dan(at)syz.com Guest
Posted: Thu Feb 12, 2015 1:53 pm Post subject: Door seals - more questions than answers. |
Hi everyone. I'm at the stage of choosing door seals and have somewhat stalled in the decision-making process, so I'm reaching out to those who've been there, in trying to make the best-informed decision. I've scoured the RV-10 Matronics email list for the past several years to see what people are doing, but still have what seems to be more questions than answers.
I know that replacing Van's seals is a popular option. I guess the first thing to know when choosing an alternative is understanding exactly what we're trying to fix. My biggest question is probably - what is the biggest problem with them? I've read that the stock seals just don't "seal" well enough. Is this because of where the seal fits (into the channel)? Or due to the physical nature of the rubber seal? I notice that it quite easily "kinks", which would leave air gaps if this happens when mounted on the door. Also, the coil I have from Vans has lots of locations where the two opposite edges in the bulb are stuck together internally (kinks that have sat that way for years). They can probably be teased apart, but obviously, if this happens when it is on the door, the sealing factor is gone. Alternately, if the problems with Van's seal are due to the location of the seal, obviously changing to a seal that attaches differently makes sense. If due to kinking, perhaps a different composition of seal?
A popular option here seems to be McMaster-Carr's part number 1120A313 (also apparently the same as 1120A31), or 1120A411 - edge-grip seals with a rubber bulb. This gets installed along the door frame instead of the door, and requires the modification that the channel (gutter) along the door frame is cut back such that the inner curve of the channel is removed so that the mounting edge is effectively co-planar with the door. I know this is a popular option, but as I say, I want to make an informed decision. Though I'm sure it makes a finished look, I am a bit concerned that removing the inner curve of the channel reduces the structural integrity of the cabin top somewhat (it effectively removes one of the flanges if the channel were to be considered an I-beam). I also kind of like the existing gutter concept to the door frame minimizing the chance of water getting inside overhead. Also, considering that this concept puts the seal on the door frame, I wonder if it would be more easily damaged and/or dislodged by people getting in and out. On the other hand, car door seals tend to be this way, so maybe it's not a big deal. One thing I don't understand - those seals have a rubber bulb... in which case, how do they seal better than Van's which also have a similar bulb, or is it primarily the mounting difference that improves things?
Another option that's been popular is that which was sold by rvtraining.com / Aviation Tech Products. This was a foam-based seal that went along the outer edge (lip) of the door. Since it didn't require modifications to the structural integrity of the door frame, I thought this was potentially appealing (plus, it feels as though a foam-based seal would be more sound-insulating than a rubber bulb). But I say "was" on purpose - I got in touch with them a few days ago, and as of December 2014, they closed Aviation Tech Products, don't have any seals left and don't know where else they may be obtained. So this exact option is out, unless someone has done something similar. On the other hand, I never quite understood how the seal would work effectively along the areas of the door where there was only a very small lip available, like along the bottom.
Another option would be seal attached to the door that compressed against the existing flange of the door frame that curves back towards the door (the part cut off when using the aforementioned 1120A411 edge-grip seal). This could be something like McMaster part 1142A28, or even a simple adhesive-backed strip like 93745K23.
If the problem with Van's seal is due to its composition, there are McMaster alternatives that have a similar form factor (and hence mounting) - like a purely foam version such as 93085K91, or even an intriguing "hybrid" rubber seal with a foam core (1141A4) that may combine the ruggedness of a rubber outer section like Van's with a foam core inside that "may" help prevent kinking and opposite sides of the bulb bonding together, if that in fact is the problem with Van's in the first place. To me this seems like the most straightforward improvement with minimal changes to what Van's intended, but I don't know if that would be "fixing" a problem with the Van's seals that may not be the big issue in the first place.
Of course, I could just go and do what the majority are doing with regards to alternate seals if there is a majority, but I'm the sort who wants to make an informed a decision as possible. Any feedback anyone could give on the concept would be greatly appreciated - particularly from those who have gone down this decision tree in the past, I'd be very interested in hearing why you decided on using what you have. Then, if I decide to go with some variation of a McMaster seal, I have to tackle the next hurdle and see if I can get them to ship to Canada, which I've heard has been problematic in the past. But one problem at a time
Thanks! Dan
Dan Charrois
President, Syzygy Research & Technology
Phone: 780-961-2213
speckter(at)comcast.net Guest
Posted: Thu Feb 12, 2015 2:45 pm Post subject: Door seals - more questions than answers. |
I know that staying with the Vans seals is not the popular choice but I have been quite happy with them and I have a good seal all around
I had the McMaster seals on my Glasair and they are not without their own problems. They shrink over time and leave a 1" gap at the joint. Additionally they are not water tight. The water seeps in around the clip. To make it water tight you must install the clip with silicone caulk. Plus all the grinding and building up on the lip.
