mark_trickel
Joined: 13 Dec 2011 Posts: 101 Location: Philadelphia, PA, USA
Posted: Wed Nov 26, 2014 6:38 am Post subject: TR-1 Incident down under |
KIS Incident Down Under
With regret, I post this news from Australia - Michael Patten’s TR-1 main gear collapsed during roll out after touchdown when one of the attach bolts let lose:
Airframe event involving a Amateur Built Aircraft KIS TR-1, VH-AIG, Taree, Aerodrome, NSW on 9 September 1996.
Following an uneventful flight, the pilot reported that the aircraft touched down normally. After rolling about 80 m the right wing dropped and the pilot suspected a tire had failed. But about 50 m further on he heard pronounced scraping noises and the aircraft slewed right then left before finally coming to a halt about 10 m to the left of the runway. A subsequent inspection of the aircraft revealed that the fixed landing gear attachment bolts had failed at the countersunk heads. The failure faces contained rust deposits, indicating the bolts had been cracked for some time prior to the accident. The manufacturer has subsequently changed the design specification to fit standard flat head bolts in place of countersunk bolts.
The complete report is located here:
http://www.atsb.gov.au/publications/investigation_reports/1996/aair/199602857.aspx
I ran out to my hanger/shed, and checked mine (my TR-1C is a very early kit #23), it has the round Allen head bolts which are recessed into the attach bracket – I will be checking them for any signs of corrosion or cracking, and I recommend you check yours too. Can anybody confirm that there was a change to a counter sunk flat head bolt??? Galin – while you are down for repairs you may want to consider replacing these main gear bolts.
Mark T.
bakerocb
Posted: Wed Nov 26, 2014 8:03 am Post subject: TR-1 Incident down under |
11/26/2014
Hello Mark, I am sorry to hear of the KIS Incident Down Under. You wrote:
"Can anybody confirm that there was a change to a counter sunk flat head
bolt???"
Here is my perception / recollection of the landing gear retention bracket
situation:
1) The one piece aluminum main landing gear on the tricycle gear KIS TR-1
had a rectangular cross section and the center portion of the gear was
fastened into a recess in the bottom of the composite fuselage.
2) The gear was held up into place in the composite recess by two metal
brackets each of which had two bolts, one bolt forward of the cross section
and one bolt aft of the cross section.
3) The earlier kit's brackets were an aluminum bar and were notched on the
upper side to fit the rectangular cross section of the landing gear. These
aluminum brackets were also counter sunk or recessed around the bolt holes
in the bottom surface of the brackets so that either the head or threaded
end of the bolt (depending upon direction of bolt insertion) did not have to
project out into the air flow.
4) By the time my kit (#116) was made, the notched and recessed aluminum
brackets were no longer being provided. Instead two pieces of flat,
undrilled steel bar stock about 6 inches long, 1 inch wide, and 3/8 inch
thick were provided as landing gear retention brackets. (Don't hold me to
those exact dimensions -- I am not at the hangar and unable to measure.)
5) Since the flat steel bar stock was neither notched nor drilled the
builder had to drill holes in the bar stock such that the sides of the
bolts would keep the gear center cross section from shifting fore and aft.
6) Normal steel AN bolts were provided to hold the steel brackets in place
and either the head or threaded end of the bolt (depending upon direction of
insertion) was left to stick out into the airflow past the bottom surface of
the steel bracket.
Any questions?
OC
Sent: Wednesday, November 26, 2014 9:38 AM
To: kis-list(at)matronics.com
Subject: TR-1 Incident down under
let lose:
Mark T.
http://forums.matronics.com/viewtopic.php?p=434702#434702
Keith.Miller(at)esa.int Guest
Posted: Wed Nov 26, 2014 8:10 am Post subject: TR-1 Incident down under |
when did "The manufacturer has subsequently changed the design specification
to fit standard flat head bolts in place of countersunk bolts."take place . i
still have the countersunk bolts !!!!.
To: kis-list(at)matronics.com,
Date: 11/26/2014 03:40 PM
Sent by: owner-kis-list-server(at)matronics.com
let lose:
Mark T.
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
galinhdz(at)gmail.com Guest
Posted: Wed Nov 26, 2014 9:04 am Post subject: TR-1 Incident down under |
Last year (2013) I actually replaced these bolts and the rubber "gaskets" they had even though they looked good with no sign of fatigue.
On Wed, Nov 26, 2014 at 9:38 AM, mark_trickel <marktrickel(at)gmail.com (marktrickel(at)gmail.com)> wrote:
[quote]--> KIS-List message posted by: "mark_trickel" <marktrickel(at)gmail.com (marktrickel(at)gmail.com)>
Mark T.
