mojavjoe
Posted: Tue Dec 30, 2014 6:31 am Post subject: Fwd: Latex Paint Rolling Video |
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Tuesday, December 30, 2014 9:17:07 AM
Subject: Re: Latex Paint Rolling Video
I'm going to spray my side by side with latex and have been looking for a clear coat product that wound be compatible with latex. Thought of varnishes, too hard, some of the stuff used by crafters (don't know if they will stand up to rain and sunlight), Valspar used to make a clear latex but I can't find it listed any longer. Skybiker used a clear coat in 04 and said that it still looked good. Malcolm do you know what he used, or do you or anyone on the list know of a good clear coat.
Sent: Wednesday, December 24, 2014 8:09:07 AM
Subject: Latex Paint Rolling Video
I just finished a new video on applying latex paint with a roller. After the sanding and polishing process the results are nearly as good as spraying. Both methods, spraying and rolling have their advantages.
Spraying gives the best finish, it’s faster for big areas, and requires less sanding to smooth the orange peel. But, you need spray equipment and a paint booth the contain the over spray, and you need to mask parts that you don’t want painted.
Rolling is faster for smaller areas and requires no masking other than along edges, it needs no paint booth or equipment, there’s no over spray. But, it requires more sanding to remove the orange peel and while the result is quite good it’s probably not quite as good as spraying.
Have a look at the video and let me know what you think.
https://www.youtube.com/watch?v=OhlxE3EFcCQ
Merry Christmas
Malcolm Morrison
www.wienerdogaero.com
ic.com/" target=_blank>www.aeroelectric.com
arget=_blank>www.buildersbooks.com
lank>www.homebuilthelp.com
lank>www.mypilotstore.com
www.mrrace.com
//www.matronics.com/contribution" target=_blank>http://www.matronics.com/contribution
lb-List" target=_blank>http://www.matronics.com/Navigator?Kolb-List
; http://forums.matronics.com
_blank data-mce-href="http://www.aeroelectric.com">www.aeroelectric.com
/" target=_blank data-mce-href="http://www.buildersbooks.com">www.buildersbooks.com
=_blank data-mce-href="http://www.homebuilthelp.com">www.homebuilthelp.com
=_blank data-mce-href="http://www.mypilotstore.com">www.mypilotstore.com
ank data-mce-href="http://www.mrrace.com">www.mrrace.com
blank data-mce-href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
get=_blank data-mce-href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
a-mce-href="http://forums.matronics.com">http://forums.matronics.com