So, each has issues so pick your poison.
I know that replacing Van's seals is a popular option. I guess the first thing to know when choosing an alternative is understanding exactly what we're trying to fix. My biggest question is probably - what is the biggest problem with them? I've read that the stock seals just don't "seal" well enough. Is this because of where the seal fits (into the channel)? Or due to the physical nature of the rubber seal? I notice that it quite easily "kinks", which would leave air gaps if this happens when mounted on the door. Also, the coil I have from Vans has lots of locations where the two opposite edges in the bulb are stuck together internally (kinks that have sat that way for years). They can probably be teased apart, but obviously, if this happens when it is on the door, the sealing factor is gone. Alternately, if the problems with Van's seal are due to the location of the seal, obviously changing to a seal that attaches differently makes sense. If due to kinking, perhap!
A popular option here seems to be McMaster-Carr's part number 1120A313 (also apparently the same as 1120A31), or 1120A411 - edge-grip seals with a rubber bulb. This gets installed along the door frame instead of the door, and requires the modification that the channel (gutter) along the door frame is cut back such that the inner curve of the channel is removed so that the mounting edge is effectively co-planar with the door. I know this is a popular option, but as I say, I want to make an informed decision. Though I'm sure it makes a finished look, I am a bit concerned that removing the inner curve of the channel reduces the structural integrity of the cabin top somewhat (it effectively removes one of the flanges if the channel were to be considered an I-beam). I also kind of like the existing gutter concept to the door frame minimizing the chance of water getting inside overhead. Also, considering that this concept puts the seal on the door frame, I wonder if it would !
Thanks! Dan
Dan Charrois
Phone: 780-961-2213
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Thu Feb 12, 2015 2:48 pm Post subject: Re: Door seals - more questions than answers. |
The Vans stock seals don't really work very well, and quite honestly, look terribly cheap, especially on a $175,000 aircraft. The McMaster edge grip bulb seals look very professional, and do their job. Unfortunately they also take quite a bit of work to install. The door frame must be modified and reinforced at the front and rear frame, and the hinge recesses must be covered to create a seal.
Having said that, I used the McMaster seals and would do it again. They look soooo much better than the stock seal.
The other modification that is a must, is the Plane Around door security latch.
I also just finished installing the new Aerosport outer door latches.
As an edit. I was my plane quite often and have never seen a drop of water get past the seals or the channel clip. I do not have any silicone on the channel.
_________________ Bill
WA0SYV
Aviation Partners, LLC
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Thu Feb 12, 2015 2:58 pm Post subject: Re: Door seals - more questions than answers. |
I installed my own on the door frame. I don't even remember where I got them. It took LOTS of work and rework to get them right. I did try the foam rubber from Aviation Tech Products and they did not work well at all. I agree with your concerns about grinding down the door frame to install the McMaster-Carr seals. However, they definitely look great. My biggest complaint with the Van's product is the appearance. Bill P. is right. They look cheap! However, knowing what I know now, I would install the Van's seals because they work fine, even if they don't look so good.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Tim Olson
Posted: Thu Feb 12, 2015 3:11 pm Post subject: Door seals - more questions than answers. |
I too have only had the standard Van's seals for almost 1100 hours now.
I think all of that kinking thing is a non-issue. It'll straighten out
and seal and
work well. I actually think that it may be the quietest and most
airtight way to
go. But if there is a "problem" with the original seals, it's that the door
can be hard to close just because the seal is about as thick as you
could put
in that gap. The McMaster ones I've seen make the door have no
resistance to
closing and the thing just latches.
I don't have any firsthand experience with anything but mine, and I know
others like the McMaster, so nothing against going either way. I do think
mine seal very tightly...I get no air or noise. I did get some
initially up by
the front door pins, but then got it sealed up. That seal fills the gap
completely and doesn't allow much in the way of air to leak.