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
     -Matt Dralle, List Admin.
List" target="_blank">http://www.matronics.com/Navigator?KIS-List
FORUMS -
sstearns2(at)yahoo.com Guest
Posted: Thu Nov 27, 2014 12:01 pm Post subject: TR-1 Incident down under |
I would recommend updating the gear installation using these gear blocks. The blocks allow the gear to flex without affecting the bolts and they allow the bolts to be properly preloaded.
http://www.groveaircraft.com/radiusplates.html
Scott
| Quote: | On Nov 26, 2014, at 6:38 AM, "mark_trickel" <marktrickel(at)gmail.com> wrote:
Mark T.
mjpienaar(at)shaw.ca Guest
Posted: Mon Dec 08, 2014 4:50 pm Post subject: TR-1 Incident down under |
Hi Scott
Would you recommend these gear installation blocks for the TR4 as well?
Mike
mikepapa(at)bigpond.com Guest
Posted: Tue Dec 09, 2014 2:37 am Post subject: TR-1 Incident down under |
Hi,
Just to clarify . This happened before my ownership, which I was aware of, and is in the log books. The damage was repaired well and the aircraft has flown 1000 hrs trouble free since. The current landing gear retaining brackets are pieces of flat bar, approx. 0.25in thick, with normal hex bolts. I believe they could be a little bit heavier, but they obviously work ok., as it has been into some ordinary strips.
Mike.
ftyoder(at)yoderbuilt.com Guest
Posted: Tue Dec 09, 2014 4:45 am Post subject: TR-1 Incident down under |
My kit #47 came with AN bolts but the manual shows the countersunk screws.
Posted: Sun Dec 14, 2014 4:21 pm Post subject: TR-1 Incident down under |
Yes, but grove does not make a 1.25" version so you would have to make a 0.25" spacer.
Scott
Sent: Monday, December 8, 2014 4:49 PM
Subject: Re: TR-1 Incident down under
--> KIS-List message posted by: "Mike Pienaar" <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)>
Hi Scott
Mike
Posted: Mon Dec 15, 2014 9:08 am Post subject: TR-1 Incident down under |
Thanks Scott,
What do you mean by "they allow the bolts to be properly preloaded"
Thanks for your help
Mike
Posted: Mon Dec 15, 2014 1:04 pm Post subject: TR-1 Incident down under |
Hi Mike,
The proper use of a bolt is to clamp parts directly together. Preloading a bolt is what we really do when we tighten a nut down to a certain torque value. The bolt stretches as you tighten the nut and the bolt provides a constant clamping force (preload) as long the load on the joint never exceeds the clamping force provided by preloaded bolt.
A great example is the bolts that clamp the main rod bearings around the crankshaft of an engine. Lycoming is very specific on the procedure for torquing these bolts right down to specifying a specific thread lubrication fluid. You can imagine if half the nut torque is going into moving a burr through the threads and not into stretching the bolt then you will not get the correct bolt preload. In this case the joint will not be clamped together with a load greater than the load from moving the piston and the joint will open slightly and stretch the bolt with each load application. Now the load on the bolt is cycling instead of the bolt being under a constant preload keeping the joint clamped together. Eventually the bolt will fatigue and fail. As I recall this is what happened to the 400 hour since factory new engine in the original factory demo Cruiser leading to an off field landing.
The landing gear bolts of course do not go through anywhere near the load cycles that the main bearing bolts do, but it is still good engineering to have bolted joints under a constant preload rather than cycling with every load cycle. This requires a continuous joint and not leaving any part of the bolt in the open air as in the factory landing gear installation.
Here is a picture of my landing gear installation on my TR-1. The bolts clamp the steel plate onto the flox pads and allow the bolts to be under a constant preload. The grove parts are a better option today though since they have a built in radius that allows the gear to flex so you don't need the rubber pad. The rubber pad goes around the landing gear and not under the bolts.
http://www.kisbuild.r-a-reed-assoc.com/KIS-TR1-Web/ScottSterns/landinggear1.JPG
[/url]
[url=http://www.kisbuild.r-a-reed-assoc.com/KIS-TR1-Web/ScottSterns/landinggear1.JPG]View on www.kisbuild.r-a-reed...
Preview by Yahoo
Anyhow, this was probably more than you were asking for, but I hope it helps.
Cheers,
Scott
From: Mike Pienaar <mjpienaar(at)shaw.ca> To: kis-list(at)matronics.com Sent: Sunday, December 14, 2014 5:54 PM Subject: Re: TR-1 Incident down under
Thanks Scott,
Mike
