Main Air Tank Install.
Ernie
PostPosted: Wed Apr 01, 2015 11:52 am    Post subject: Main Air Tank Install. Reply with quote
Here is the tank installed. Stock tank is still in airplane, since I'm testing and didn't feel like taking out smoke system and battery. Can still get items in through port side door. Tank can be removed in about 2 minutes. Filled up and ready to test. I turned up my pressure relief valve since there is no fear of overfilling system now. Nice to have the extra reserve air.
Ernie
[img]cid:ii_14c76825e8c36c6a[/img][img]cid:ii_14c76825d3984dec[/img][img]cid:ii_14c7682646197856[/img]
 Filesize:  833.77 KB
 Viewed:  2622 Time(s)
 Filesize:  730.28 KB
 Filesize:  646.34 KB
dougsappllc(at)gmail.com
PostPosted: Wed Apr 01, 2015 12:36 pm    Post subject: Main Air Tank Install. Reply with quote
Ernie,I'd be a bit cautious about "turning up your pressure relief valve".  The other components in the system are made to run at 45 to 50 atms, cranking it up in excess of that may cause failures in other components, especially if your using any additives in the pneumatic system.  Standard check valve rubber discs will start to "extrude" at about 60 atms, less if your using a additive.
Good luck,
Doug
On Wed, Apr 1, 2015 at 12:47 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
Ernie
 Filesize:  833.77 KB
 Viewed:  2620 Time(s)
 Filesize:  646.34 KB
 Filesize:  730.28 KB
Ernie
PostPosted: Wed Apr 01, 2015 1:17 pm    Post subject: Main Air Tank Install. Reply with quote
I didn't give that much thought. I was just thinking about the tubing. I will stay under 60 BAR
Ernie
On Wed, Apr 1, 2015 at 4:29 PM, doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
Good luck,
Doug
Ernie
 Filesize:  646.34 KB
 Viewed:  2619 Time(s)
 Filesize:  730.28 KB
 Filesize:  833.77 KB
markdavis(at)wbsnet.org
PostPosted: Wed Apr 01, 2015 1:21 pm    Post subject: Main Air Tank Install. Reply with quote
Ernie,
      How far did you turn up the pressure?  I'd be concerned that unnecessarily high pressures will result in higher operating temps on the compressor and lead to accelerated coking and premature pump failure  (all of that Standard Gas Law/Boyles's Law stuff I didn't pay enough attention to in school) and shortened actuator seal life from higher operating pressures.    Just wondering about the unintended consequences of tweaking the system pressure up.   Increased air reserve is great, but replacing an air compressor ranks pretty high on my Don't Like to Do It List.
Mark Davis
N44YK
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Ernest Martinez
Sent: Wednesday, April 01, 2015 1:48 PM
To: yak-list
Subject: Main Air Tank Install.
Ernie
[img]cid:image002.jpg(at)01D06C8D.AA6AD120[/img][img]cid:image004.jpg(at)01D06C8D.AA6AD120[/img][img]cid:image006.jpg(at)01D06C8D.AA6AD120[/img]
 Filesize:  21.78 KB
 Filesize:  22.9 KB
 Filesize:  28.14 KB
Ernie
PostPosted: Wed Apr 01, 2015 1:29 pm    Post subject: Main Air Tank Install. Reply with quote
I turned it up to 60 BAR, but will tweak it back down to 55.
Ernie
On Wed, Apr 1, 2015 at 5:20 PM, Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)> wrote:
Ernie,
Mark Davis
N44YK
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Ernest Martinez
To: yak-list
Ernie
 Filesize:  21.78 KB
 Viewed:  2618 Time(s)
 Filesize:  28.14 KB
 Filesize:  22.9 KB
mark.bitterlich(at)navy.m
PostPosted: Thu Apr 02, 2015 7:27 am    Post subject: Main Air Tank Install. Reply with quote
FYI, a friend did a home-brew replacement of the pressure relief valve on an otherwise stock system in a 50. During a test flight the system reached about 62 atmos, or about 170 (or so) PSI over the maximum recommended pressure setting of 50 Atmos, or 725 PSI. When he lowered the gear, he blew the chevron seals out of one of the main landing gear actuators. I never did ask him how old they were, so there might have been other factors involved. I too lost chevron seals in my 50, but in my case it was from following advise posted on this list of "injecting" air-tool oil into the system. Later, I took one of those seals and sprayed air tool oil on them directly, and within a week it was swollen and soft. Lesson learned.
Additionally, adjusting the pressure relief valve to a higher setting puts more strain on all system components, which includes the engine air-compressor, unless of course you have installed one of several methods to "unload" the compressor in-flight, which Richard Goode has discussed, and which I have also seen used on several Yaks and Sukhoi's as well. Thus I would agree with Doug that increasing system pressure over the maximum design recommendation given by the aircraft manufacturer might have catastrophic circumstances, but at the very least will decrease component life.
Mark
draftsjust417(at)gmail.co
PostPosted: Thu Apr 02, 2015 7:44 am    Post subject: Main Air Tank Install. Reply with quote
Good advice Mark, yes lessons learned.
I have my CJ's air system set for 47 ATM, use castor oil, have new restrictors in LG lines (thanks Doug Sapp) and it seems content to work very well on that.
 Justin
N280NC
On Thu, Apr 2, 2015 at 8:27 AM, Bitterlich, Mark G CIV NAVAIR, WD <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Mark
