jack.byrne(at)bigpond.com Guest
Posted: Thu Oct 19, 2006 1:09 pm Post subject: Boots on Battery Contactor. |
Bob and Listers.
With reference to the discussion that has been going on re this subject.
My starter and battery contactor both came from B & C. The battery contactor
has boots the starter contactor does not. Got them 12 months ago.
I emailed B & C about the boots on the battery contactor and got the
following reply.
The S701-1 and S701-2 are the same basic contactor. The coil is isolated
from the case, therefore the case need not be grounded. Both coil leads are
brought out to their respective #10 studs on the side of the cylinder. Note
that the pre-wired S701-1 coil receives its power through the Red jumper
from the battery post, and its ground through the Master Switch (which is
connected to the other #10 stud).
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>
Now, if I knew how the switches worked I would have been able to see that
the wire from the Master switch was a GND wire and not a +12V wire.
Which is different than the starter contactor, the wire from the start
switch is +12V and the starter contactor gets its GND from the
airframe.(Z13-
So no need to grind the boots off the battery contactor
Maybe this will clear it up.
Chris Byrne
SYDNEY
nuckollsr(at)cox.net Guest
Posted: Sun Oct 22, 2006 7:38 am Post subject: Boots on Battery Contactor. |
At 07:06 AM 10/20/2006 +1000, you wrote:
<jack.byrne(at)bigpond.com>
Bob and Listers.
following reply.
airframe.(Z13-
Aha! I thought we were discussing the S702 STARTER contactor
that MUST find a coil connection through the mounting feet.
If the discussion is limited only to the battery and crossfeed
contactors, then yes . . . the boots are not an electrical issue
but it would still be interesting to know why they were added
after about 75 years of successful service sans boots.
< with experiment. >
< --Lawrence M. Krauss >