I'm not sure what I'd do if I built another one. I'm inclined to say
I'd stick
with what I have, since it's been good. But I'd probably go ride with some
friends who have the other and see if theirs leaks at all. If so, I'd
definitely
go with mine, but if not, I'd consider either. I do like the looks of the
doors better with the seal on the door side though. I'd rather not have the
black foam around the door hole.
Honestly, if you do it right, I don't think you'll go wrong either way.
Like you, I'd think that whatever you can do to be non-intrusive into the
structure, would be the best approach, so if you go the other way, I'd
cut the seal to fit the door channel, not the channel to fit the seal.
On 2/12/2015 4:40 PM, Gary wrote:
kdb.rv10(at)gmail.com Guest
Posted: Thu Feb 12, 2015 4:56 pm Post subject: Door seals - more questions than answers. |
I installed Van's seals and absolutely could not close the door. I pushed from the outside but it would not completely close. It all depends on how deep you set the door; since I wanted mine to be flush, I suppose it sets deeper than Van's. On Van's factory plane it works great, but not on mine. So, I took Van's seals off and installed the McMaster- Carr seal. It was a lot of work, but it completely seals and the door closes just right. If I were building another plane, that's what I'd use without another thought.....
Kevin Belue
On Feb 12, 2015, at 3:50 PM, Dan Charrois <dan(at)syz.com> wrote:
Thanks! Dan
Dan Charrois
Phone: 780-961-2213
Bob Turner
Posted: Thu Feb 12, 2015 5:23 pm Post subject: Re: Door seals - more questions than answers. |
Put me into the "Vans original" camp.
Yes, they look cheap.
Yes, after endless sanding and fitting it is dis-heartening to find you have to sand and fit more after the seals are on.
My doors are a little tight to close, so extra attention is needed to make absolutely sure the aft pin is engaged.
But I hear and feel no air leaks, no water leaks, I'm happy.
_________________ Bob Turner
RV-10 QB |
Dave Saylor
Posted: Thu Feb 12, 2015 5:44 pm Post subject: Door seals - more questions than answers. |
I have the simple foam backed strips. Pictures here:
http://tinyurl.com/Post-regarding-door-seals
My doors seal water and air tight. The best part is how the door closes--no effort at all, just push the handle down.
I've replaced the seals once in 7 years. It takes an hour or so and cost was less than $20.
Don't be dismayed if the door seems hard to close on the first try. Let it sit for a few hours and the foam takes as set at zero clearance. Then the doors open and close easily.
--Dave
On Thu, Feb 12, 2015 at 1:50 PM, Dan Charrois <dan(at)syz.com (dan(at)syz.com)> wrote:
[quote]--> RV10-List message posted by: Dan Charrois <dan(at)syz.com (dan(at)syz.com)>
Thanks! Dan
Dan Charrois
Phone: 780-961-2213
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
_________________ --Dave
KWVI |
Kelly McMullen
Posted: Thu Feb 12, 2015 6:29 pm Post subject: Door seals - more questions than answers. |
Another option that I haven't heard mentioned. www.aircraftdoorseals.com
Similar to what was previously offered by rvtraining.com, however, uses a proprietary foam that compresses as much as needed and mostly stays compressed after first 24 hours. I have their product on my Mooney, and it works quite well. I believe they will sell you whatever length you need. Not cheap. On certified plane kit is typically $130 for door seal. Don't know if they discount for experimental.
On Thu, Feb 12, 2015 at 6:23 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=438286#438286
FORUMS -
b Site -
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Fri Feb 13, 2015 9:39 pm Post subject: Door seals - more questions than answers. |
| Quote: | Hi everyone. I'm at the stage of choosing door seals and have somewhat stalled in the decision-making process, so I'm reaching out to those who've been there, in trying to make the best-informed decision. I've scoured the RV-10 Matronics email list for the past several years to see what people are doing, but still have what seems to be more questions than answers.
Thanks, everyone, for your incredibly useful feedback with regards to my query about door seals. Like most other things in homebuilding, there are lots of different ways to do things, all with good and compelling reasons to choose them.
One thing that did surprise me is how many people commented on continuing to use Van's original seals - from past comments here, it seemed that everybody was changing out their seals. But I guess, a lot of discussion here naturally tends to where we deviate from the plans as opposed to where we follow them - there's more to talk about
In any case, I feel like I'm going into this particular decision with a lot more information than I had before. Thanks again!
Dan
Dan Charrois
Phone: 780-961-2213
