Frequency problem update
danb
PostPosted: Mon Feb 09, 2015 5:27 pm    Post subject: Frequency problem update Reply with quote
A little over a week ago I mentioned I recently purchased a Bose headset that would not allow me to make a call to tower. I could talk to ground, yet , when I switched over to tower I got nothing but a loud high-pitched squeal. I wanted to give an up-date as I have the problem resolved. All it took was going to Radio Shack and purchased a couple ferrite beads. I snapped one on the coax behind my radio, started my engine and hit the PTT. It was almost gone but still a chirp here and there. I shut down and snapped the second one on the coax just in front of the antenna. Works perfect now. Hope this can help others with similar problems.
Dan B
Kellym
PostPosted: Mon Feb 09, 2015 6:40 pm    Post subject: Frequency problem update Reply with quote
Sounds like your antenna coax has compromised shielding, that allows RF leakage. Most likely the ferrite beads mask the problem. A new coax would likely give same result.
On 2/9/2015 6:25 PM, danielj.billingsley(at)yahoo.com (danielj.billingsley(at)yahoo.com) wrote:
[quote] A little over a week ago I mentioned I recently purchased a Bose headset that would not allow me to make a call to tower. I could talk to ground, yet , when I switched over to tower I got nothing but a loud high-pitched squeal. I wanted to give an up-date as I have the problem resolved. All it took was going to Radio Shack and purchased a couple ferrite beads. I snapped one on the coax behind my radio, started my engine and hit the PTT. It was almost gone but still a chirp here and there. I shut down and snapped the second one on the coax just in front of the antenna. Works perfect now. Hope this can help others with similar problems.
Dan B
Kelly McMullen
KCHD
PostPosted: Wed Feb 11, 2015 7:31 am    Post subject: Frequency problem update Reply with quote
Dan B
I agree. The OUTSIDE of a properly installed coax is radio frequency
neutral . . . i.e. nothing of what exists inside the coax will
exist outside the coax. The fact that adding anything outside
has an influence on observed behaviors suggests that your coax
is behaving more like a piece of wire than a properly functioning
transmission line.
Metal or composite airplane? If composite, what kind of
ground plane under your antenna? Where is antenna located
on airplane? Check your coax connectors at both ends . . .
danb
PostPosted: Wed Feb 11, 2015 10:29 am    Post subject: Frequency problem update Reply with quote
Bob, This is a tube and fabric plane (Kitfox). My connection to the radio was straight forward, however, the antenna (which is in the vertical stab.) is a simple SS pole with just a thread and nut end. I crimped a washer like connector on the primary wire and tightened it with a nut. The outside strand was twisted and crimped on the same type of connector and I bolted that to the frame. I always felt as if this were Disneyland-type engineering. Are there any other options or ideas?
Dan B
Sent: Wednesday, February 11, 2015 8:29 AM
Subject: Re: Frequency problem update
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Dan B
transmission line.
on airplane? Check your coax conna href="http://www.matronics.com/Navigator?AeroElectric-List" target="_tp://forums.matronics.com/" target="_blank">http://forums.matronics.com</ -Mats.com/contribution" target="_blank">http://www.matronics.com/contribution==============
PostPosted: Wed Feb 11, 2015 3:15 pm    Post subject: Frequency problem update Reply with quote
Dan B
Does this installation have a service history? Are there
exemplar installations flying? The first Kitfox structure
image that popped up in a search looks like this . . .
[img]cid:.0[/img]
If this is applicable to your airplane, where is the antenna located
with respect to the metallic structure of the vertical fin? I'm
puzzled as to how an antenna 'buried' under the fabric can
enjoy the necessity for a relatively 'free' view of the
universe in all directions around the antenna. An antenna
mounted in close proximity to the metallic structure of this
fuselage would be first seriously detuned from it's design
frequency and second, suffer severe distortion of radiation
patterns. It would be interesting to see what kind of SWR
measurements you get from such an installation.
The drawing above calls out an antenna mounting feature
that would offer a best-compromise location for your Comm
antenna.
 Filesize:  306.91 KB
 Viewed:  11760 Time(s)
wrmaxwell(at)bigpond.com
PostPosted: Wed Feb 11, 2015 3:50 pm    Post subject: Frequency problem update Reply with quote
dalemed
PostPosted: Thu Feb 12, 2015 10:31 am    Post subject: Frequency problem update Reply with quote
Since the problem is sensitive to frequency (ground vs tower) I suspect the antenna or the way it's mounted, in which case the ferrite might be the best solution.
Dale [quote][b]
Dale
Zenith Zodiac CH650
Kellym
PostPosted: Thu Feb 12, 2015 11:50 am    Post subject: Frequency problem update Reply with quote
The frequency sensitivity relates to the fact that RF feedback is
occurring. I had this problem in a previous aircraft, which I eventually
traced back to a cold solder joint on the RG-58 BNC coax connector at
the radio. It worked fine on frequencies below 123.0, and as the
frequency went higher it would give off a feedback squeal when the mike
was keyed. New coax with properly crimped BNC connectors eliminated the
problem. Ferrite beads just mask the problem.
