dougsnash
Posted: Sat Jan 24, 2015 11:51 am Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting |
I put an inspection panel adjacent to where the strut enters the wing so that I can inspect those bolts at every annual.
Doug M
Sent: Saturday, January 24, 2015 10:49 AM
Subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting
Hi all,
I rivetted the trailing edge of the nose skin to the spar on the bottom side. But realize now I cannot get that upside down bolt in the upper strut fitting because the skin is rivetted tight in this position. On the right wing I was sure to get it on and the bolts torqued before I rivetted on the skin, thought I would get smart on the left wing, not so. Has anybody else done this, and is there an alternative to drilling out 40 some A4 rivets to get this bolt in.
Perry
Quote: |
ist" target="_blank" rel="nofollow">http://www.matronics.com/Navigator?Zenith701801-List
el="nofollow">http://forums.matronics.com
_blank" rel="nofollow">http://www.matronics.com/contribution
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
pdelano(at)telus.net Guest
Posted: Sat Jan 24, 2015 2:11 pm Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting |
Hi Doug,Could you remove the bolts if you needed to. If so, I probably should do the same. Would you have a picture?Regards,PerrySent wirelessly from my BlackBerry device on the Bell network.Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
Sender: owner-zenith701801-list-server(at)matronics.com
Date: Sat, 24 Jan 2015 19:50:43 +0000 (UTC)
To: zenith701801-list(at)matronics.com<zenith701801-list(at)matronics.com>
ReplyTo: zenith701801-list(at)matronics.com
Subject: Re: Zenith701801-List: Forgot to install bolts in 7V2-5, Upper Strut Fitting
I put an inspection panel adjacent to where the str= ut enters the wing so that I can inspect those bolts at every annual.
Doug M
= From: Perry Delano <pdelano(at)telus.net>=
To: zenith701801-l= ist(at)matronics.com
Subject: Zenith701801-List: Forgot to install bolts i= n 7V2-5, Upper Strut Fitting
Hi all,
I rivetted the trailing edge of the nose skin to the spar = on the bottom side. But realize now I cannot get that upside down bolt in t= he upper strut fitting because the skin is rivetted tight in this position.= On the right wing I was sure to get it on and the bolts torqued before I r= ivetted on the skin, thought I would get smart on the left wing, not so. Ha= s anybody else done this, and is there an alternative to drilling out 40 so= me A4 rivets to get this bolt in.
Perry
=20 Quote: |
ist" target=3D"_blank" rel=3D"nofollow">http://www.matronics.com/Navigator?=
Zenith701801-List
el=3D"nofollow">http://forums.matronics.com
_blank" rel=3D"nofollow">http://www.matronics.com/contribution
[/b] |
dlorrzen701(at)earthlink. Guest
Posted: Sat Jan 24, 2015 4:37 pm Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting |
Go to George Race's website and order an inspection cover. http://www.mrrace.com/Products/index.htm
Sent from my Verizon Wireless 4G LTE DROID
Perry Delano <pdelano(at)telus.net> wrote:
[quote]<!-- /* Font Definitions */ (at)font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:11.0pt; font-family:"Calibri","sans-serif";} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} a:visited, span.MsoHyperlinkFollowed {mso-style-priority:99; color:purple; text-decoration:underline;} span.EmailStyle17 {mso-style-type:personal-compose; font-family:"Calibri","sans-serif"; color:windowtext;} .MsoChpDefault {mso-style-type:export-only; font-size:10.0pt;} (at)page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in;} div.WordSection1 {page:WordSection1;} -->
Hi all,
Â
Â
Â
Perry
Â
Â
_-============================================================ _-= - The Zenith701801-List Email Forum - _-= Use the Matronics List Features Navigator to browse _-= the many List utilities such as List Un/Subscription, _-= Archive Search & Download, 7-Day Browse, Chat, FAQ, _-= Photoshare, and much much more: _-= _-= --> http://www.matronics.com/Navigator?Zenith701801-List _-= _-============================================================ _-= - MATRONICS WEB FORUMS - _-= Same great content also available via the Web Forums! _-= _-= --> http://forums.matronics.com _-= _-============================================================ _-= - List Contribution Web Site - _-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-= --> http://www.matronics.com/contribution _-============================================================
JohnDRead(at)aol.com Guest
Posted: Sat Jan 24, 2015 6:24 pm Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting |
Make inspection covers for anywhere there is a bolt to be checked. Your DAR will want to see inside your airframe when he/she is doing the inspection before you go test flying.
John Read
Home: 303.648.3261
Mobile: 719.494.4567
In a message dated 1/24/2015 5:38:07 P.M. Mountain Standard Time, dlorrzen701(at)earthlink.net writes:
Quote: | Go to George Race's website and order an inspection cover. http://www.mrrace.com/Products/index.htm
Hi all,
Perry
Quote: |
List href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
| ~44}r{(8^e.+-fZ+e,z1kxWÖ¯hn0zfȸ+bzr.+-R Ò¹*m!'0(at)!jÙ®rræ¡ |
Posted: Sat Jan 24, 2015 7:44 pm Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting |
John, David, Mike and Doug,
Thank you all for your input. I think I will bite the bullet and knock the rivets out of half the nose skin so I can get the bolt in as specified in the plans and manual.  I will have to then consider some inspection panels. Thanks for the tip on George Race’s website.
Perry
Posted: Sat Jan 24, 2015 8:30 pm Post subject: Forgot to install bolts in 7V2-5, Upper Strut Fitting |
Looked at it again. Taking 50+ rivets out of the spar for one bolt looks pretty onerous. Will send a note to Caleb to see if he can give any tips. Maybe a shorter bolt.
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Perry Delano
Sent: Saturday, January 24, 2015 7:42 PM
Subject: RE: Forgot to install bolts in 7V2-5, Upper Strut Fitting
Perry Quote: | http://www.matronics.com/Navigator?Zenith701801-List | 01234567
Checked by AVG - www.avg.com
Version: 2014.0.4800 / 01/24/15
