RotaxEngines-List Digest: 2 Msgs - 10/16/06
Guy Buchanan
PostPosted: Fri Oct 20, 2006 7:25 pm    Post subject: RotaxEngines-List Digest: 2 Msgs - 10/16/06 Reply with quote
At 05:41 AM 10/17/2006, you wrote:
Sorry I left out some of the details. The engine is a Mod 99 (Blue Head)
582 with 'E' box with 3:1 ratio. The plane is a Model II Kitfox that was
completed in 1996. I have the prop angle set at 10.5 to play around at
home and 11.0 degrees when I want to do cross country. The Model II has
a very STOL wing and my cruise is about 70 mph but I can push it to 95
wide open.
Thanks Stan. You're numbers are a little more consistent with mine, as I'm
getting 80mph cruise at 5800rpm out of my 3:1 582 in a K-IV-1200. I use 12
degrees. Unfortunately others do much better. (Isn't that always true?)
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
