Z14 DWG File for FADEC
Robert Reed
PostPosted: Sun Jan 11, 2015 4:19 pm    Post subject: Z14 DWG File for FADEC Reply with quote
Does anyone have the DWG File for the
Dual Battery, Dual Alternator, FADEC Version Schematic (Z14)
I have the PDF Version but need to obtain the DWG File.
If up have it, could you email it to me at RobertR237(at)att.net
Bob Reed
raymondj(at)frontiernet.n
PostPosted: Sun Jan 11, 2015 6:02 pm    Post subject: Z14 DWG File for FADEC Reply with quote
Just ran across this ad. Thought I'd pass it on to you. Maybe the trial
version would get the job done.
http://www.axsware.com/?gclid=CNuDqvOqjcMCFTBgMgodymsARA
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
Bob Reed
PostPosted: Sun Jan 11, 2015 6:22 pm    Post subject: Z14 DWG File for FADEC Reply with quote
The entire library of AeroElectric Connection drawings
in .pdf and .dwg form are available from the website
at:
http://tinyurl.com/og7ztjl
A 'fadec version' . . . not sure what this is.
can you mail me a copy of the .pdf?
Robert Reed
PostPosted: Sun Jan 11, 2015 7:34 pm    Post subject: Z14 DWG File for FADEC Reply with quote
Bob
I have attached a copy of the only file that I have which it turns out is not the one I thought it was.
Several years back you worked up a version of the Z14 Dual Bat, Dual Alt, Split Bus for the Aerosance FADEC system. I think it was called the Z14-FADEC and I remember seeing it on your site but I can't find it now. The copy that I have looks the same but does not identify the original. I thought I had a copy on my computer but have been unable to locate and suspect it was lost when I upgraded computers a while back.
The attached schematic is very close to what I need but I need to make a few changes for my configuration. I can probably use the Z14 and make the changes if all else fails.
Bob Reed
Sent: Sunday, January 11, 2015 8:21 PM
Subject: Re: Z14 DWG File for FADEC
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
If up have it, could you email it to me at RobertR237(at)att.net (RobertR237(at)att.net)
at:
<a href="http://tinyurl.com/og7ztjl"
N142DSFinalElectricalFADEC.pdf
 Filename:  N142DSFinalElectricalFADEC.pdf
 Filesize:  47.21 KB
 Downloaded:  311 Time(s)