Dale
Kelly McMullen
KCHD
PostPosted: Thu Feb 12, 2015 1:33 pm    Post subject: Frequency problem update Reply with quote
eventually traced back to a cold solder joint on the RG-58 BNC coax
connector at the radio. It worked fine on frequencies below 123.0,
and as the frequency went higher it would give off a feedback squeal
when the mike was keyed. New coax with properly crimped BNC
connectors eliminated the problem. Ferrite beads just mask the problem.
Yes. By definition, a transmission line with strong
standing waves (high SWR) may become a poor transmission
line and a better antenna. Since the 'distance' from
peak to peak on a standing wave is defined by the operating
frequency, the degree with which a degraded transmission
line radiates (or receives) is a function of the frequency
of interest.
In one case, the operator reported relief from the
effects by simply shortening a coax. He put a new
connector on one end and decided to cut away some
extra slack. The connector replaced was a 'good' one
but the frequency of interest moved off to another
value. He didn't discover the 'other' bad connector
until later under different circumstances.
Ferrites over a radiating line WILL reduce the
effects . . . but it does nothing to correct the
underlying issue . . . which may still have deleterious
effect on system performance.
Bad transmission lines can affect reception too
but these are often more difficult to observe.
In the final analysis, it's difficult to beat
antenna installations with track records unless
you're going to visit a capable RF lab and have
any 'new idea' in antennas evaluated by-the-numbers.
donvansanten(at)gmail.com
PostPosted: Thu Feb 12, 2015 2:29 pm    Post subject: Frequency problem update Reply with quote
Over the years that I have followed this list I recall you saying  "check your coax connections". I might be having a senior moment, but I can not remember you ever telling us how to check them. Is continuity all we are looking for on the conductor and the shield but not shorted together? On Feb 12, 2015 1:40 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
The frequency sensitivity relates to the fact that RF feedback is occurring. I had this problem in a previous aircraft, which I eventually traced back to a cold solder joint on the RG-58 BNC coax connector at the radio. It worked fine on frequencies below 123.0, and as the frequency went higher it would give off a feedback squeal when the mike was keyed. New coax with properly crimped BNC connectors eliminated the problem. Ferrite beads just mask the problem.
   of interest.
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
danb
PostPosted: Thu Feb 12, 2015 5:26 pm    Post subject: Frequency problem update Reply with quote
Bob, Thanks for the good information. To answer a previous question you had...The antenna IS mounted inside of the vertical stab. I did not put a ground plane on it but rather (as mentioned earlier) took the ground to the tube frame. The only reason I configured it this way was because a buddy with the same Kitfox model mounted it this way and it has performed for him very well. With my Ham background, I knew the ideal install would be with that ground plane, however, fitting a ground plane of any size perpendicular to the antenna is not possible where the antenna is currently at. The antenna itself is not accessible...only the connections to it. I have been using a headset that has ANR capability, but I was using it without the ANR. Every time I turned the ANR feature on, I got the same RF noise. I was hoping that the new Bose headset would work but it is the same issue. The ferrite bead trick has made it operational, but like you said it is only masking the issue. I suppose I will end up mounting an antenna behind the turtledeck with a proper ground plane for the fix. Thanks to all who assisted with this problem.
Dan B.
Sent: Thursday, February 12, 2015 2:28 PM
of interest.
Bob . . . nbsp; --> http://www.matronics.com/Navigator?AeroElectric-List<; http://forums.sp; - List Contribution Web Site -
_; &nb://www.matronics.com/contribution" target="_blank">http://www.matronics.c===================
Kellym
PostPosted: Thu Feb 12, 2015 6:50 pm    Post subject: Frequency problem update Reply with quote
It is NOT the location or lack of ground plane causing the feedback. It
is most likely one of the coax connections.
Dan B.
Kelly McMullen
KCHD
PostPosted: Thu Feb 12, 2015 7:06 pm    Post subject: Frequency problem update Reply with quote
Once you solve the feedback problem, you will then likely start finding occasions when your signal cannot be heard by another aircraft on certain bearings, or that aircraft will only hear a weak signal. That will be caused by your antenna's mounting position, being partially shielded by the fin frame etc. When you think of it, an antenna mounted within the tubing frame of the aircraft, even in the fin, is essentially an antenna mounted in a Faraday Cage.
On 13/02/2015 1:48 PM, Kelly McMullen wrote:
[quote]--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com)
It is NOT the location or lack of ground plane causing the feedback. It is most likely one of the coax connections.
On 2/12/2015 6:25 PM, danielj.billingsley(at)yahoo.com (danielj.billingsley(at)yahoo.com) wrote:
Dan B.
PostPosted: Thu Feb 12, 2015 7:19 pm    Post subject: Frequency problem update Reply with quote
At 16:27 2015-02-12, you wrote:
Certainly do the continuity check. Then, my favorite is the
twist and tug test. The most common failure at the coax
connector is loss of integrity at the shield. In the
legacy solder-and-clamp connectors (UG-8Cool it was really
easy fabricate a bad joint. With the crimp on connectors,
a badly adjusted stripper can damage wires such that
they are mechanically weakened.
With either connector, a substantial torque moment
on the cable as it enters the back of the connector
should produce ZERO perceived motion.
