bob88
Posted: Wed Dec 10, 2014 9:08 pm Post subject: Manifold pressure with G3X |
Getting ready to hang the engine and trying to do as much as possible on the back end first. My question relates to the Vans recommendation that the manifold pressure line be connected to the port on cylinder #5. I have a used, overhauled engine with the MP port on #6. The plug on #5 doesn't want to come out, at least without extraordinary measures. So...is there a problem using #6 for the MP line with the Garmin engine sensor system? If so, any suggestions about getting the plug out of #5?
john(at)trollingers.com Guest
Posted: Thu Dec 11, 2014 3:16 am Post subject: Manifold pressure with G3X |
I have a G3X and my MP is pulled off of my #6 just fine
On Thu, Dec 11, 2014 at 12:08 AM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=435587#435587
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
-Matt Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
Posted: Thu Dec 11, 2014 4:07 am Post subject: Manifold pressure with G3X |
You can use the portion any cylinder. The port on #5 is just closer to the firewall.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | On Dec 11, 2014, at 12:08 AM, bob88 <marty.crooks(at)comcast.net> wrote:
Kelly McMullen
Posted: Thu Dec 11, 2014 6:12 am Post subject: Manifold pressure with G3X |
As Jesse says, it doesn't matter between cylinders. You could just as easily use #3. The only difference is in the length of tubing to plumb to where ever you mount the sensor. The FF plans just show mounting MP sensor on the right side of the firewall, but there is nothing set in stone about where you put it. I've seen #1 used for MP on a 4 cyl Lyc for a type certificated aircraft.
On Thu, Dec 11, 2014 at 5:03 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: [url=tel:352-427-0285]352-427-0285[/url]
O: [url=tel:352-465-4545]352-465-4545[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
> On Dec 11, 2014, at 12:08 AM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
le, List Admin.
">http://forums.matronics.com
A&P/IA, EAA Tech Counselor
KCHD |
karolamy(at)roadrunner.co Guest
Posted: Fri Dec 12, 2014 11:30 am Post subject: Manifold Pressure with G3X |
Regarding plug removal, what tool are you using? If memory serves me correctly it usually is just a 3/16 hex on those ports. Are you using a 3/8 drive socket with 3/16 hex in socket? And penetrating lube of choice?
Need to know what you've done/tried for suggestions - as well as mayb a pic of issue. Otherwise as others said don't ruin a cyl, just go for another port.....
Rich
| Quote: | On Dec 12, 2014, at 12:02 AM, RV10-List Digest Server <rv10-list(at)matronics.com> wrote:
whodja
Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
Posted: Sat Dec 13, 2014 4:38 am Post subject: Re: Manifold pressure with G3X |
Good choice for penetrating lube; 50% ATF (automatic trans fluid) and 50% acetone.
I hope that helps,
Tal
davidsoutpost(at)comcast. Guest
Posted: Sat Dec 13, 2014 7:50 am Post subject: Manifold pressure with G3X |
Sent: Saturday, December 13, 2014 7:38:19 AM
Subject: Re: Manifold pressure with G3X
--> RV10-List message posted by: "whodja" <whodja(at)gmail.com>
I hope that helps,
Tal
http://forums.matronics.com/viewtopic.php?p=435677#435677
