Keith.Miller(at)esa.int Guest
Posted: Wed Mar 25, 2015 6:54 am Post subject: Aeroquip hoses |
Any one had an experience of these Aeroquip f hoses ( fuel and Oil type
303, , 601 and Stratoflex hose) deteriorating over time ?
Some of mine must be best part of 18 years old now- 13 years flying. They
all look good from the outside. or can some one point me to a specification
which defines the life of them in service .
Keith
To: "kis-list(at)matronics.com" <kis-list(at)matronics.com>,
Date: 03/24/2015 11:44 PM
Subject: Re: Re: NEOPRENE HOSE
Sent by: owner-kis-list-server(at)matronics.com
Fuel system problems are about 25% of the mechanical failures leading to
accidents in homebuilts. I would switch to real aircraft hoses (like
aeroquip 303) and hardware for any aircraft system. It is not hard to make
up the hoses yourself if you get the mandrel tool.
Scott
Sent from my iPad
On Mar 24, 2015, at 3:24 PM, Galin Hernandez <galinhdz(at)gmail.com> wrote:
My TR-4 has the neoprene hose from the wing to the fuselage as per the
plans. One of them started leaking (old age cracking) after 9 years of
use. The hose is very inexpensive so I now have it in my "scheduled
maintenance" to replace the hose very 5years.
On Mon, Mar 23, 2015 at 9:13 AM, mark_trickel <marktrickel(at)gmail.com>
wrote:
The 3/8 I.D. Neoprene hose included in KIS kits was intended for the
fuel line connection between the fuel tanks, and the fuselage. The
manual is a little vague, but there is a drawing of a typical
aircraft fuel system included in the TR-1 Builders Manual (Airframe
Assembly section page 8 ). I did not check, but I am sure the same
drawing is in the TR-4 Builders Manual. The drawing comes from our
faster, sleeker, and much more difficult to build cousin, the Lancair
235/320.
The black rubber hose is a very important piece to the KIS aircraft.
I can think of 2 real important reasons for this hose. First it makes
hooking up the fuel tanks – simple. It would be a lot harder to
install a metal piece of tubing in this tight spot. Second when a
wing panel breaks off in a crash, the neoprene fuel line would
separate very easily - you won’t have to worry about the fuel line
whiplashing about the cockpit (hopefully you all have plenty of Adell
clamps or the like securing the fuel line inside the cockpit).
Vinyl tubing was also included in KIS kits for use in the pitot
static system. Some items included in the kits in fact have a shelf
life, and that includes the neoprene, and vinyl tubing (tires, unused
resin and adhesives). KIS kits are now reaching the 25 year old mark,
and owners that have KIS aircraft built with these original materials
need to seriously think about replacing or upgrading them if they
have not done so already. The vinyl tubing in my 23 year old is still
somewhat serviceable, but I am upgrading to Nyloseal tubing, and
fittings - those will last a few lifetimes.
Some builders did not follow the Builders Manual, it’s just the
nature of homebuilt airplanes. Some installed that black rubber hose
from the fuel tanks all the way through the cockpit to the firewall
(a very bad idea). My TR-1 had that black hose from the tanks through
the side of the fuselage, then slid onto the aluminum tubing (no
barb) held on by 2 hose clamps, running 45+ psi automotive fuel pumps
in each wing slosh tank. The return came from the firewall fitting
into vinyl tubing, to the fuel valve, back into vinyl tubing to the
tanks. That tubing is now petrified. What’s in your fuel system?
http://forums.matronics.com/viewtopic.php?p=439763#439763
List" target="_blank">http://www.matronics.com/Navigator?KIS-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
ist"">http://www.matronics.com/Navigator?KIS-List
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
sstearns2(at)yahoo.com Guest
Posted: Wed Mar 25, 2015 10:26 am Post subject: Aeroquip hoses |
According to the Q/A section on the ACS page 303 hoses should be replaced every 5 years. Seems pretty conservative. I have read other places 10 years.
They have a lot of distributors that should be able to make a new set of hoses based on the old ones. The end fittings are probably still good. They are not too hard to do yourself if you get the mandrel tool from ACS.
http://www.eaton.com/Eaton/ProductsServices/Hydraulics/HowtoBuy/AeroquipExpress/index.htm
Scott
Sent from my iPad
Keith
Scott
Sent from my iPad
235/320.
FORUMS -
b Site -
Posted: Thu Mar 26, 2015 7:23 am Post subject: Aeroquip hoses |
Scott,
thanks for the info , probably like many I thought the aeroquip/
stratoflex hoses were the safest and most reliable solution , but if they
only last 5 years , its probably better to use the cheap neoprene and
replace at the same interval. I will do a major inspection of all my hoses
ASAP, as i am clearly on borrowed time .
