 447
On Sun, 5/3/15, w0odi <woodyz1957(at)gmail.com> wrote:
Subject: what kind of seat do you have in your Kolb Firestar II
Date: Sunday, May 3, 2015, 11:58 PM
"w0odi" <woodyz1957(at)gmail.com>
for passengers..
Larry
http://forums.matronics.com/viewtopic.php?p=441658#441658
Forum -
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Richard Pike
Posted: Mon May 04, 2015 7:25 am Post subject: Re: what kind of seat do you have in your Kolb Firestar II |
Owner is about 5'11" and 260 pounds, likes this seat real well. http://oh2fly.net/oldpoops/FSII%20seat%20page.html
With this windshield getting in and out was easy.
http://oh2fly.net/oldpoops/Latch.html
Check the last picture on this page - 2 tubes made it much more difficult.
http://oh2fly.net/oldpoops/Panel.htm
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
George Alexander
Posted: Mon May 04, 2015 10:17 am Post subject: Re: what kind of seat do you have in your Kolb Firestar II |
| w0odi wrote: | - S - N - I - P -
- S - N - I - P -
Larry |
Larry:
You and I are about the same dimensions... and I have a FS II.
While I don't have a picture of my seat configuration, I'll offer this:
Refer to the attached in-flight picture.
Bill Sullivan is correct about sitting upright when the tail comes up to flying stance.
and
Assuming that you are average proportions for 6'2" (legs & torso) you may encounter a problem (minor) with your knees sticking up. I tend to fly with my legs flayed to the outside to give maximum throw of the stick for the ailerons. As you can see in the picture, I don't have/need a full enclosure.
The remedy for this situation would be to reconfigure the seat to move it back. The biggest issue in doing this would be to move the tube that runs horizontally behind the seat back. While it does serve the purpose of being a stop for the seat back, its primary purpose (according to Dennis Jackson, Kolb's master welder) is to minimize the collapsing of the cage should it opt to become a lawn dart.
One thing that helped a little was to reduce the padding in seat (both bottom and back). I replaced the foam the builder had use with the 1" memory foam. Probably only gave me an additional 1/2" to 1" in both pieces, but every little bit helps.
Also gave consideration to moving the rudder pedals forward, but with size 13 shoes, there's only so much room in that nose pod.
Bottom line, the near standard configuration has not been a problem for me and I've been flying this FS II for over 10 years. If you are planning to do a lot of cross country with 2-3 hour legs, your results may vary.
Here is the link to a YouTube video with the camera mounted under the wing. May be able to see how it is. As the Turtle Man would say..... "Live Action"
https://youtu.be/dOte07vGiEg
"Worth what you paid fer it." Beauford William Tuton III
22.27 KB |
7362 Time(s) |
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