Keith
Date: 03/25/2015 07:27 PM
Subject: Re: Aeroquip hoses
years.
Scott
Sent from my iPad
They
| Quote: | all look good from the outside. or can some one point me to a
specification
| Quote: | which defines the life of them in service .
Keith
make
| Quote: | up the hoses yourself if you get the mandrel tool.
Scott
Sent from my iPad
Lancair
| Quote: | 235/320.
makes
| Quote: | hooking up the fuel tanks – simple. It would be a lot harder to
Adell
| Quote: | clamps or the like securing the fuel line inside the cockpit).
unused
| Quote: | resin and adhesives). KIS kits are now reaching the 25 year old
mark,
| Quote: | and owners that have KIS aircraft built with these original
materials
| Quote: | need to seriously think about replacing or upgrading them if they
still
| Quote: | somewhat serviceable, but I am upgrading to Nyloseal tubing, and
through
| Quote: | the side of the fuselage, then slid onto the aluminum tubing (no
pumps
| Quote: | in each wing slosh tank. The return came from the firewall fitting
FORUMS -
b Site -
or addressees only.
| Quote: | The unauthorised disclosure, use, dissemination or copying (either in whole
or in part) of its
| Quote: | content is not permitted.
| Quote: | Emails can be altered and their integrity cannot be guaranteed by the
sender.
Posted: Thu Mar 26, 2015 7:51 am Post subject: Aeroquip hoses |
I would stay away from the neoprene hose. Another option is the Teflon hoses that last a lot longer. That is what the airlines use now.
Scott
Sent from my iPad
| Quote: | On Mar 26, 2015, at 8:23 AM, Keith.Miller(at)esa.int wrote:
Scott,
Keith
years.
Scott
Sent from my iPad
They
specification
> Thanks
> Keith
> From: Scott <sstearns2(at)yahoo.com>
make
> Scott
> Sent from my iPad
Lancair
> 235/320.
makes
Adell
unused
mark,
materials
still
through
pumps
> FORUMS -
> _blank">http://forums.matronics.com
> b Site -
> target="_blank">http://www.matronics.com/contribution
or addressees only.
or in part) of its
sender.
Posted: Thu Mar 26, 2015 8:17 am Post subject: Aeroquip hoses |
Scott
since i have all aeroquip/ stratoflex, its simpler for me to replace just
the hose and use the original end fittings , As you said , they are
quick to make up ,
| Quote: | From a google search , Rotax engines also states that their rubber hoses
need to be replaced at 5 years.
Does anyone know which Service Bulletin Continental covers their rubber
parts under ? ( OC ? )
Keith
Date: 03/26/2015 04:53 PM
Scott
Sent from my iPad
Scott,
Keith
years.
Scott
Sent from my iPad
They
specification
> Thanks
> Keith
make
> Scott
> Sent from my iPad
Lancair
> 235/320.
makes
Adell
unused
mark,
materials
still
through
pumps
> FORUMS -
> b Site -
or addressees only.
whole
| Quote: | or in part) of its
sender.
or addressees only.
or in part) of its
sender.
bakerocb
Posted: Mon Mar 30, 2015 10:13 am Post subject: Aeroquip hoses |
3/30/2015
Hello Keith, You wrote: "Does anyone know which Service Bulletin
parts under ? ( OC ? )"
A search of the Continental pubs did not reveal anything. I talked to Jason
at Continental Technical Support.
He said that he knew of no Continental publication dealing with that subject
and that the flex hoses on the
engine should be replaced at TBO hours or 12 years. He just assumed the same
would apply to flex hoses
from the airframe to the engine. He did throw the words "on condition" into
the conversation a few times.
I say to put in the very best quality hoses that you can find and check
their condition whenever they are
exposed and during scheduled inspections.
OC
Sent: Thursday, March 26, 2015 12:17 PM
To: kis-list(at)matronics.com
Scott
quick to make up ,
rubber
Keith
Scott
Sent from my iPad
Scott,
they
hoses
Keith
years.
Scott
Sent from my iPad
They
specification
> Thanks
> Keith
make
> Scott
> Sent from my iPad
> the
> of
> the
Lancair
> 235/320.
> aircraft.
makes
Adell
unused
mark,
materials
still
> hose
through
pumps
> FORUMS -
> b Site -
> addressee
or addressees only.
whole
> delete
sender.
or addressees only.
whole
or in part) of its
sender.
or addressees only.
or in part) of its
sender.
